kyoshjro90
Mình mới lướt 1 vòng trên web thấy có tặng key free cho win8 pro do chính Microsoft tặng, có thể dùng để active được.
Add Windows 8 Pro Pack or Windows 8 Media Center Pack to your edition of Windows
Swipe in from the right edge of the screen, and then tap Search.
(If you're using a mouse, point to the upper-right corner of the screen, and then click Search.)
Enter add features in the search box, and then tap or click Settings .
Tap or click Add features to Windows 8 and then do one of the following:
If you need to purchase a product key, tap or click I want to buy a product key online.
You will be prompted through the steps to buy a product key from there and it will be entered for you.
If you already have a product key, tap or click I already have a product key.
Enter your product key and click Next.
Read the license terms, select the check box to accept the license terms, and then click Add features.
If you were running Windows 8, your PC will restart automatically and Windows 8 Pro With Media Center will be on it.
If you were running Windows 8 Pro, your PC will restart automatically and Windows Media Center will be available for use.
Bác nào bí quá không nhận được key thì xài đỡ key này nha
W2GMT-2TR2C-W8N3H-23PXJ-MR9WD
WCPVY-YV8NQ-MT7F9-2V9T2-D668D
CKXVJ-GF9HD-NDFXC-DKQ32-GQ4FQ
Download Win8
Key active
Download Win8
Link tải phim
Key active
Link tải phim
