Nitro Pro Enterprise 8.5.3.14 Final - đọc và chỉnh sửa file PDF hiệu quả nhất
nguyenduy_89
Định dạng : ISO
Dung lượng : 95 MB
Thể loại : Phần mềm văn phòng
Nitro Pro 8 lets you quickly and easily create professional-quality PDF documents from any format or content type: paper scans, spreadsheets, presentations, reports, and more.
Creating PDF:
В· Create PDF and PDF/A documents from virtually any Windows file.
В· Convert and merge files into a single PDF document.
В· Convert entire collections of files to PDF in one batch.
В· Scan paper documents to PDF.
В· One-button PDF creation from Microsoft Word, Excel, and PowerPoint.
В· Create 'intelligent' PDF documents with bookmarks, links, metadata, and security from Microsoft Office programs.
Copying & Exporting PDF:
В· Export PDF for reuse in Microsoft Word, WordPerfect, OpenOffice and more.
В· Use different conversion modes to export files that look precisely like the original PDF and others that are easier to edit and repurpose.
В· Extract all text and images from PDF documents.
В· Batch convert PDF files to Word, RTF, and text formats.
В· Copy text while retaining formatting, including font, color, and size.
Editing PDF:
В· Insert and edit text, including font, size, color and more.
· Edit images — insert, resize, rotate, crop, flip, replace, arrange, delete, and extract.
· Edit image properties — brightness, contrast, color space, and resolution.
· Edit pages — insert, delete, rotate, crop, extract, and replace.
В· Split pages of PDF documents based on page groups, page ranges, and bookmark structure.
В· Add headers, footers, watermarks, and text to all pages in a document.
В· Add Bates numbering across a collection of PDF documents.
В· Add and edit bookmarks and links.
В· Auto-create bookmarks based on document text formatting and headings.
В· Auto-create links based on keywords and page numbers.
В· Optimize, shrink and repair PDF documents.
В· Edit document properties including metadata and initial view settings.
Optical Character Recognition (OCR):
В· Create PDF files from scanned paper documents, or existing image-based PDF files, perfect for publishing, editing, or archiving.
В· Create fully compliant PDF/A documents.
В· Create editable PDF files and customize documents using the Editable Text feature.
В· Create easily searchable, PDF/A compliant documents for archiving with 'Searchable Image' mode.
В· Flexible multi-language support.
Reviewing & Marking Up PDF:
В· Highlight text content with the Highlight, Underline, Cross Out and Replace Text tools.
В· Add Sticky Notes, Text Boxes, and Call Out annotations.
В· Add freehand drawings with the Pencil tool.
В· Add drawing shapes, including lines, arrows, rectangles, ovals, polygons and clouds.
В· Apply stamps to pages, choosing from standard built-in stamps or your own custom creations.
В· Attach documents and other files to your PDF pages.
В· Add explanatory text and other feedback to your markups.
В· Sort and manage comments.
В· Filter comments based on type, author, status, subject, and more.
В· Summarize comments for easy viewing alongside page content. View the summary as a PDF or print it for paper-based reviewing.
PDF Security:
В· Secure documents with passwords and certificates.
В· Encrypt with 40-bit, 128-bit, and 256-bit level security.
В· Apply restrictions on printing, copying, and altering PDF documents.
В· Create and apply re-usable security profiles.
В· Digitally sign and certify PDF files.
PDF Forms:
В· Fill in, save, print and submit forms.
В· Design forms.
В· Add, edit and run javascript.
Home Page - Create, Convert & Edit PDF Files | Nitro
Install Notes:
1] Install The App
2] Enter Serial
3] Enjoy This Release!!
[CENTER] [url=http://www.fshare.vn/file/TG7BKADKGT]Fshare - Dich vu chia se, luu tru du lieu mien phi tot nhat[/url]  [/CENTER]
Manuatu
Ðề: Nitro Pro Enterprise 8.5.3.14 Final - đọc và chỉnh sửa file PDF hiệu quả nhất
Trình đọc PDF tốt nhất!
NHVL
EM đang dùng cái này để chỉnh sửa mớ hợp đồng nè :))
Băng Rừng
Mới dùng cái này để lấy mấy cái hình trong file PDF ra, chất lượng cũng được, sử dụng được :D
ktsnhan
Nhờ bạn hướng dẫn active giúp nhé!
davidbeckham_nd
Re: Ðề: Nitro Pro Enterprise 8.5.3.14 Final - đọc và chỉnh sửa file PDF hiệu quả nhất
Bác tải keygen của bác băng rừng theo link Fshare - Dich vu chia se, luu tru du lieu mien phi tot nhat.
Tải về rùi thì làm như sau:
1. Cài đặt Nitro ( em dùng deamon tool để tạo ổ ảo và cài , em cài bản 32 bit)
2. Cài xong bật Nitro lên sẽ có yêu cầu Activate.
3. Bác chạy file keygen của bác băng rừng.
4. Nhập số Install number vào file keygen sau đó nhấn Generate, bác sẽ nhận được license numbers.
5. Copy lince number và paste vào file activation của nitro là xong.
Chúc bác thành công
ktsnhan
Thank Bác davidbeckham_nd mình đã active thành công!
dungsin_lqd
-sao khg active dc
xài thử thấy khá tốt thanks
