1 Link Windows 8.1 AIO 24in1 with Update x64 v2 en-US Jun2014 Actived,24 bản Windows 8.1 trong 1 kèm Update
murphy78 presents Windows 8.1 AIO 24in1 x64 with Update v2 Jun2014
This image contains Windows Updates current to Jun10-2014
No Windows 8.1 Settings were harmed in the making of this ISO.
No Programs are added to Windows.
No Registry Settings were modified.
No Unattended Settings were added to the ISO.
64-bit RTM Sources:
en_windows_8.1_with_update_x64_dvd_4065090.iso
en_windows_8.1_n_with_update_x64_dvd_4065114.iso
en_windows_8.1_professional_vl_with_update_x64_dvd _4065194.iso
en_windows_8.1_professional_n_vl_with_update_x64_d vd_4065208.iso
en_windows_8.1_enterprise_with_update_x64_dvd_4065 178.iso
en_windows_8.1_enterprise_n_with_update_x64_dvd_40 65163.iso
en_windows_embedded_8.1_industry_pro_with_update_x 64_dvd_4065122.iso
en_windows_embedded_8.1_industry_enterprise_with_u pdate_x64_dvd_4065141.iso
9600.17050.winblue_refresh.140317-1640_x64fre_client_coresinglelanguage_en-us-ir3_csla_x64frer_en-us_esd.esd
These RTM Sources are the final Build 9600.17031
Installation Indexes:Đã kèm các bản sau trong file.
Windows 8.1 (Core) / KMS-Activated
Windows 8.1 (Core) N / KMS-Activated
Windows 8.1 (Core) Single Language / KMS-Activated
Windows 8.1 Pro / KMS-Activated
Windows 8.1 Pro N / KMS-Activated
Windows 8.1 Pro VL / KMS-Activated
Windows 8.1 Pro N VL / KMS-Activated
Windows 8.1 Pro WMC / KMS-Activated
Windows 8.1 Enterprise / KMS-Activated
Windows 8.1 Enterprise N / KMS-Activated
Windows Embedded 8.1 Industry Pro / KMS-Activated
Windows Embedded 8.1 Industry Enterprise / KMS-Activated
Release File: Win81AIO-Update-24in1-x64-en-US-v2-Jun2014.iso
Language: en-US (English - United States)
Added updates:
KB2899189, KB2920189, KB2931366, KB2939153, KB2939576, KB2950153,
KB2954879-v2, KB2956575, KB2957189, KB2957689, KB2958262, KB2962140,
KB2964718, KB2964736, KB2965142, KB2965699, KB2965788, KB2966072,
KB2966804, KB2969817, KB2934018, KB2959977, KB2934520, KB2955164,
KB2965500, KB2962409, KB2969339, KB2973448
Embedded-Only update:
KB2932074
Tools used:
dism for Image Exports
oscdimg for ISO mastering
Microsoft Diagnostics and Recovery Toolset (DaRT) 8.1
Added Info folder to Windows Setup dir to annoy credit theives
murphy78 diskpart/apply script v1.2.4
Features:
-NetFx 4.5.2
-Windows 8.1 with Update MSDN/ESD download
-Highly compressed ESD format.
-DaRT 8.1 integrated into boot.wim recovery options.
-Diskpart/apply script with recovery image and multi-boot support v1.2.4*
*To access, press shift-f10 during boot-setup and type: MENU
Important Notes:
-EI.CFG is present. *You will need to extract the iso and delete this
file to upgrade from a previous version of Windows*. You will also want to
allow setup to download updates during upgrade process.
Changes:
**v2 Change**
-Re-examined winre optional dart stuff and I've restored the stock
Winre.wim from each index so that none of the file attributes or
ACL permissions are modified in any way. Perhaps this will help
solve the rare boot-install error.
-Note that this boot install error is very rare and only seems to occur
in x64 versions. You might want to follow the x64 comments and see if
people report that it fixes their issues.
-If the x64 people say it works better, you might want to use it anyway
if you don't mind re-downloading.
-There is a weird connection with dism and file attributes and properties.
It's hard to explain, but during my early testing with winre stuff, I
noticed that improper file attributes would make a mount folder unable to
unmount. It could be as simple as not deleting files that were previously
differently attributed, or it could be indicative of a larger problem.
Credits:
CODYQX4 - AutoKMS Activator from MTK 2.5.1
murphy78 - Testing, ISO design, Integration, Diskpart/Apply script
Enjoy Pirates,
murphy78-TPB/MDL
http://up.4share.vn/d/2310171a111b1014
