Mede8erViet
Mede8erViet xin vui mừng thông báo đến khách hàng,người dùng Mede8er MED450X2/500X2, sau 1 thời gian làm việc chăm chỉ, tiếp nhận những bugs và những yêu cầu các tính năng mới mà người dùng trên toàn thế giới cũng như tại Việt Nam phản hồi, Mede8er đã hoàn thành firmware mới nhất bản Final V2.0.
Mọi người cùng Mede8erViet khám phá firmware mới này nhé
Finally Cheesy The all new V2 Firmware that has been many many months in the making
The New V2 has lots of new functionality so its VERY IMPORTANT that you download and read the user manuals . This release does not have a working Transmission BT downloader so dont update if you have pending downloads that need completion. See note at the bottom for more info
IMPORTANT: ONLY INSTALL VIA EMERGENCY METHOD AND DO NOT USE CONFIG RESTORE
AFTER THE UPDATE WE SUGGEST YOU UNPLUG AND REBOOT THE X2 AND THEN CONTINUE
Emergency Method (Resets Configuration to Default)
Format USB stick to FAT32. Unzip the firmware and copy the Install.img to the root of the USB stick. Disconnect the power jack at the rear of the Mede8er then plug it back in - Now press the on/off button and hold it pressed for 20 seconds and then release. After approximately 15 seconds the LED on the Mede8er with flash blue and you will get a progress bar on your TV display (some TV's will not display this) wait until the Mede8er re boots itself +- 60 sec. Your Mede8er is now updated.
NHỮNG TÍNH NĂNG MỚI + SỬA LỖI CỦA BẢN FIRMWARE V2.0 FINAL
ChangeLog -- v2.0.0
1. New V2 GUI
2. New Mede8er XML Movie Jukebox with 5 View Styles and Parental Control.
3. New User Customized Background function - User can use own background JPG images for GUI
4. New Skin function -- Users will be able to download community developed skins for X2
5. New Auto View Function
6. NEW -- Audio button shortcut to Audio Player 'Now Playing'
7. New customize GUI and SUBTITLE text based fonts (loaded into flash memory)
8. New Boot to Favourites function
9. Added support for PGS subtitles in MKV files
10 Added support for external vob/sub subtitles
11. Added Icelandic Launguge to GUI
12. Added Manual IP Setup for WiFi
13. Added HDD Size/Free Space added to Setup Menu
14. Fixed Internet Browser not displaying mouse curser
15 Fixed PCIe WiFi not booting up in conjunction with large size internal HDD
16. Fixed read NTFS only internal HDD
17. Fixed read issue on some HDD brands
18. Improved SRT subtitle image quality
19. Fixed external set sub with bracked extension after file name eg name[NL].srt or name.(NL).srt
20. Fixed limit of subtitles in one folder
21. Fixed SPDIF Passthrough when X2 does not have internal EDID info
22. Fixed crash caused by some characters in mp3 tag when doing a scan.
23. Fixed pause/play problem with DTSMA on some Pioneer Amp models
24. Fixed General Bugs and functionality
25. Fixed crash when opening BDISO with unsupported BD Menu
Transmission BT - Currently updating from V2.13 to V2.42 and this will be ready early next week. It must be noted that if you have pending downloads you should complete these first in V1.0.3 before updating as the new version uses different directories.
Investigating
1. Login to Picasa account
2. Vobsub not working if made with mkbmerge 4.9.1
3. LPCM - 6CH AAC Loosing Center channel when skipping forward/back
I would like to thank Hansen for his incredible work on this release. I would also like to thank Massbommel for his invaluable input and testing every night and every weekend Wink. To Jer1956 and Insomniac I thank you for your input. To all the Mede8er Beta testers a huge thanks and I can tell you that you guys have helped to make V2 what it is.
Mede8er1
http://www.mede8er.org/beta/Firmware_Final/MED500X2/Mede8er_X2_V2.0.0_18Nov2011.rar
Để upgrade firmware các bạn làm theo các bước sau:
o Tải firmware mình muốn upgrade từ trang chủ Mede8er hoặc ngay link trên
o Giải nén vào usb đã format để có 2 file 'install.img'
o Cắm usb vào Mede8er
o Tắt Mede8er đi
o Bật Mede8er lên và giữ nút Power trên Mede8er trong 20 giây
o Mede8er sẽ tự động cài đặt firmware và bạn hãy khởi động lại Mede8er để hoàn tất quá trình cập nhật
CHÚ Y: CHỈ NÊN LÀM ĐÚNG CÁCH NÀY - KHUYẾN CÁO KHÔNG DÙNG " CONFIG RESTORE"
Mọi người cùng xem và thưởng thức V2.0 với Mede8er MED500X2
[video=youtube;OBvJFSixuaE]http://www.youtube.com/watch?v=OBvJFSixuaE[/video]
[video=youtube;MmnriK2w3Uo]http://www.youtube.com/watch?v=MmnriK2w3Uo[/video]
