Lang thang trên mạng , thấy con này :
Popcorn Hour A-500 PRO specifications:
SoC – Sigma Designs SMP8758 ARM Cortex A9 processor @ 1.2 GHz with ARM Mali-400 GPU and VXP image processing engine
System Memory – 2048 MB DDR3
Storage – NAND Flash for firmware, 1x SD card reader, internal SATA bay
Video Output – HDMI up to 3840×2160 @ 30 Hz
Audio Output
Digital – HDMI, optical S/PDIF, and coaxial S/PDIF
Analog – Stereo RCA jacks, XLR connectors, and headphones
Audio DAC – ESS SABRE Audio DAC ES9018K2M
Video Containers – M1V, M2V, M4V, M2P, MPG,VOB TS, TP, TRP, M2T, M@TS, MTS, AVI, ASF, WMV, MKV, 3DMKV, MOV, MP4, RMP4
Video Codecs – HEVC, VP9, H.264, MPEG-4.2-ASP, SMPTE 421M, AVS, H.261
Audio
Formats – AAC, M4A, MPEG audio, WAV, WMA, FLAC, OGG, APE, TTA, DSD
Decoders – DTS, WMA, WMA Pro, MPEG-1 (Layer 1,2,3), MPEG-4 AAC-LC, MPEG-4 HE-AAC, LPCM, FLAC, Vorbix
Pass-through – DTS, DTS-HD HR, DTS-HD MA
Connectivity – Gigabit Ethernet
USB – 2x USB 2.0 host, 1x USB 3.0 slave
Misc – IR receiver, IR extender port, dual boot switch, power and network LEDs
Power Supply – N/A
Dimensions – 210 x 188 x 57 mm (Aluminum enclosure)
Weight – N/A
This fanless 4K media player will ship with a remote control, two AAA batteries, an HDMI cable, a USB 3.0 slave cable, ab AC power adapter, a Quick Start Guide, and a Warrranty card. The device can run Linux or Android, and both operating systems appear to be pre-installed, as there’s a dual boot switch on the device. The guts of the machine are actually pretty similar to Popcorn Hour VTEN, which I reviewed a few months ago and found quite good at what it’s supposed to do play videos, including 4K videos using 10-bit HEVC codec, and handle HDMI audio pass-through for all HD audio codec I tested. Popcorn Hour A500 PRO is a different beast however with double the RAM, a SATA bay, higher-end audio codec and connectors, and support for both Linux and Android, while VTEN was only running Linux at the time.
Giao diên mnj như mấy con trước :
Read more: http://www.cnx-software.com/2015/08...signs-smp5878-soc-crowdfunding/#ixzz3jnTruiM4
Hình như dự kiến 399usd, ... chờ tiếp ...
Audio Output
Audio
Power Supply – N/A
Weight – N/A
