[TViX HD M-6500A/7000A]:Firmware mới 1.5.11 Pre-release ngày 12.11.2009
hoangtuan_neu
FW này không có nhiều thay đổi nào đáng kể, chủ yếu là chau chuốt thêm phần giao diện sử dụng
[DOWNLOAD]http://demod.dvico.com/PreRelease/tvix_M-6500.7000_1.5.11.zip[/DOWNLOAD]
Changes from 1.5.10
1) Player
1. Better support for EXIF rotation information in Jpeg files
2. Change back to old icon size (200*200) for normal and Album Jacket
mode
(We referred to the 1.5.10 feedback, which all preferred 200x200
size rather than new 120x120 size. Video folder icon size will
remain as previous version 1.5.10 which is 138x186)
3. The play button is the default button on the synopsis page.
(remote controller focus will be on PLAY button not BACK button)
4. Now, the icon mode change with FUNCTION key on the remote works on
text mode folders. (It worked only when all the three mode was text
mode in 1.5.10)
5. More Video cover folders are added
If a name of folder, which on the root folder, is starts with one
of below words(case insensitive), it will shows Video cover art mode
instead a normal icon mode.
-"video", "movie", "dvd", "bluray", "blu-ray", "film",
"cinema", animation", "drama", "miniseries", "tv series",
"music video"
6. Rearrange the file list page for some severe over scan displays.
Depends on the display, there could be still be some hiding at the
edges.
Below is the explanation between new mode in comparison to old mode with ICON mode using FUNCTION Key
on the remote controller.
1. Video
Cover Art vs Text(with ICON mode turned on using FUNTION key on the remote controller, it refers to this mode with ‘Text’ mode below)
- Cover Art : * It shows cover art for all the folders under (“video”, “movie”, “dvd”, “bluray”, “blu-ray”, “film”, “cinema”, animation”, “drama”, “miniseries”, “tv series”, “music video”)
** It will show ‘Back’, ‘Preview’ ‘Play’ button when there is no sub folder in current folder.
- Text : * it shows Cover Art only the folders set to ICON mode using FUCTION Key on the remote controller
** It will not show ‘Back’, ‘Preview’, ‘Play’ button even though it will show cover art icon and synopsis (as background image)
Both mode will show 138x186 size icon.
2. Audio
Album Art : * It will show 200x200 Album art for all the folders under ‘Audio’, ‘Automp3’ and ‘Music’
** It will show files as file list rather than Album art icon for folders without any sub folders.
Text : * It will show 200x200 Album art only for the folders set to ICON mode using FUNCTION key on the remote controller
** It will show 200x200 ICON if the folder is set to ICON mode regardless of existence of sub folders.
3. Photo
Thumbnail mode : It will show jpeg files as 120x120 thumbnails for all the folders under ‘Photo’ or ‘Picture’
Text mode : It will show jpeg files as 120x120 thumbnails for only the folders set to ICON mode using FUNCTION key on the remote controller
Besides above there is no difference between Thumbnail mode and Text mode in Photo.
- Video folders : “video”, “movie”, “dvd”, “bluray”, “blu-ray”, “film”, “cinema”, animation”, “drama”,“miniseries”, “tv series”, “music video”
- Audio folders : ‘Audio’, ‘Automp3’ and ‘Music’
- Photo folders : ‘Photo’ or ‘Picture’
- You can set to ICON mode for any folder besides above folders using FUNCTIN key on the remote controller.
Then it will show folders as 200x200 icons.
- Of course, you will need to prepare folder.jpg file if you want your preferred ICON image appear as a folder icon.
2) For the DTV, (No change)
- There is no separate color space option for DTV. The color space on Video option will be used for DTV.
worldvision
Huyền Thoại
Ðề: [TViX HD M-6500A/7000A]:Firmware mới 1.5.11 Pre-release ngày 12.11.2009
Á á Hàng mới cứ tung ra liên tục !! phải thử liền thui !!coi có đẹp hơn không ??
GINZYGOODS
Vừa up thử lên với em hàng nội địa ngon lành cành đào không hề bị Boot Loading j cả, đợi patch cái tiếng Anh tiếng Việt nữa là song :-h
TVIX 6500/7000A/7010A vẫn là chuẩn nhất, lại hàng nội địa nữa thì càng đẹp >:) , DVICO luôn quan tâm chăm sóc cho dòng TVIX đẳng cấp này
Chipcon
Tối về up cái xem nào.
Hình như lại quay lại cỡ Cover lớn rồi, bản 1.5.10 cover nhỏ quá mà chạy có vẻ không ổn lắm.
Hi vọng quả .11 này ngon hơn
justbenice
nghe bác nói em lại thấy chán 6600N , chắc phải đổi qua cái 7010A wá.
tdhvn
Chắc sắp tới firmware cho TViX M-6600 cũng như vậy đấy bác ạ...
traigang92
Nói làm gì nhiều vì mọi người đều biết TViX HD M-6500A/7000A là hàng hiệu rồi.Để cạnh một cái khác và cungd trình chiếu 1 tác phẩm thì mới thấy TViX HD M-6500A/7000A nó vượt trội cả về hình ảnh lẫn âm thanh.
tdhvn
Bác nói chuẩn không cần chỉnh, Vote ++ :)
vuanhcop
DVICO còn luôn quan tâm đến khách hàng nữa chứ...Dùng mấy cái đầu HD của hãng khác...thấy lỗi ở firmware mà mãi chẳng thấy hãng sửa đổi, nâng cấp gì cả.
Chipcon
Bản 1.5.11 này ổn hơn bản 5.10, mình đã up và thấy lỗi bị reboot với một số file đã được fixed, Icon to hơn...
P/S: Hồi 6600 sắp ra, mình tưởng cái Hộp sữa của mình sắp bị mang ra ném lon, hóa ra gừng vẫn còn cay lắm :))
hoangtuan_neu
Bác cứ nghĩ thế làm tội nghiệp em nó :)) em nó có ko ra FW nữa thì cho đến thời điểm này vẫn thuộc hạng siêu cay :))
duonglv
Firmware phát triển liên tục cả năm rưỡi nay không ngon mới lạ, hehe, hy vọng mấy FW kế tiếp của em 66 cũng xem được poster như em 6500/7000 :x
HHN
Ôi sao mà FW ra nhanh vậy trời ???? lại up tiếp thôi :D
luatsu
Mình vừa update FW này. Xem được phụ đề tiếng Việt. Nhung khi xem phim ấn vào bookmark để lưu vị trí xem thì báo "unsupported". Có bác nào biết cách khắc phục không hay đây là lỗi. Nếu mình muốn quay lại bản FW chuẩn thì cài lại có được kg?
Cảm ơn trước.
tdhvn
Cảm ơn trước.
Do bác chưa biết cách dùng Bookmark thôi. Khi duyệt phim trên thư mục, chỉ cần nhấn Bookmark, thì nó sẽ hiện ra các phim mà đang xem dở trước đó (cho phép đến 8 phim). Chỉ việc chọn phim trong danh sách đó, rồi nhấn OK, nó sẽ tự nhảy đến vị trí đang xem dở.
Chipcon
Cảm ơn trước.
Bác không cần bấm để lưu BM, bác không xem nữa thì cứ Stop, nó sẽ tự lưu đoạn bác đang xem dở. Sau đó khi duyệt file thì bác bấm BM như bác tdhvn hướng dẫn, nó sẽ hiện cho bác các film mà nó đã lưu, bác chỉ việc chọn các film đang xem dở thôi.
traigang92
Từ khi up FW mới không xem ca nhạc.Bây giờ xem mới thấy nó không dọc được ca nhạc Thúy nga và asia khi những file có đuôi .iso. Vậy có phải do FW mới bản 1.5.11 không hả bác.Thanhks
tdhvn
Bác nói nghe lạ quá, tôi vẫn nghe DVD9 ISO TN ầm ầm...
dnthanh
Bác HoangTuan cho hỏi sao up fw mới lại không biết tìm kết nối USB và chuyển ổ đĩa ở đâu cả vậy?
