Bino là phần mềm xem phim với các tính năng:
- Hỗ trợ xem phim stereoscopic 3D video với nhiều định dạng
- Hỗ trợ trình chiếu trên nhiều màn hình
- Đặc biệt: gần như là phần mềm xem 3d duy nhất trên Mac OS
- Lưu ý: Phần mềm chỉ hỗ trợ xem phim 3D, ko có chức năng chuyển đổi phim 2D thành 3D
Supported input layouts (modern formats can be autodetected):
Monoscopic (2D) video
Left and right view in separate video streams and/or files
Left and right view side by side (optionally with half width)
Left and right view on top of each other (optionally with half height)
Left and right view in alternating rows
To display a stereoscopic video, the left and right view have to be prepared in a special way so that the left eye sees the left view and the right eye sees the right view. Different display techniques use different approaches to achieve this separation of the two views.
Supported output techniques:
Anaglyph glasses (red/cyan, green/magenta, amber/blue). This works with every display.
Bino uses the high-quality Dubois method to produce anaglyph images. This gives far better results than the usual full-color and half-color methods.
Left and right view side by side (used by some 3D displays)
Left and right view on top of each other (used by some 3D displays)
Left and right view in alternating rows or columns (used by some 3D displays)
OpenGL quad-buffered stereo (only available with some graphics cards)
Bino currently works on GNU/Linux, FreeBSD, Mac OS X, and Windows. It uses the following libraries:
FFmpeg to decode video and audio files. FFmpeg version 0.7 or later is required.
LibASS to render subtitles.
OpenAL (on GNU/Linux: OpenAL Soft) for audio output.
OpenGL (with Glew) for video output. Hardware accelerated OpenGL 2.1 with framebuffer objects is required.
Note that proprietary drivers are not required! Recent Linux kernel + Mesa + X.org versions should work fine.
Qt for the user interface and video window.
Optionally Equalizer for multi-display support.
Bino is free software, licensed under the terms of the GNU GPL version 3 or later.
cách sử dụng cũng đơn giản, chỉ cần chọn đúng input theo source (phần lớn là Side-by-Side) và Output theo loại kính mình xài (2 màu hay trập, ...) là xem được
còn sub thì phần mềm chỉ mới hỗ trợ sub nhúng trong file mkv, chắc phải chờ cập nhật
theo cảm nhận riêng của mình thì phần mềm này xem phim trên mac mượt hơn, win, bác nào có máy test thêm cái
DOWLOAD
WINDOWS: http://www.3d-one.com/bino-1.2.0-w32.exe
MAC: Bino: free stereoscopic 3D video player (Mac OS X binaries) (nhớ chọn đúng bản Mac OS đang xài)
GNU/LINUX: Bino: free 3D video player - Download (cũng nhớ chọn đúng bản linux của mình)
