Tình trạng
Không mở trả lời sau này.
genzo1984
CHÀO BUỔI SÁNG CẢ NHÀ, CHÚC CẢ NHÀ MỘT NGÀY VUI VẺ VÀ THÀNH CÔNG$-)
hbinhlove2003
Chào cả nhà, em mới leech DVD này về để test dàn 5.1 nghe phê lắm, từ chuẩn DTS đến DD5.1
The Ultimate Surround 5.1DD/DTS Test DVD (R.K. Edition)
Description :
This DVD is intended to compare the two DVD surrounds formats 5.1DD (448kbps) and DTS (1536kbps/768kbps).
Furthermore this Surround Test DVD can be used to test your A/V-Receiver (5.1DD/DTS decoder) capabilities because it includes LPCM tracks as reference.
Also you can just enjoy the surround because it is 100% mixed in real discreet surround.
A very fine DVD to demo your high-end A/V-Receiver ;)
DVD Info (Audio Only) :
Source : Ambra - Prism of Life - DVD9
Video : NTSC 16/9 (150kbps, still pictures)
Audio : DTS (1536kbps), 2x DTS (768kbps), 2x 5.1DD (448kbps) en 3x 2.0DD (192kbps)
Tracks : 15 tracks, 1h09m
Menu : Yes, Main and Settings (8x Audio selection)
Technical Info Tracks 1 to 8 :
Track 1 :
Original 5.1 DTS track from the Ambra DVD in full bitrate (1536kbps).
Track 2 :
Converted DTS (768kbps) - DTS HD Encoder.
Track 3 :
Converted 5.1DD (448kbps) - Aften 4.1 Encoder.
Track 4 :
Original LPCM (stereo) track from the Ambra DVD
Track 5 :
LPCM from 5.0 DD (448kbps) Aften 4.1 Encoder (stereo only)
Track 6 :
Track 7 :
5.0 DTS (768kbps) (stereo only)
Track 8
2.0 DD (192kbps)
Note : For the necessary decoding of the DTS and 5.1DD (AC3) foobar2000 is being used.
Testing Surround 5.1DD&DTS :
The surround tracks 2 to 3 are both converted using the same source (track 1).
They should sound (almost) equally.
The reference DTS (track 1) might sound slightly clearer, however this is according to me marginal.
If clear differences are heart between DTS and 5.1DD continue comparing Track 4 to 7.
Checking the stereo tracks :
The reason for checking in stereo is to exclude faults from DTS or AC3 decoders.
LPCM is a very old and simple codec which will in all cases be converted perfectly by any A/V-Receiver and therefore be seen as a reference.
Compare Track 4 with 5 and you will notice that there is almost no differences.
Any differences heart is caused by the codec Dolby Digital and its compression.
Compare Track 4 with 6.
If you hear more differences between 4 and 6 (compared to 4 and 5) this is caused by the Dolby Digital decoder of your A/V-Receiver.
Compare Track 4 with 7 to see if your DTS decodes perfectly.
It should sound almost identical to the LPCM track.
Please note that the stereo tracks (DTS/DD) are in fact encoded in 5.0 surround mode and only L and R are modulated.
I did not included a LPCM track converted back from the DTS track.
The differences would (theoretically) be less than the LPCM conversion of the 5.1DD track.
Callibration :
The DVD can also be used to callibrate your receiver levels for different modes.
Track 4 to 8 are Resp. LPCM, DTS, Surround DD and Stereo DD.
These tracks have all the same modulation (within 0.1dB).
Modern A/V-Receivers have the abbility to adjust levels for these different modes.
Use the LPCM as reference and adjust the others to the same level.
Please take care that 2.0DD callibrated in stereo and not Dolby Prologic.
Before callibrating the different modes it is neccesary to callibrate the levels of all your speakers.
Most modern A/V-Receivers have internal test tones (noise) which can be used to callibrate the 5 (or more) channels to the same level.
I hope you will all ENJOY this "Ultimate Surround 5.1DD/DTS Test DVD (R.K. Edition)"
Dùng phần mềm MegaDownloader down free cho lẹ nha các bác
https://mega.co.nz/#!B5x3VBSb!ezu5en2SNwZE5Ffsf_z9wKSx3ZAKcij8IZczvLp9sD4
longdnl
Cùng chiêm ngưỡng những hình ảnh tuyệt đẹp của nhân vật Caitlyn trong League of Legends.
Caitlyn là một nữ nhân vật có vẻ ngoài xinh đẹp và nóng bỏng, với món vũ khí chính là một khẩu súng. Bộ ảnh cosplay này được thực hiện bởi nữ coser có nickname YYunju đến từ Hàn Quốc.
ST.
tonytruong
Cám ơn em đã share link anh kéo về up lên Fshare chia sẻ cho anh em hén, Thanks em nhiều :)
maison67
Chào cả nhà buổi trưa!:) Nick meocon này là của thằng bán đầu HD ở Q. 4 hay sao đó các bác, hôm nọ nó chào hàng em đầu HD, lúc trước em chưa có. Nếu nó lơ tơ mơ, anh Trường trảm cho nó bay đầu luôn!:-bd
maison67
Cái này có phải down từng khúc, từng khúc rồi ráp lại phải hông bác Bình? Bác không gom lại thành 1 file cho AE down cho đỡ cực hơn!:-w
maison67
Loay hoay... mà hong có acc MegaDownloader đành pótay rồi, nhờ các bác trợ giúp để cho mình down được về xem! Thank's all!^:)^
maison67
Bác HeinekenOnly có PM, đọc tin hồi âm liền nhá, để mình CK tới bác liền!:)
hbinhlove2003
Các tính năng chính của chương trình:
  • Hỗ trợ download toàn diện tại mega như: download link dạng thư mục, hỗ trợ pause, resume, download thông qua proxy trung gian, giới hạn tốc độ tối đa, tự động import link từ clipboard, tự động tắt máy sau khi download xong,....
  • Hỗ trợ import trực tiếp file .elc.dlc để download (2 dạng file mã hóa link).
  • Không hao tốn tài nguyên hệ thống khi download.
  • Hỗ trợ streaming và quản lý thư viện link để xem phim online (mình sẽ giới thiệu chi tiết chức năng này ở topic khác).
  • Mã hóa liên kết của mega sang dạng thức mega://enc?xxxxx (không phải Meg.co.nz)
Hệ điều hành hỗ trợ:
  • Windows XP SP3 (đã cài đặt .NET 4.0 hoặc mới hơn)
  • Windows Vista (đã cài đặt .NET 4.0 hoặc mới hơn)
  • Windows 7 (đã cài đặt .NET 4.0 hoặc mới hơn)
  • Windows 8 (đã cài đặt .NET 4.0 hoặc mới hơn)
Giải thích một số tùy chọn chính của chương trình:
Vì giao diện chương trình khá trực quan và dễ dùng nên mình sẽ không hướng dẫn cách dùng nữa mà sẽ giải thích một số lựa chọn cơ bản của MegaDownloader (minh họa trên phiên bản mới nhất hiện tại, version BETA 0.81).
  • Download path: thư mục download mặc định.
  • Capture links from clipboard: tự động import link mega vào chương trình khi copy.
  • Start downloading when application starts: tự động download khi khởi động chương trình. Chức năng này dùng khi phiên download trước đó chưa hoàn tất và bạn cần phải tắt máy / chương trình trước đó.
  • Start with windows: tự động khởi động cùng hệ điều hành.
  • Automatic extraction: tùy chọn việc khả năng chiếm dụng tài nguyên hệ thống khi sử dụng chức năng tự động giải nén (có 2 mức là bình thường và thấp).
  • Limit connection to: giới hạn tốc độ download tối đa.
  • Number of parallel downloads: số file download đồng thời (mặc định là 3).
  • Number of connections per file: số kết nối cho 1 file (mặc định là 3).
tonytruong
Chính xác đó anh
Hôm bữa bị a cảnh cáo rồi đó , spam nữa a cứ chém thẳng tay .;))
Bởi vậy nó đâu dám vô đây Spam, hôm nọ trảm nó phát rồi, chỉ mong sao nó đừng có hành động đi lừa AE trên DĐ mình thôi, chứ có trảm nó ngàn đao cũng vậy à, đâu ăn nhằm gì đâu. :) ;))
Tình trạng
