[MULTI] Microsoft Windows 10 6-in-1 AIO English Full Updated 08.05.2015 Pre-Activated
auvie
Microsoft Windows 10 6in1 AIO English Full Updated 08.05.2015 Pre-Activated
Notice 1:Updates Integrated:KB3074683(138MB) And KB3081424 (313MB) Thats Why the iso have that Size The Other 2 Updated Installed Automatically so no worrys
Notice 2:If you defender see malware or something just for you know is kmspico is 100% trusted and Works ...Defender find like malware or virus cauze they didn't know the application
UAC:disable for kmspico should works without ask you ..if you want enabled go in control panel/action center/change settings and choose that you want
Compression:Install.wim to Install.esd
Activation:Kmspico (180 Days) (silent Activation First Login)
Last BuildLab:10240.th1.150729-1800
Last BuildLabEx:10240.16412.amd64fre.th1.150729-1800
Mode:Bootable
Editions:Home x86-x64 /Pro x86-x64 / Enterprise x86-x64
Sources iso's used for AIO:
File: en_windows_10_multiple_editions_x86_dvd_6848465.iso
CRC-32: 57f04dbd
MD4: 3b072fe6f36cff9299b906f8c0d22ee9
MD5: 99feb0f9e7262b7eefa460840a31b59d
SHA-1: d927a91e1dd7d9c6023d0da1dbcb16defec5b6c1
File: en_windows_10_multiple_editions_x64_dvd_6846432.iso
CRC-32: b1a4699e
MD4: 36a8b5ac130301bee799683b00c732e1
MD5: 23e397a21a9e01f141c64b7e1260314a
SHA-1: 60cce9e9c6557335b4f7b18d02cfe2b438a8b3e2
File: en_windows_10_enterprise_x86_dvd_6851156.iso
CRC-32: e8a9bf6d
MD4: 8345a846e74b6b46bee0fdaa04dd20d1
MD5: 68162933e551e55779504dacdfb0c5ae
SHA-1: e7138032986bfcfa0e5f1a8e41e2e9fd1ec94268
File: en_windows_10_enterprise_x64_dvd_6851151.iso
CRC-32: c3d5b0ca
MD4: 6377d92db21bf8c9f5e1c437811787a3
MD5: a67722adfaf209c72eacb3ab910ee65e
SHA-1: 30ad1cdf5d0670f12788005131e24862f6ab8aab
Cauze i have make big mystake with my previous upload this time i fixed enterprise.
- Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
- RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
- Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
- Graphics card: Microsoft DirectX 9 graphics device with WDDM 1.0 driver.
- Display: 800x600
yentran85
Ðề: [MULTI] Microsoft Windows 10 6in1 AIO English Full Updated 08.05.2015 Pre-Activated
Xin cho mình hỏi đây cũng là một cách crack sẵn phải không ạ hay là bản quyền ạ? Mình không rành về máy tính lắm nên không biết.
auvie
active săn luôn nhe bạn....bạn dùng như bản quyền chính thức vậy...update thổi máy...
