Ðề: Hỏi han - Xin xỏ các vấn đề HD Hà Nội post ở đây nhé!!!
dàn của em trong sách hướng dẫn sử dụng có ghi là có giải mã dts digital....pro logic gì gì đó em không nhớ lắm.
à cái đó đây:e copy nguyên bản của nó các bác xem xong nói cho e bít có nên mua thêm cardsound không?
PAL/NTSC Playback of DVD/VCD/DVD-R
MP3, Audio CD, CD-R, CD-R/W Playback
To play PAL movies you need a PAL TV or a Video converter
Plays DVD-Video discs, SACDs, CDs, and audio CD-Rs & CD-RWs
5 speaker surround sound - independently position the 5 speakers to give you the best surround sound
290 Watts Total System Power
Remote Commander Remote Control
Front Optical Digital Input For Video Game Consoles
Dolby Digital, dts And Dolby Pro Logic Decoder
3-Disc DVD/CD Changer
Subwoofer Output
Digital Cinema Sound System With 32-Bit DSP
Innovative Digipad™ Touch-Sensitive Interface
Audio Line In/Out (Analog): 2/1
Advanced DSP Modes With Theater Reverberation Effects
Audio Line In/Out (Digital): 1/1
2-Way Shielded Main Speakers With 6-Inch HOP Woofers
Dual Auto Reverse Dubbing Deck With Full Logic Controls
3-disc carousel changer (change 2 discs while the 3rd keeps playing)
Double auto reverse dual cassette deck with hi-speed dubbing
Quality Design and Sound
On-screen GUI
headphone jack
Dual Voltage system for use in any Country!
Switches between 110-240 volts 50/60 hertz - Use it world-wide!!
Description:
3500W P.M.P.O. with DVD Playback: The MHC-RV660D offers a new level of audio performance by belting out 2200W P.M.P.O. of unbridled power.
Digital Cinema Sound with DSP Sound Effect
Dolby Digital (AC3) / DTS: Sony provides a future proof solution for all your DVD movies! Dolby Digital features 5.1 discrete channels -2 rear surround, 2 front, 1 center and 1 sub-woofer. As a result, this format offers good dynamic range, channel separation, and Signal-to-Noise (S/N) ratio, and can therefore produce the feeling of being at a live theatre performance. Also supported is DTS surround sound format. DTS offers even better surround sound quality with its lower compression factor. This brings DTS sound much closer to original master quality.
V-Groove: V-Groove enhances the low frequency effects of all your favorite music and Video CD software. Designed for realistic sound reproduction, V-Groove delivers impressive 'in-concert' ambience as well as putting you right in the thick of any movie. Thanks to its unique low frequency (50-100Hz) response, loudness and volume enhancement, it is versatile enough to handle the demands of high-fidelity sound as well as the power needed for delivering a convincing soundtrack. Realism takes on a new meaning with V-Groove.
Variable Attenuation Control System (VACS): Sony's Variable Attenuation Control System (VACS) achieves sound reproduction with superb clarity, even at high volume levels. By eradicating sound distortion which commonly occurs during high volume playback, VACS lets you enjoy your music the way it was meant to sound.
Hybrid Dual Woofer: A unique design that integrates a two-stage woofer, for excellent coverage of bass sound. Whether it's mid to low frequency or even extremely low frequency sound segments, the Hybrid Dual Woofer gives you the power and flexibility to enjoy excellent bass across the spectrum.
Speakers:
5 Speakers
Front: 3-way, 15cm Woofer x 2, HOP Woofer, Balance Driven Tweeter
Centre: Dual 8cm Units
Rear: 8cm Units
Amplifier:
110w x 2 + 40w x 3 RMS, 3500w PMPO
Dolby Digital, Dolby Pro Logic, DTS
DVD, Tuner, Tape, A/B, MD, Digital
Input: Optical input x 1, Analogue input x 2,
Mic input (Minijack w/Volume) x 1
Tuner
FM 20/MW 20 Presets, RDS
Additional Features:
Operational Keys for Amplifier Unit
Direct Selection of Cinema Studio Effects with Illuminated Keys
File Select Jog for Easy Selection of Preset Files
Sound Parameter and EQ Adjustment with 4-Direction Key and "SUR" / "E"
More Technical specs:
Power Output - Front (RMS10%THD): 100w x 2
Power Output (PMPO): 2200W
Audio Line IN/OUT (Analog): 2 / 1
Audio Line IN/OUT (Digital): -/1
Output Terminal (Center/Rear/Surround/Sub Woofer): - / - / - / Yes
Video Signal IN/OUT: "1/3 (S/Component/Composite)"
Mic IN/VOLUME/ECHO: 1 (6.3)/Yes/Yes
Headphone Jack (3.5mm / 6.3 mm): Yes (3.5)
Graphic Equalizer: 3 Band
Preset EQ: 12
Programable EQ setting (Personal File): 3
Bass/Treble control: EQ
Bass Boost function: GROOVE / V-GROOVE
Dolby Digital: Yes
DTS: Yes
PowerStream indicator: 6LEDs
DSP Edit/EQ Edit: -/Yes
Dimmer: Yes
VACS: Yes
Karaoke-PON/Multiplex: "Yes/Yes (only DVD function)"
Key control: Yes
Cinema Space/Surround: -/Yes
Direct AV EQ: Yes
GAMESYNC MIXING: Yes
Virtual Speaker Mode: "Yes (only DVD function)"
Timer: Yes
Power Save Mode: Yes
Band: FM / MW
Tuning Range (FM): 87.5 ~ 108.0 MHz
Tuning Range (AM): 531-1602kHz/9kHz, 530-1710kHz/10kHz
Station Preset: FM20 / MW10
External FM/AM Antenna: Yes (75 ohm)
DVD/SACD/CD/Video CD Player Type: 3DVD Tray
D/A Converter (Video / Audio): - /1Bit
Digital Filter (Bit/fs): 18 bit / 8 fs
DVD/DVD Audio/SACD/CD/Video CD: Yes/-/-/Yes/Yes
CD-R / CD-RW Play Back: Yes / Yes
DVD / CD / SACD TEXT: Yes / Yes /-
Exchange: Yes
Play Mode (Shufle / Program / Repeat): Yes / Yes / Yes
VCD Version 2.0: Yes
Picture Navigator: Yes
Tray Lock (at demo mode): Yes
MP3 Playback: Yes
JPEG Playback: Yes
Tape Deck Type: Double
Recordable deck (A/B): -/Yes
Auto Reverse (A/B): Yes/Yes
Operation: Full Logic
CD Syncro Recording: Yes (no Fade)
AMS
