Ðề: Chuyên mục 2 kênh - HD Quảng Ninh
Con nầy uýnh với Usher 718 Diamond hay lắm.
Tình hình là em đang định lên đời em này:
LUXMAN 550AII
Product Description
Continuous Output
* 20W + 20W/8Ω Class A
* 40W + 40W/4Ω
Total Harmonic Distortion
* 0.006% or less (8Ω at 1KHz)
* 0.03% or less (8Ω from 20~20KHz)
Input Sensitivity / impedance
* PHONO (MM) : 2.5mV/47KΩ
* PHONO (MC) : 0.3mV/100Ω
* LINE : 180mV/42KΩ
* BAL. LINE : 180mV/79KΩ
* MAIN-IN : 450mV/51KΩ
Output Voltage
* RECORDER: 180mV and PRE-OUT: 1V
Signal-to-Noise Ratio
* PHONO (MM) : Above 91dB
* PHONO (MC) : Above 75dB
* LINE : Above 106dB
Frequency Response
* PHONO : 20Hz~20,000Hz (0.5dB)
* LINE : 20Hz~100,000Hz (+0dB ~ -3dB)
Tone Controls
* Bass 10dB at 100Hz and Treble 10dB at 10kHz
Loudness Control
* +7dB (1dB) at 100Hz, +5dB (1dB) at 10kHz
Controls
* Power meter, headphones jack
* Recording selector
* Speaker selector (A and B), stereo / mono selector
* Tone controls, balance and direct line
* Sub sonic filter, loudness and line phase sensor
* Remote control
Electric Power Consumption
* 190W (on, but without a signal), 1.3W (idle)
Voltage
* AC100V(50Hz / 60Hz)
Dimensions
* 18.3” (W) × 7” (H) × 17.1” (D)
Weight
* 48.4 lbs (22kg)
Các bác cho em vài lời khuyên với. Nó đi với loa nào, chơi nhạc gì thì ngon nhất ạ.
