Mede8erViet
Ðề: Mede8er (MED200X; MED300X; MED400X Mini; MED500X ,MED500X Light; MED500X2)
Anh hucek ơi có firmware mới 1.5 của Mede8er MED300X rồi ạ, anh up lên thử nhé:
Bác này báo bệnh của 300x giống hệt của tôi hiện đang bị. Bác down lại FW mới rồi up xem có lỗi gì ko thì báo lại để tôi làm theo nhé ;![]()
New update for MED300X
Changelog V1.5
1) Fixed Alpha sorting on USB fat32 Drives
2) Changed screensaver image
3) Selection of Font A or B in Setup Menu
4) Fixed aac sound in MOV file
Mã:MED300X INTERNATIONAL VERSION [url]http://www.mede8er.org/beta/Firmware_Final/MED300X/MED300X_V1.5_28Nov.rar[/url] MED300X THAI VERSION [url]http://www.mede8er.org/beta/Firmware_Final/MED300X/MED300X_V1.5_28Nov(Thai).rar[/url]
Update Procedure
UnZIP or UnRAR the file and you will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Disconnect the power jack at the rear of the Mede8er then plug it back in - Now press the on/off button and hold it pressed for 10 seconds and then release.
After approximately 15 seconds the LED on the Mede8er with flash red-blue and you will get a display of the progress of percentage installed on your TV display (some TV's will not display this) wait until the Mede8er re boots itself +- 180 sec. You Mede8er is now be updated.
DO NOT REMOVE POWER DURING THE EMERGENCY RECOVERY PROCEDURE.
Mede8er1
