[Xtreamer] Firmware mới 2.2 ngày 10.02.2010
dnghi
Có gì mới?
1. Blu-ray simple navigation.
a. Chapter navigation.(GOTO or Next button)
b. Audio navigation(AUDIO button)
c. Subtitle navigation(SUBTITLE button)
2. Ken Burns slideshow effect
a. During Photo playback.
b. Setup->Playback-Ken burns Slideshow Effect.
3. Hue & Saturation
a. Setup->A/V->Hue, Saturation.
4. Multi Audio output.(HDMI only)
a. Output AAC/FLAC/OGG/WAV 5.1 PCM
b. Setup->A/V->Digital output.
5. Wireless network
a. Static IP
b. WPS
6. DVD/Blu-ray folder auto play.
a. If folder is DVD/Blu-ray folder structure, Appear select window of “Browser folder and auto playback”
7. New RSS video (HD) sites added in Internet menu.
8. Change custom GUI image.
a. Web page->Setup->TV skin.
b. Support 16bits BMP(656 format)
9. Custom RSS(Personal) option in “Internet” menu to use user’s customized script from internal HDD.
Ngon lành hơn:
10. “Return” button acts as stop button, during video playback
11. Wireless Network performance.
12. eTrayz mount option from UDP to TCP
a. Media Library -> eTray.
13. Internet sites support H.264(mp4) streaming.
14. Internet video playback.
a. Default playback resolution from 320x240 to full screen
b. Fast forward 1.0x->0.5x->0.8x->1.2x->1.5x->2.0x
15. Photo display quality.
16. Recognize ext3 file system in internet HDD.
17. USB HDD detection much faster.
18. Web GUI downloading works stable.
19. Xtreamer Restart from Web GUI
a. Setup->NAS Mode->Restart
20. added fast forward speed 1.1x during Video playback.
21. Change volume window position from bottom to top.
Sửa lỗi:
22. Official DVD can’t playback used by GL811 chip DVD device.
23. MKV+DTS out of sync.
24. External USB HDD detect error.
a. Samsung S1 mini (1.8inch external USB storage)
25. If TS file has internal subtitle, can’t display subtitle.
26. Subtitle visible when screen saver is on.
Tải và hướng dẫn:
Download it here:
http://gator884.hostgator.com/~xtreamer/Xtreamer_2.2.zip
To upgrade the firmware from a 2** version please:
1. Download the file.
2. Save the file on your computer (any directory).
3. Copy your file to a USB memory stick and use the USB host port on your Xtreamer.
3. Turn on your Xtreamer and navigate to the SETTINGS menu of your Xtreamer.
4. Find and select the FIRMWARE UPGRADE option
5. Navigate to the USB memory attached to your Xtreamer containing the firmware update file.
PLEASE NOTE: We do not recommend to upgrade the firmware via your network shared folders, as a loss in connection to the network could cause a break in the firmware upgrade process.
7. Once you have located the file, highlight the file and press ENTER on your remote to begin the upgrade process.
8. The Xtreamer will reboot and the process will be done in matter of few minutes. Once done the Xtreamer will reboot itself.
9. After the process is finished, you may want to do a RESTORE DEFAULT in the SETTINGS menu.
** CAUTION: DO NOT POWER-OFF THE XTREAMER DURING THE FIRMWARE UPGRADE PROCESS **
duchuu
Ðề: Xtreamer FW2.2 New
E cài 2.2 vào không reboot được bác ơi, nó cứ chớp nháy liên tục. có bác nào bị giống e không
dnghi
Chưa rõ lắm vụ này, bạn nói rõ thêm xem sao?
Có phải bạn chưa mở tính năng Power Off không?
dnghi
Ðề: [Xtreamer] Firmware mới 2.2 ngày 10.02.2010
Mình chỉ mỗi chưa chạy lại xmp (xtreaner mod pack) để cài skin cho nó được thôi. Phần phụ đề chỉnh outline rất ấn tượng với 3 mức dày mỏng vừa khác nhau.
Phần tín hiệu của HDMI cũng rất ok, phần chuyển động slide show hình ảnh rất sống động, đa dạng...
tdhvn
Tôi đã thử OK với cái này:
lordknows
Tui mới upgrade lên 2.2, không bị vấn đề gì cả.
Một điểm chú ý với các bác, nên chọn USB dây ngắn, hoặc Flash USB, thay vì HDD USB.
Trong một số trường hợp, dây nguồn vào quá dài, điện không đủ và Xtreamer nó cũng không thể nhận được Source, nên không upgrade thành công.
Nhân tiện, đúng là 2.2 chạy nhanh hơn, GUI nhìn rõ ràng hơn và nhận Storage nhanh hơn.
Đang chờ đợi .APE support :(.
dophubao
Các pác xài xtreamer giúp em với
em có con xtreamer + Xtrayz, nhưng không biết làm thế nào để connect 2 thằng này trực tiếp với nhau cả, giờ em đang connect bằng cách phải thông qua mạng LAN
Ai biết chỉ giúp em với
duchuu
đã up lại bằng USB FLASH ok, thanks
tdhvn
Bác connect 2 thằng đó với nhau qua LAN là đúng kiểu rồi đấy.
alpha191119
firmware 2.2 sao nó o đọc được sub trong ( như sub tiếng anh của bluray phim chẳng hạn) mặc dù set sub là default , hay là bắt buộc phải cài user font mới được ?? có bác nào thử chưa ?
dnghi
Trường hợp này mình đoán à do bạn đang xài font phụ đề chọn Manual đúng không?
Nếu bác nào không đọc được các phụ đề gắn trong, phụ đề tiếng Hoa, Anh theo film...thì hãy tắt phần chọn font phụ đề Manual đi, sẽ hiện lên ngay í mà!:-j
Chúc vui xuân bên HD thật êm xuôi!
Dnghi
please_helpme
Em có Test mấy Film BluRay
chạy trên A.C.Ryan & WD Live thì k có tiếng (Unknow Audio Format gì đó)
nhưng Xtreamer Firmware 2.2 thì OK & có cả Sub Viet
Xtreamer hơi bị nhiễu (Noise/Grain)
alpha191119
Dnghi
mình không để ở chế độ manual bác ơi ,sub default là on , loay hoay mải vẩn không làn sao hiển thị được sub cả , đành phải chuyển về firmware 2.1.1 để xem tiếp, chưa biết cách nào để khắc phục cả
alpha191119
sẳn đây nhờ bác dnghi luôn , xtreamer hình như không hổ trợ file .EVO của HDDVD , và dạng âm thanh Dolby Digital Plus của HDDVD , phải không bác ? liệu sắp tới firmware mới có cập nhật cái này không , vì có 1 số phim HDDVD dạng này mà o xem được nên mình thấy tiếc tiếc
tdhvn
Cho đến nay thì vẫn chưa có em HD Player nào hỗ trợ file đó bác ạ.
Lưu Linh
Sẵn có con Xtreamer của người ta gửi, em down về test thử xem sao, thanks bác !
