(Các bạn chịu khó đọc tiếng Anh, review tiếng Việt xin chờ em vài ngày
1. K007 HD Network Multi-Media Player
2. K008 HD Network Multi-Media Player
3. K009 HD Network Multi-Media Player
4. K100 HD Network Multi-Media Player
6. K300 HD Network Multi-Media Player
CPU: Sigma Design SMP8634B
EMS memory: 256Mbyte DDR RAM, 32Mbyte Flash ROM
Video Decode formats: H.264, avi, wmv, mpg, vob, mp4, asf, tp, trp, ts, ISO, mov, mkv
Audio decode formats:MP3, WMA, Ogg, PCM, M4A, FLAC, WAV
Photo Format: JPEG, Bitmap, GIF
File System Format: NTFS, FAT32, EXT3
Subtitle Format: SRT, SSA
I/O Ports:
- USB 2.0 Host ports (supporting playing the media files from external CD ROM/DVD ROM/Portable HDD/USB storage/WIFI card/DMB-TH)
- 10/100Mbps Lan port
- IDE interface
A/V Ports: HDMI 1.3 (digital video and audio signals)
- YPbPr
- Composite Video output
- Coaxial 5.1 digital audio output port
- Dolby5.1 Six audio outputs (Audio FR/FL, SR/SL, C, SW)
Human interface: Remote Control (standard configuration)
Language supported[FONT=ËÎÌå]£º[/FONT] English and Chinese, other languages can add on request.
Power Supply[FONT=ËÎÌå]£º[/FONT] AC 100V-220V/50Hz-60Hz DC 12V 4.16A
Spare parts: HDMI Cable, Optical SPDIF Cable, User Manual
CPU: Sigma Design SMP8634 C
EMS memory: 256Mbyte DDR RAM[FONT=ËÎÌå]£¬[/FONT]32Mbyte Flash ROM
Video Decode formats: H264 VC-1 MPEG2 WMV DIVX XVID
Audio Decode formats: Dolby AC3 LPCM AAC MP3
I/O Ports:
- High definition DVD HDD
- IDE interface
- YPbPr
- Optical SPDIF
Human interface[FONT=ËÎÌå]£º[/FONT] Remote Control (standard configuration)
Power Supply[FONT=ËÎÌå]£º[/FONT] AC 100V-240V/50Hz-60Hz DC 12V 4.16A
The Kaiboer K009 HD Player fully supports 1080p giving you a smooth distortion free HD display. The Kaiboer K009 is the perfect companion for your HD TV as well as any other TV that you might own. If the Kaiboer K009 is combined with a NAS network the K009 can stream video over the network, giving you a true video on demand feeling with all attached TV in your place. There is an easy to access Drive bay for adding a hard drive or changing the internal drive without the need for any tools. Multiple drives can be effortlessly swaped in and out as needed. There is both Passive and silent Active cooling systems in the Kaiboer K009 Player to keep the player cool even when an internal hard drive is installed.
CPU: SMP8635 Memory: 256MB DDR Flash: 32MB
Storage Devices: Hard Disk Interface: 3.5" SATA
File System: NTFS, EXT3, FAT32 (NTFS, EXT3 is recommended, as FAT32 support file size maximum 4GB)
Subtitles: PGS(Original Blue-ray Subtitles), SSA, SRT
I/O Interface:
- USB 2.0 Host x 2 (used to connect to external CD or DVD ROMs/Mobile HDD/U disk and play stored Media files.
USB 2.0 Slave Device (used to connect to PC. Faster for file transfers to when using with internal drive.)
10/100Mbps LAN (used to play videos in network or VOD)
A/V Ports
- HDMI1.3 (with embedded digital AV signals)
VGA (YpbPr/RGBHV)
S-Video (Output standards definition PAL/NTSC analog video signal)
Composite Video: output PAL/NTSC analog video
Coaxial SPDIF: output 5.1channels digital audio
Optical SPDIF: output 5.1channels digital audio
Analog stereo audio (Audio R/L)£º 24bit/192khz Sampling Rate DAC£¬support Dolby ProLogic and ProLogic II
HD Output
- 480i: 720x480 Interlace Scan£»
480p: 720x480 Progressive Scan£»
720p: 1280x720 Progressive Scan£»
1080i: 1920x1080 Interlace Scan£»
1080p: 1920x1080 Progressive Scan.
Video Out
- NTSC (480i / 480p)
PAL (576i / 576p)
LCD HDTV (720p/1080i/1080p)
Plasma TV (1366x768, 1280x768)
Projectors
- Analog ¨C Component (YPbPr), VGA (RGB+HV), S-Video, Composite Video
Digital - HDMI, DVI
Digital Media formats supported
Video Formats:
HD Video
- MPEG2-HD: .mpg, .tp, .ts, .avi, .mkv
WMV-HD/VC-1: .evo,.wmv, ts, .avi, .mkv
H.264(Mpeg4-AVC): .m2ts,.mov,.mp4, .ts, .avi, .mkv
Mpeg4(DivX-HD, Xvid-HD): .avi, .mkv
Standard Definition
- MPEG-1/2/4: .mpg, .mpeg, .mp4, .m4p, .m2t, .m2p,.m1v, .m2v, .m4v, .trp, .dat
MPEG2: DVD: .iso, .ifo, .vob
MPEG4: DivXTM & XviD: .avi, .mkv
WMV: .wmv, .asf
Audio
- WAV
MP3/MP2/MPA
AAC (Advanced Audio Coding)
WMA
OGG
RPCM
Photos
- JPG/BMP/GIF/PNG
5. K200 HD Network Multi-Media Player
Details: The Kaiboer K100 HD 1080P Player continues along the tradition and quality standards that we use for all our players. Cleverly engineered into a small foot print with all the advance hardware that you expect from Kaiboer, with a sleek outside appearance. The integration of many digital technologies into a single player include; streaming internet broadcast, download using BT, read from many different sources, network, USB stick, external USB or eSATA hard disk makes this player the perfect addition to your home theater.
Front View of the K100 Muliti Media HD Player (White). The K100 comes in two colours, white and black.
Specifications:CPU: Sigma Design SMP8635 c
Cooling: Active cooling using a hi quality silent fan.
Video decode formats: H.264, VC1, MKV, MPEG-1, MPEG-2, MPEG-4, DivX, XVID, MOV, AVI, ISO
Audio decode formats: Flac, MPEG Audo layer 1&2, mp3, OGG, AC3, AAC, WMA, WMA RPO, DD5.1, DTS original data output
Photo Format: JPEG, Bitmap, GIF, animated GIF and PNG
File System Format: NTFS, FAT32 , EXT3
I/O Ports:- 2x USB 2.0 Host ports (supporting playing the media files from external CD ROM/DVD ROM/Portable HDD/USB storage/WIFI card
- 1x USB 2.0 Slave device port to connect PC.
- 1x 10/100Mbps auto Ethernet port: for streaming video files.
- 1x SATA interface on the right side.
- YPbPr
- Optical SPDIF
Language supported: Over 15 international languages: English, French, Italian etc...
Power Supply: AC 100V-220V/50Hz-60Hz DC 12V 3A
Spare parts: HDMI Cable, Optical SPDIF Cable, SATA cable, remote control, power supply, power plug, User Manual.
Dimension: 16.5cm x 13cm x 5cm
Engineered with elegance and convenience in mind.......
Back View of the K100.
Front view of the K100 in black.
Details:
Here comes Kaiboer new NMT K200 HD player in golden, black and silver colors. There is an easy to access Drive bay for adding a hard drive or changing the internal drive without the need for any tools. Multiple drives can be effortlessly swaped in and out as needed.
Specifications:
CPU: Sigma Design SMP8635C
Cooling: Active cooling using a high quality silent fan.
Audio decode formats: Flac, MPEG Audo layer 1&2, mp3, OGG, AC3, AAC;WMA, WMA RPO, DD5.1, DTS original data output
Photo Format: JPEG, Bitmap, GIF, GIF and PNG
Subtitle Format: SRT, SMI, SUB, SSA
I/O Ports:
- 2x USB 2.0 Host ports (supporting playing the media files from external CD ROM/DVD ROM/Portable HDD/USB storage/WIFI)
- YPbPr
- Optical SPDIF
Language supported: English, Chinese, English, Chinese, German, French, Italian, Czech, Swedish, Spanish, Polish, Portuguese, Bulgarian, Norwegian, Hungarian, Slovenian, Greek, Russian, Dutch.
Power Supply: AC 100V-220V/50Hz-60Hz DC 12V 4.16A
Spare parts: HDMI Cable, Optical SPDIF Cable, Power Plug, User Manual
Package:
Details:
K300 Multi Media HD player brings you to explore a new stunning high definition world.
What's the most attractive features of K300?1. The total refurbished Aluminum case, colorful VFD screen to show basic playing information.2. used the latest Pioneer DVD-ROM, could support RBD, TBD, D9 discs.3. DTS decoding directly by software.4. Perfectly support Full HD1080P, DTSHD, TrueHD, LPCM, strong and original 7.1 audio output.5. Support original Blu-ray subtitles.6. No sew playing, play movies section by section smoothly.7. Support 99% HD video files.8. Be powered on/off by remote control.9. Easy access of HDD bay, to install the HDD in 3 seconds.![]()
CPU: SMP8635 Memory: 256MB DDR Flash: 32MB DVD-ROM: Pioneer
File System: NTFS, EXT3, FAT32 (NTFS, EXT3 is recommended, as FAT32 support file size maximum 4GB)Subtitles: PGS(Original Blue-ray Subtitles), SSA, SRT[FONT=ËÎÌå]
I/O Interface:[/FONT]USB 2.0 Host x 2 (used to connect to external CD or DVD ROMs/Mobile HDD/U disk and play stored Media files.
A/V PortsHDMI1.3 (with embedded digital AV signals)
VGA (YpbPr/RGBHV)
Analog stereo audio (Audio R/L)[FONT=ËÎÌå]£º[/FONT] 24bit/192khz Sampling Rate DAC[FONT=ËÎÌå]£¬[/FONT]support Dolby ProLogic and ProLogic II
HD Output480i: 720x480 Interlace Scan[FONT=ËÎÌå]£»[/FONT]
480p: 720x480 Progressive Scan[FONT=ËÎÌå]£»[/FONT]
720p: 1280x720 Progressive Scan[FONT=ËÎÌå]£»[/FONT]
1080i: 1920x1080 Interlace Scan[FONT=ËÎÌå]£»[/FONT]
Video OutNTSC (480i / 480p)
PAL (576i / 576p)
ProjectorsAnalog ¨C Component (YPbPr), VGA (RGB+HV), S-Video, Composite Video
Digital - HDMI, DVI
Video Formats:
HD VideoMPEG2-HD: .mpg, .tp, .ts, .avi, .mkv
Standard DefinitionMPEG-1/2/4: .mpg, .mpeg, .mp4, .m4p, .m2t, .m2p,.m1v, .m2v, .m4v, .trp, .dat
WMV: .wmv, .asf
AudioWAV
MP3/MP2/MPA
WMA
OGG
RPCMJPG/BMP/GIF/PNG
Photos
