Ðề: [Chia sẻ]Data XBMC được cập nhật thường xuyên với những Add-on mới nhất và hay nhất năm 2015
Bộ thu thập và lưu trữ dữ liệu Campbell Scientific Datalogger CR1000
Thông tin s?n ph?m chi ti?t <http://doluongdieukhien.com/bo-thu-thap-va-luu-tru-du-lieu-campbell-scientific-datalogger-cr1000-6722633.html>
Benefits and Features
Ideal applications include fire weather, mesonet systems, wind profiling, weather stations, air quality, ETo/agriculture, soil moisture, water level/stage, aquaculture, avalanche forecasting, time-domain reflectometry, vehicle testing, SCADA, and water quality
Serial communications with serial sensors and devices supported via I/O port pairs
Collects and stores data and controls peripherals as the brain of your system
Flexible power and communication options make it ideal for remote locations.
4-MB memory can be expanded with add-on memory systems.
Supports PakBus, Modbus, SDI-12, and DNP3 protocols
Compatible with channel expansion peripherals allowing you to expand your system
Program with LoggerNet, PC400, or Short Cut to fit your setup
Communicates via various options: TCP/IP, email, FTP, web server.
Gas Discharge Tube (GDT) protected inputs
Battery-backed clock that ensures accurate time is maintained while datalogger is disconnected from battery power
Program and control on site with addition of CR1000KD keyboard and display unit.
Contains custom ASIC chip that expands pulse count, control port, and serial communications capabilities
Nguyen Van Hung
Công ty TNHH Thiết bị đo lường và điều khiển
Địa chỉ: CL37, Khu đô thị Nam La Khê, 368B Đường Quang Trung, Quận Hà Đông, TP Hà Nội
Mobile: +84 904 251 826
Tel: +84-4-85894254
Web: <http://doluongdieukhien.com/>
Skype/Yahoo: nvhung.mctt
Email:
[email protected] <mailto:
[email protected]>
