Cho hỏi xem phim 3D trên TV 43D490 ở dạng nào?
trungtai113
Cho mình hỏi Tivi 43D490 xem phim 3D SBS 1080p được ko?hay chỉ xem được SBS 720p thôi?
Mình vừa dow phim hoạt hình Kungfu Panda 3D .mkv mà ko xem được?trên Tivi 43D490 đó các bác?
Thông tin:
Format : Matroska
Format version : Version 2
File size : 6.71 GiB
Duration : 1h 25mn
Overall bit rate : 11.2 Mbps
Encoded date : UTC 2011-09-01 14:39:38
Writing application : mkvmerge v4.9.1 ('Ich will') 编译于 Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 + libmatroska v1.1.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 25mn
Bit rate : 11.0 Mbps
Width : 2 560 pixels
Height : 720 pixels
Display aspect ratio : 3.556
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.199
Stream size : 6.43 GiB (96%)
Writing library : x264 core 115 r1995 c1e60b9
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 25mn
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 157 MiB (2%)
