nguyenduy_89
Office Tab Enterprise Edition 9.70 Multilingual - Tab của phần mềm office
ExtendOffice.com company introduced a new version of its small but very useful utility called Office Tab 7 The principle of Office Tab is relatively simple, but no less effective the windows open documents are displayed in the interface of Office applications as tabs open pages in modern browsers.
Utility Office Tab eliminates one of the few shortcomings of the package Microsoft Office - the lack of an intuitive tool for working with large numbers of public documents. Although the company Opera Software has implemented a mechanism of tabs in my browser for quite some time, Microsoft has implemented a similar approach only in the browser Internet Explorer, but not in other applications. Partly a problem dealing with multiple open documents now decides to improved user interface of Windows 7, but the utility Office Tab fixes mentioned drawback in the root each application of a series of Office (Word, Excel and PowerPoint) gets its own set of tabs for all open documents.
Features:
Abundant positions and flexibility to show the Tab: Above Workspace, Below Workspace, Left Workspace or Right Workspace.
Office Tab allows you to customize the tab color.
Available to rename the saved Tab in the right click Tab pop-up menu.
Supply an independent Office Tab Center for configuring all the setting in Office Tab 4.00.
More than 11 Tab styles can be chose.
Office Tab can be hidden while there is one Tab.
You can drag the Tab from one Tab position to another Tab position in Microsoft Word and Microsoft Excel (except in Microsoft PowerPoint).
Right clicks the Tabs, there will pop-up a menu, which includes Close function, Rename function and so on.
Office Tab can be easily enabled or disabled.
Customize Tabs layout. Office Tab arranges 3 layouts for choosing AutoSize, SizeToFit and Fixed.
Customize the max width of Tabs for AutoSize and SizeToFit layout, and fixed width of Tabs for fixed layout.
You can lock the Tab in Microsoft Word and Microsoft Excel, but not in the Microsoft PowerPoint. The locked document Tabs or workbook Tabs cannot be saved or closed.
When the documents or workbooks have been modified, Office Tab will mark these modified documents or workbooks with an asterisk in their names to indicate the modified documents or workbooks except in Microsoft PowerPoint.
Close Tabs by clicking Middle Mouse Button or Double click Left Mouse Button on the Tab; to build new Tab just need to double click Left Mouse Button on the blank area of Tab bar.
Office Tab provides plenty of shortcuts helping you work with efficiency. Press in+Q to hide display the Tabs bar, press Ctrl+Tab to quickly switch between Tabs or press Alt+N to quickly select the specific Tabs. N stands for the Order Numbers of the Tabs from left to right on the Tab bar, the N just can be the number 1 to 9 and include both 1 and 9)For example, there are five Tabs on the Tabs bar. You can just press Alt+5 to select the fifth Tab from the left on the Tab bar. Office Tab supports customization of the hide display Tabs bar shortcut and switch Tabs shortcut.
Word Documents Tabs supports to open current document in new windows, and Excel Workbooks Tabs supports to open current workbook in new Windows.
Operating System: Windows 8/7/Vista/2003/XP/2000
[center] tenlua.vn : [url=http://tenlua.vn/officetabenterprise9-70-rar-0d37e62de10b6f0e/#download0d37e62de10b6f0e]Tên lửa | OfficeTabEnterprise_9.70.rar[/url]
Fshare.vn : [url=http://www.fshare.vn/file/TTHVCMV3YT]Fshare - Dich vu chia se, luu tru du lieu mien phi tot nhat[/url] [/center]
