Còn với Alcohol mới nhất thì bị thế này:
########################### System Information ###########################
Windows 7 Ultimate 6.1 Service Pack 1 (Build 7601)
Processor info: Intel(R) Pentium(R) 4 CPU 3.20GHz x 2 (3198MHz)
Physical memory available to Windows: 1,038,520 KB
############################ Program Information ###########################
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\Alcohol.exe
Company Name: Alcohol Soft Development Team
Description: Alcohol 120%
Original: Alcohol.exe
Product: Alcohol 120%
Trademarks: Alcohol Soft Development Team
Copyright: Copyright(C) 2002-2010 Alcohol Soft Development Team
Version: 2.0.1 ( Build 2033 )
Date: 2010/09/17
Hash: 5e4a0d97feeb20c9c2aad6c3f66ce66d
Hash(1): d1a7d53c01d606372993559997c72f31b27b0eb5e471c4032596595d6ae3e69
Hash(2): 38895af1c71f02d81ff332d01c55e3cbc5c0e68bc7c1470493979f95c079be0
Loader: c:\windows\explorer.exe
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
Description: Alcohol virtual device control library
Original: alcoholx.dll
Product: Alcohol
Copyright: Copyright (C) 2000-2010
Version: 4.36.0 ( Build 0 )
Date: 2010/07/17
Hash: d2a2ef36614cde99ff3aa4703d7682a4
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\DevSupp.dll
Description: Alcohol Software Device Capability Library
Original: DevSupp.dll
Product: Alcohol Software Device Capability Library
Version: 2.8.1 ( Build 2316 )
Date: 2010/09/17
Hash: a9ea42efee2021c634f656031e55ba76
########################### User Information ###########################
Licensed to:
[email protected]
Registered User ID: 6F46
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
SCSI Pass Through Direct (SPTD) layer version: 1.74
CPU Priority Level: High
Memory Buffer Size (MB): 256
Examine the accuracy of data read from physical device: Yes
Enable Enhanced Weak Sector Scanner during dumping: No
Overburn disc(s): No
Turn off "Auto-Select best write speed" function if possible: No
Fill memory buffer before recording discs: Yes
Book Type DVD+R/DVD+RW disc as DVD-ROM while burning: No
Ignore Media Type: No
RMPS (Recordable Media Physical Signature) Emulation: No
BAD Sectors Emulation: No
Sub-Channel Data Fixed & Emulation: No
Laserlock Emulation: No
UI Language: English
############################ Device(s) List ############################
(E
TSSTcorp CDDVDW SH-S223C (atapi, Port 2, Bus 1, Target 1, Lun 0)
(F
NYX 5QZWTEFK (aqmu0n4h, Port 3, Bus 0, Target 0, Lun 0)
##################### Installed Device Drivers List #####################
ACPI.sys afd.sys AgileVpn.sys Alcoholx.dll amdxata.sys
apisetschema.dll aqmu0n4h.SYS atapi.sys ataport.SYS autochk.exe
Beep.SYS blbdrive.sys BOOTVID.dll bowser.sys cdd.dll
cdfs.sys cdrom.sys CI.dll CLASSPNP.SYS CLFS.SYS
cng.sys CompositeBus.sys cpuidlep.SYS cpuz134_x32.sys crashdmp.sys
csc.sys dfsc.sys discache.sys disk.sys drmk.sys
dump_atapi.sys dump_dumpata.sys dump_dumpfve.sys Dxapi.sys dxgkrnl.sys
dxgmms1.sys fdc.sys fileinfo.sys fltmgr.sys Fs_Rec.sys
fvevol.sys fwpkclnt.sys giveio.sys halmacpi.dll HDAudBus.sys
HdAudio.sys HIDCLASS.SYS HIDPARSE.SYS hidusb.sys HTTP.sys
hwpolicy.sys igdkmd32.sys intelide.sys intelppm.sys ISODrive.sys
kbdclass.sys kbdhid.sys kdcom.dll ks.sys ksecdd.sys
ksecpkg.sys lltdio.sys luafv.sys mcupdate_GenuineIntel.dll monitor.sys
mouclass.sys mouhid.sys mountmgr.sys mpsdrv.sys mrxsmb.sys
mrxsmb10.sys mrxsmb20.sys Msfs.SYS msisadrv.sys msrpc.sys
mssmbios.sys mup.sys ndis.sys ndistapi.sys ndiswan.sys
NDProxy.SYS netbios.sys netbt.sys NETIO.SYS Npfs.SYS
nsiproxy.sys ntdll.dll Ntfs.sys ntkrnlpa.exe Null.SYS
pacer.sys parport.sys partmgr.sys parvdm.sys pci.sys
PCIIDEX.SYS pcw.sys peauth.sys portcls.sys PSHED.dll
rasl2tp.sys raspppoe.sys raspptp.sys rassstp.sys rdbss.sys
rdpbus.sys RDPCDD.sys rdpencdd.sys rdprefmp.sys rdyboost.sys
rspndr.sys Rt86win7.sys SCSIPORT.SYS secdrv.SYS serenum.sys
serial.sys smss.exe speedfan.sys spldr.sys spsys.sys
sptd.sys srv.sys srv2.sys srvnet.sys swenum.sys
tcpip.sys tcpipreg.sys TDI.SYS tdx.sys termdd.sys
TSDDD.dll tunnel.sys udfs.sys umbus.sys usbccgp.sys
USBD.SYS usbehci.sys usbhub.sys USBPORT.SYS usbuhci.sys
vdrvroot.sys vga.sys VIDEOPRT.SYS vmstorfl.sys volmgr.sys
volmgrx.sys volsnap.sys wanarp.sys watchdog.sys Wdf01000.sys
WDFLDR.SYS wfplwf.sys win32k.sys WMILIB.SYS WudfPf.sys
################## Detailed Information of Device(s) ##################
(E
TSSTcorp CDDVDW SH-S223C (2:1) detail information.
Vendor Identification: TSSTcorp
Product Identification: CDDVDW SH-S223C
Production Revision Level: SB05
Support recording method: DAO / SAO, RAW SAO, RAW SAO + SUB, RAW DAO(96), TAO, DVD DAO
BURN-Free Technology: BURN-Proof
Auto-Select best write speed: Not Supported
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 02h
CD-R & CD-RW Read / Write: CD-R: Yes / Yes, CD-RW: Yes / Yes
Read CD-R Fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R and DVD-RAM Read / Write: DVD-R: Yes / Yes, DVD-RAM: Yes / Yes
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 / 2 Supported: Yes / No
Mode 2 Form 1 / 2: Yes / Yes
Multi-Session: Yes
BUF: Yes
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: Yes
R-W De-interleaved and Corrected: No
C2 Pointers Support: Yes
ISRC / UPC Supported: Yes / Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
###################### Source Disc/Image Information ######################
Type: Media Descriptor Image file
Path: D:\Data\
Name: Sakura no Reply.mds
Session: 1
Track: 1
File(s): Sakura no Reply.mdf
####################### Dumping/Recording Progress Log #######################
********* Time stamp of this log file: 2012/06/11 10:20:00 *********
10:20:00 Processor info: Intel(R) Pentium(R) 4 CPU 3.20GHz x 2 (3198MHz)
10:20:00 Physical memory available to Windows: 1,038,520 KB
10:20:00 Memory Buffer size: 256 MB
10:20:00 Image file loading: D:\Data\Sakura no Reply.mds
10:20:00 DVD Source Info: Session: 1, Track: 1, Length: 6.11 GB / 3205312
10:20:11 (E
TSSTcorp CDDVDW SH-S223C (2:1): Recording Method/Speed
10:20:11 Illegal speed 8.0X (11080 KB/Sec) for this media, running on 6.0X (8310 KB/Sec)
10:20:11 Recording - DAO - 6.0X (8310 KB/Sec)
(E
TSSTcorp CDDVDW SH-S223C (2:1) - Media format: DVD+R (Double Layers)
10:20:11 (E
TSSTcorp CDDVDW SH-S223C (2:1): BURN-Free activated
10:35:43 Image file loading completed!
10:36:25 (E
TSSTcorp CDDVDW SH-S223C (2:1) - [Write ERROR] LBA: 3161216, Length: 32
S:KEY - 03/0C/82 - "Undocumented Error Message!"
10:36:25 (E
TSSTcorp CDDVDW SH-S223C (2:1): Recording failed!
10:36:25 Error message: [03/0C/82] - Undocumented Error Message!
10:36:25 (E
10:36:32 Something is wrong with the recording procedure! Please check the log file and report any errors to Technical Support.
Vậy phãi giải quyết ra sao?
