Re: Ðề: Mua HD Player nào để xem phim 3D tốt nhất hiện nay ?
Mấy bác thủ cái này mình dang dùng thấy rât là ung ý. KDLINK720. giá cũng rất ok khoảng $150 dollars.
Introducing...
kdLinks HD720 is a high end digital media player with the most advanced Realtek 1186 3D chipset. It has built in WiFi (a/b/g/n). With 1186 chipset, it also supports 3D movie playback on 3D TV. Compare with HD700 model, HD720 has a built in 3.5" HDD Bay. It can also be used as USB 3.0 High Speed External Hard Drive Enclosure.
If you are looking for a media player which could play almost all formats (i.e. ISO, VOB, FLAC, CUE), this HD720 is your best choice.
Key Features
HD720 can truly decodes, playback and outputs High Definition 3D/2D 1080p videos through HDMI 1.4 interface. It can play almost any media files.
- Video Files - BDMV, BD-ISO, MKV, MOV, WMV, TS, M2TS, MTS, FLV, AVI, DVD-ISO, VOB, M2P, MP4, MPG, DAT, ASF, TP TRP, SWF
- Video Codecs - H.264/AVC, MPEG1/2/4, DivX/Xvid, VC-1, and RMVB
- Audio Formats - DTS/DTS-HD MA, Dolby AC3/True-HD, LPCM, ADPCM, FLAC, APE, LC-AAC, HE-AAC, MP3, OGG, WAM, WAV
- Image Formats - JPG, GIF, PNG, BMP, and TIF
- 2 USB, 1 SATA & LCD Front Panel
- Video Output: RCA, YPbPr and HDMI
- Support 2D/3D* (*Require 3D TV and Glasses)
What's Included:
- HD720 Player
- IR Remote
- 110-240V AC Adapter
- HDMI & USB 3.0 Cable
- User Manual
---------- Post added 27-11-2013 at 14:21 ----------
Best Media Player to Play All 2D/3D Media Files. It Supports Full 1080P, Plus it also supports Blu-Ray Navigation Menu (BD-1.0 and 2D movies only), Dolby TrueHD, DTS-HD
Realtek 1186 3D Chipset Brings a Faster Clock Speed, More RAM, HDMI 1.4 and Full 3D Support
Gigabit 1000Mbps Network & Built-In 802.11n Wi-Fi. No More Additional Cost, No More Compatibility Issues; Ready to Use Right Out Of Box
Front LCD Panel & Built In 3.5" SATA/SATA2 Hard Disk Drive Bay With Up To 3TB of Storage Space (HDD is not included). It Can Also Be Used as USB 3.0 High Speed External Hard Drive Enclosure
Support RCA, YPbPr and HDMI; Good For Any TV Set (CRT or LCD/LED); New Aluminum Housing Enables the Player Efficient in Dissipating Heat From The CPU.
