dvson185
Components Removed
Australia Local Pack
Canada Local Pack
Great Britain Local Pack
Music and Video Examples (Ringtones)
New Zealand Local Pack
Tablet PC Components
Services altered
FTP --- Set to ---> Disabled
IP Helper --- Set to ---> Disabled
LPD Service --- Set to ---> Disabled
Offline Files --- Set to ---> Disabled
Windows Event Log --- Set to ---> Automatic
Security Center --- Set to ---> Automatic (Delayed Start)
Windows Search --- Set to ---> Disabled
Media Center Extender --- Set to ---> Disabled
Net.Msmq Listener Adapter --- Set to ---> Disabled
Net.Pipe Listener Adapter --- Set to ---> Disabled
Net.Tcp Listener Adapter --- Set to ---> Disabled
Net.Tcp Port Sharing --- Set to ---> Disabled
Application Management --- Set to ---> Disabled
Branch Cache --- Set to ---> Disabled
Certificate Propagation --- Set to ---> Disabled
Distributed Link Tracking Client --- Set to ---> Disabled
Netlogon --- Set to ---> Disabled
Network Access Protection Agent --- Set to ---> Disabled
Parental Controls --- Set to ---> Disabled
Remote Procedure Call (RPC) Locator --- Set to ---> Disabled
Remote Registry --- Set to ---> Disabled
Routing and Remote Access --- Set to ---> Disabled
Smart Card --- Set to ---> Disabled
Smart Card Removal Policy --- Set to ---> Disabled
SNMP Trap --- Set to ---> Disabled
Windows Connect Now - Config Registrar --- Set to ---> Disabled
Windows Media Player Network Sharing --- Set to ---> Disabled
Windows Process Activation --- Set to ---> Disabled
Tweaks
Add 'Admin Tools' to Desktop context-menu
Add 'Open Elevated CMD here' to Folder context-menu
Add 'Take Ownership' to context-menu
Add 'Task Manager' to desktop context-menu
Remove 'Troubleshoot Compatibility' from context-menu
Remove the Action Center icon
Show 'Computer' on Desktop
Show 'Control Panel' on Desktop
Show 'Network' on Desktop
Allow 3rd Party Themes
Disable Drive Autorun
Disable Last File Access Timestamp
Disable Low Disk Space Notification
Disable Search Online on Unknown File Extensions
Disable Shortcut Link Resolve
Disable Thumbnail Cache
Increase Icon Cache
Launch Folder Windows in a Separate Process
Show File Extensions
Speed Up Desktop
Speed-up Access to AVI Media Files
Change Setup Background
Disable Accelerator
Disable Default Browser Check
Disable First Run Customize
Faster Browsing in IE
GPU Rendering::GPU Rendering On
Set Google as Search Provider
Turn On Cleartype
Unlimited Simultaneous Downloads
Administrative Tools::All Programs
Games::Hide
Help and Support::Hide
Run::Show
Change Logon Background
Detailed Shutdown & Logon
Disable Startup sound
Disable User Account Control
Enable MSI Service in Safe Mode
Shut Down Quicker
Always Unload DLLs
Always Write Crash Dump Files
Block Negative DNS Entries
Disable Admin Shares
Disable Automatic Restart on BSOD
Disable Bandwidth Limit
Disable CPU Parking (AMD)
Disable Dr Watson
Disable NTFS Encryption
Disable Prefetch
Disable Windows Error Reporting
Don’t allow Windows to turn off devices
Increase File System Memory Cache Size
Increase RPC Packet Size
Keep Positive DNS Entries
Large System Cache::Enable
Turn off system beeps
Softwares
Microsoft Office Pro 2016 (updated)
7zip
Google chrome
Directx
.Net Frameworks 4.6.1
Rainmeter + Aimp3 (skin fits the theme)
Firefox
Java RE 8.66
Adobe Reader DC
uTorrent Pro
Visual C++ Redistributable (2005 > 2013)
Virtual Clonedrive (Optional : Require user confirmation for certificate )
Winrar
Checksums
Size: 5246210048 bytes (5003 MB)
CRC32: CDAC87DA
CRC64: 2C03A9F250B73F10
SHA1: 5873B4365EB150E4BF54EACE80DD30227CC2B32E
SHA256: 6A72C0660BBC86B9E1C77E6A5719BA458AB649A2FF8B8F11F194AC5768FE4014
Bản này bình thường là cho VIP nhưng sắp đến giáng sinh nên họ free cho tất cả luôn
