C:\Users\Admin\Documents\vlc-record-2012-02-18-21h52m57s-http___127.0.0.1_8902_tv.ts-.ts
General #62810
Complete name : C:\Users\Admin\Documents\vlc-record-2012-02-18-21h52m57s-http___127.0.0.1_8902_tv.ts-.ts
Format : MPEG-TS
File size : 1.85 MiB
Duration : 17s 501ms
Overall bit rate : 885 Kbps
Video #69
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : No
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=31
Codec ID : 27
Duration : 17s 200ms
Bit rate : 761 Kbps
Width : 800 pixels
Height : 600 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.063
Stream size : 1.56 MiB (84%)
Audio #68
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 3
Duration : 17s 544ms
Bit rate mode : Constant
Bit rate : 80.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -38ms
Stream size : 171 KiB (9%)
