Ðề: Microsoft Windows 7 OEM All Editions (32/64 bit)
Fd ECAT 2011-10-03 0B9EG Update (12/2011) | Multi + RUS | 5.52 GB
Auto Parts Catalog Fd (Fd) contains a catalog of parts f all models of Fd cars, jeeps, light commercial, produced f the European market.
The "online catalog of spare parts FORD" provides the most comprehensive collection of cars and not only allowing f the models, but also changes in complete sets. This makes it possible to select a qualified Fd parts except f increct ders.
Using a dealer Fd ECat program significantly increases the efficiency of daily wk of specialists in the repair, maintenance vehicles, managers of ganizations that sell avotozapchastyami Fd.
Electronic parts catalog Fd Ecat - a system f identifying and sending ders f parts and services f all European dealers Fd. This system provides functions to access advanced search and content, but also connects to the DMS and other systems Fd.
FdEcat comes to DVD and installed from DVD.
There are different installation procedures f different types of installation:
- The first installation
- install a different version FdEcat to replace the already installed version
- re-install the same version FdEcat over an installed program.
FdEcat integrated with other infmation systems and management systems and Fd, which allows you to use all of its properties on the vehicle configuration and retrieval of infmation and subsequently use the results to another application. In addition, the data sted in FdEcat can copy and move to other copies of the software installed FdEcat.
0B5HF
0B67E
0B75E
0B7DF
0B82C
0B8HH
0B96G
0B9EG
0BA4H
0BAIH
0BB8H
0BBFH
+ Activat f the base version
Extras. Infmation: Installation runs through start.exe
Further, on the machine where installed run IExpler (IMPORTANT! Other browsers may not wk!)> 6.0, trying to drive
http://localhost:8080/Fd
Login Admin
Sa passwd
It is also the first time you need to enable ActiveX control called ISOView. IE security settings should be standard f all areas!
WARNING! It is very desirable to put ECAT ONLY and ONLY to the "fresh" system (eg a virtual machine). Compatibility and wk with other programs, directies are not checked. Be careful.
UPDATES
03.11.2011 - Distribution of updated accding to the administration of the tracker.
12.06.2011 - Distribution updated - updated tablet.
Download from filesonic.com
http://www.filesonic.com/file/4247295705/Ecat_2011_10.part01.rar
http://www.filesonic.com/file/4247295715/Ecat_2011_10.part02.rar
http://www.filesonic.com/file/4247295725/Ecat_2011_10.part03.rar
http://www.filesonic.com/file/4247295735/Ecat_2011_10.part04.rar
http://www.filesonic.com/file/4247295745/Ecat_2011_10.part05.rar
http://www.filesonic.com/file/4247295755/Ecat_2011_10.part06.rar
http://www.filesonic.com/file/4247295765/Ecat_2011_10.part07.rar
http://www.filesonic.com/file/4247295775/Ecat_2011_10.part08.rar
http://www.filesonic.com/file/4247295785/Ecat_2011_10.part09.rar
http://www.filesonic.com/file/4247295805/Ecat_2011_10.part10.rar
