tonytruong
Ðề: “Chào Ngày Mới" của HD Sài Gòn 2014
Lên hàng như đã hứa với anh em, nhẹ nhàng nhưng chất lượng cao nha A/e nhanh tay nào
LICHTMOND III 3D (2014) [1080p.H-OU.DTS-HD.MA.7.1.AC3.BluRay.x264-Sonda] [Demo] [AT-TEAM]
Mã:Description Tytul: Lichtmond 3 Days of Eternity Wydany: 2014 Gatunek: Demo Rezyseria: Giorgio Koppehele, Martin Koppehele Obsada: Midge Ure,Alan Parsons,Sky du Mont,Thomas W. Kraupa Opis: Kolejna odslona filmu LICHTMOND III w 3D. 1.Nightflight to Chronos Part 1 2.Nightflight to Chronos Part 2 3.Feel the Spirit 4.Wheel of Time 5.Catching Rainbows 6.Empires of the Past (feat. Sky Du Mont) 7.Days of Eternity (feat. I Muvrini) 8.Space and Beyond 9.Endless Moments (feat. Midge Ure) General Format : Matroska Format version : Version 2 File size : 9.51 GiB Duration : 50mn 2s Overall bit rate mode : Variable Overall bit rate : 27.2 Mbps Movie name : LICHTMOND III 3D.Bluray3D [Rip by Sonda AT-Team] Encoded date : UTC 2014-10-26 12:51:38 Writing application : mkvmerge v5.7.0 ('The Whirlwind') built on Jul 8 2012 20:08:51 Writing library : libebml v1.2.3 + libmatroska v1.3.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : [email protected] Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : V_MPEG4/ISO/AVC Duration : 50mn 2s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 1.78:1 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Title : Rip by Sonda Writing library : x264 core Default : Yes Forced : No Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio #1 ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 50mn 2s Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 229 MiB (2%) Title : AC3 5.1 Language : English Default : Yes Forced : Yes Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 50mn 2s Bit rate mode : Variable Bit rate : 4777 / 1 509 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Title : DTS-HD MA 5.1 Original Language : English Default : No Forced : No Audio #3 ID : 4 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 50mn 2s Bit rate mode : Variable Bit rate : 6555 / 1 509 Kbps Channel(s) : 8 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Title : DTS-HD MA 7.1 Original Language : German Default : No Forced : No Menu 00:00:00.000 : en:(01)00:00:00:000 00:01:38.932 : en:(02)00:01:38:932 00:03:49.646 : en:(03)00:03:49:646 00:10:25.041 : en:(04)00:10:25:041 00:15:42.775 : en:(05)00:15:42:775 00:21:57.649 : en:(06)00:21:57:649 00:28:51.229 : en:(07)00:28:51:229 00:34:59.305 : en:(08)00:34:59:305 00:40:17.039 : en:(09)00:40:17:039 00:46:34.166 : en:(10)00:46:34:166 00:50:02.249 : en:(11)00:50:02:249
