dnghi
Có gì mới?
1. Blu-ray simple navigation.
a. Chapter navigation.(GOTO or Next button)
b. Audio navigation(AUDIO button)
c. Subtitle navigation(SUBTITLE button)
2. Ken Burns slideshow effect
a. During Photo playback.
b. Setup->Playback-Ken burns Slideshow Effect.
3. Hue & Saturation
a. Setup->A/V->Hue, Saturation.
4. Multi Audio output.(HDMI only)
a. Output AAC/FLAC/OGG/WAV 5.1 PCM
b. Setup->A/V->Digital output.
5. Wireless network
a. Static IP
b. WPS
6. DVD/Blu-ray folder auto play.
a. If folder is DVD/Blu-ray folder structure, Appear select window of “Browser folder and auto playback”
7. New RSS video (HD) sites added in Internet menu.
8. Change custom GUI image.
a. Web page->Setup->TV skin.
b. Support 16bits BMP(656 format)
9. Custom RSS(Personal) option in “Internet” menu to use user’s customized script from internal HDD.
Ngon lành hơn:
10. “Return” button acts as stop button, during video playback
11. Wireless Network performance.
12. eTrayz mount option from UDP to TCP
a. Media Library -> eTray.
13. Internet sites support H.264(mp4) streaming.
14. Internet video playback.
a. Default playback resolution from 320x240 to full screen
b. Fast forward 1.0x->0.5x->0.8x->1.2x->1.5x->2.0x
15. Photo display quality.
16. Recognize ext3 file system in internet HDD.
17. USB HDD detection much faster.
18. Web GUI downloading works stable.
19. Xtreamer Restart from Web GUI
a. Setup->NAS Mode->Restart
20. added fast forward speed 1.1x during Video playback.
21. Change volume window position from bottom to top.
Sửa lỗi:
22. Official DVD can’t playback used by GL811 chip DVD device.
23. MKV+DTS out of sync.
24. External USB HDD detect error.
a. Samsung S1 mini (1.8inch external USB storage)
25. If TS file has internal subtitle, can’t display subtitle.
26. Subtitle visible when screen saver is on.
Tải và hướng dẫn:
Download it here:
http://gator884.hostgator.com/~xtreamer/Xtreamer_2.2.zip
To upgrade the firmware from a 2** version please:
1. Download the file.
2. Save the file on your computer (any directory).
3. Copy your file to a USB memory stick and use the USB host port on your Xtreamer.
3. Turn on your Xtreamer and navigate to the SETTINGS menu of your Xtreamer.
4. Find and select the FIRMWARE UPGRADE option
5. Navigate to the USB memory attached to your Xtreamer containing the firmware update file.
PLEASE NOTE: We do not recommend to upgrade the firmware via your network shared folders, as a loss in connection to the network could cause a break in the firmware upgrade process.
7. Once you have located the file, highlight the file and press ENTER on your remote to begin the upgrade process.
8. The Xtreamer will reboot and the process will be done in matter of few minutes. Once done the Xtreamer will reboot itself.
9. After the process is finished, you may want to do a RESTORE DEFAULT in the SETTINGS menu.
** CAUTION: DO NOT POWER-OFF THE XTREAMER DURING THE FIRMWARE UPGRADE PROCESS **
3. Hue & Saturation
5. Wireless network
a. Static IP
b. WPS
Ngon lành hơn:
Sửa lỗi:
Tải và hướng dẫn:
Download it here:
