Để fix vụ cover bé tí 160x160 của minidlna. Các bước như sau. Tút này em chạy trên pi4 v1.1 / Buster lite 5.4.83 (2021-01-11).Bác cho em cái hướng dẫn nhé, thanks
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 5.4.83-v7l+ #1379 SMP Mon Dec 14 13:11:54 GMT 2020 armv7l GNU/Linux
pi@raspberrypi:~ $ cat /proc/cpuinfo | grep Model
Model : Raspberry Pi 4 Model B Rev 1.1
pi@raspberrypi:~ $ cat /proc/meminfo | grep Mem
MemTotal: 3919796 kB
MemFree: 2849096 kB
MemAvailable: 3645708 kB
1. Uninstall minidlna nếu đã install trước đó:
sudo apt-get purge minidlna -y
sudo apt-get remove minidlna
sudo apt-get autoremove -y
2. Download 2 file này về pi. Mặc nhiên là /home/pi
minidlna-1.2.1.tar.gz
wget https://sourceforge.net/projects/minidlna/files/minidlna/1.2.1/minidlna-1.2.1.tar.gz
Mirror:
wget "https://drive.google.com/uc?export=download&id=1CxkYoMsSuANV9Ye1L-9FTNIjPr1-omys" -O minidlna-1.2.1.tar.gz
minidlna-1.2.1-cover-resize.patch
wget https://gist.github.com/grigorye/d30bbed518226e44a18eec75f6f6159e/raw/78a5e3261cc6c88bbf901cd1adac26ec6b2f978b/minidlna-1.2.1-cover-resize.patch
Mirror:
wget "https://drive.google.com/uc?export=download&id=1LPz61FHqi1XcNQtPJfVooi3euqJUK-im" -O minidlna-1.2.1-cover-resize.patch
3. Chạy các lệnh sau:
sudo apt-get update
sudo apt-get install build-essential autopoint debhelper dh-autoreconf gcc libavutil-dev libavcodec-dev libavformat-dev libjpeg-dev libsqlite3-dev libexif-dev libid3tag0-dev libogg-dev libvorbis-dev libflac-dev -y
tar -zxvf minidlna-1.2.1.tar.gz
cd minidlna-1.2.1
cp /home/pi/minidlna-1.2.1-cover-resize.patch ./
patch -p1 < minidlna-1.2.1-cover-resize.patch
./configure
make
sudo make install
sudo cp ./minidlna.conf /etc/
sudo cp linux/minidlna.init.d.script /etc/init.d/minidlna
sudo chmod +x /etc/init.d/minidlna
sudo update-rc.d minidlna defaults
sudo mkdir /var/cache/minidlna
4. Edit file /etc/minidlna.conf như sau. /mnt/NAS là nơi chứa nhạc:
media_dir=A,/mnt/NAS
resize_covers=no
friendly_name=minidlna
db_dir=/var/cache/minidlna
log_dir=/var/log
log_level=no
inotify=yes
root_container=M
wide_links=yes
5. Start và stop service:
sudo service minidlna stop
sudo service minidlna start
Cập nhật library - forces a rescan:
sudo /usr/local/sbin/minidlnad -r
Cập nhật full library - forces a rebuild:
sudo /usr/local/sbin/minidlnad -R
6. Test:
pi@raspberrypi:~ $ /usr/local/sbin/minidlnad -V
Version 1.2.1
pi@raspberrypi:~ $ service minidlna status
● minidlna.service - LSB: DLNA/UPnP-AV media server
Loaded: loaded (/etc/init.d/minidlna; generated)
Active: active (running) since Thu 2021-02-11 08:51:25 +07; 3min 30s ago
Docs: man:systemd-sysv-generator(8)
Process: 573 ExecStart=/etc/init.d/minidlna start (code=exited, status=0/SUCCESS)
Tasks: 3 (limit: 4915)
CGroup: /system.slice/minidlna.service
├─590 /usr/local/sbin/minidlnad -f /etc/minidlna.conf
└─621 /usr/local/sbin/minidlnad -f /etc/minidlna.conf
Feb 11 08:51:24 raspberrypi systemd[1]: Starting LSB: DLNA/UPnP-AV media server...
Feb 11 08:51:25 raspberrypi minidlna[573]: Starting minidlna: minidlna.
Feb 11 08:51:25 raspberrypi systemd[1]: Started LSB: DLNA/UPnP-AV media server.
http://your_ip:8200/
7. Edit file /etc/sysctl.conf thêm vào phía dưới:
fs.inotify.max_user_watches = 65536
sudo reboot
Vậy là xong ạ!
Lưu ý:
@@@ Ở bước 2. Nếu thích mình có thể patch thêm 2 cái nữa:
- minidlna-1.2.1-add-support-dsd.patch | Support DSD
wget "https://drive.google.com/uc?export=download&id=1zO1NrOjxiCmtOTvgYceyVskX1mXwzrt8" -O minidlna-1.2.1-add-support-dsd.patch
- favicon-support-v1.2.1.patch | Fix lỗi requests favicon.ico 404 error (Không quan trọng lắm)
wget "https://drive.google.com/uc?export=download&id=1M-oOJJ2mvaZQ_e3lbk_axclHMy0ZUwoV" -O favicon-support-v1.2.1.patch
Cần chạy thêm 2 lệnh này ở bước 3:
patch -p1 < minidlna-1.2.1-add-support-dsd.patch
patch -p1 < favicon-support-v1.2.1.patch
@@@ Cách bên trên tạo service theo kiểu cũ init.d. Nếu thích mình có thể cho nó chạy theo cách systemd minidlna.service. Em sẽ test sau ạ.
More info: Service init.d scripts vs /etc/systemd/system vs /usr/lib/systemd/system
Trước và sau khi fix covers:
More info:
http://m.blog.naver.com/parkmino45/221099945434
https://github.com/ywhs/linux-software/releases/tag/1.2.1
https://octroom.exblog.jp/21092409/
https://melgrubb.com/2016/12/11/rphs-v2-minidlna/
https://sourceforge.net/p/minidlna/patches/152/
