General
Unique ID : 197467734792834256060161544616693852580 (0x948EE7005473749396877EB8B2D9E9A4)
Complete name : T:\123\Hercules (2014).mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 11.4 GiB
Duration : 1h 37mn
Overall bit rate : 16.8 Mbps
Movie name : Hercules 2014-1080p LolHD
Encoded date : UTC 2014-11-03 18:18:58
Writing application : mkvmerge v6.8.0 ('Theme for Great Cities') 64bit built on Mar 2 2014 21:34:26
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 37mn
Bit rate : 15.0 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.406
Stream size : 10.2 GiB (89%)
Title : Hercules 2014-1080p LolHD
Writing library : x264 core 142 r2479kMod dd79a61
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=0 / crf=18.0000 / qcomp=0.65 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=50000 / vbv_bufsize=62500 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.20 / pb_ratio=1.20 / aq=3:0.85 / zones=9625,10212,b=1.4/13245,13935,b=1.4/13936,14059,b=1.2/14060,14144,b=1.4/14145,15106,b=1.2/15107,15286,b=1.4/15287,15423,b=1.2/15424,15509,b=1.4/15510,15726,b=1.2/15727,15947,b=1.4/15948,16275,b=1.2/16276,16442,b=1.4/16443,16583,b=1.2/16584,16820,b=1.4/16821,16884,b=1.2/16885,17275,b=1.4/17276,17321,b=1.2/17322,17391,b=1.4/17392,17449,b=1.2/17450,17506,b=1.4/17507,17550,b=1.2/17551,18718,b=1.4/18757,18794,b=1.4/18824,20261,b=1.4/20262,22065,b=1.1/22066,27586,b=1.4/27587,30742,b=1.3/30743,31651,b=1.4/31652,33774,b=1.2/34556,35422,b=1.4/36020,37345,b=1.4/41301,45489,b=1.3/45490,47705,b=1.4/47822,48228,b=1.4/48455,49134,b=1.4/52765,53602,b=1.4/55556,56973,b=1.4/56974,57954,b=1.2/62342,81614,b=1.3/97969,98160,b=1.3/98227,98682,b=1.3/98738,101660,b=1.3/102733,103803,b=1.3/111889,123337,b=1.4/127535,140212,b=0.4
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 1h 37mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 1.03 GiB (9%)
Language : Vietnamese
Default : Yes
Forced : No
