K-Lite Codec Pack Mega 7.7.0 - Bản mới nhất ngày 29/8/2011
K-Lite Codec Pack ver 7.7.0 Mega ~ 20.7 MB ~ August 29th 2011
About the K-Lite Codec Pack
The K-Lite Codec Pack is a collection of DirectShow filters, VFW/ACM codecs, and tools. Codecs and DirectShow filters are needed for encoding and decoding audio and video formats. The K-Lite Codec Pack is designed as a user-friendly solution for playing all your audio and movie files. With the K-Lite Codec Pack you should be able to play all the popular audio and video formats and even several less common formats.
The K-Lite Codec Pack has a couple of major advantages compared to other codec packs:
It is updated frequently. So it is always up-to-date with the newest and/or best components.
All components have been carefully selected for specific purposes. It is not just a random bunch of stuff thrown together.
It is very user-friendly and easy to use.
Works great with Windows Media Player and Windows Media Center. But also with all other DirectShow players, such as Media Player Classic, BS.Player, ZoomPlayer, and others.
The installation is fully customizable, meaning that you are able to install just those components that you really want.
The pack has many options, which allows you to tweak it to your own specific needs and preferences.
Uninstallation removes everything that was installed by the pack. Including all registry keys. All changes are properly undone.
It is extremely easy to make a fully customized unattended installation with the integrated wizard.
It does not contain any codecs or filters that are known to be bad, buggy or unstable. In fact, the installer is able to detect and disable several known troublemakers.
It tries to avoid potential conflicts with other codecs installed on your computer. The installer is able to detect and remove over 100 different codec and filter packs.
The installer is able to detect broken codecs and filters on your system, and helps you to remove them.
It is a very complete package, containing everything you need to play your movies.
The pack has options to activate thumbnail generation in Windows Explorer for several popular video file formats, which are by default not thumbnailed in Explorer.
The pack automatically configures Media Center to recognize all common audio and video file formats, so that such files show up in your media library.
This pack has a huge user base. This means that problems are found and resolved quickly.
There are different variants of the pack. From very small to large.
The pack is suitable for both novice and expert users.
The mega variant has almost the same contents as the full variant, but additionally contains some extra DirectShow filters and VFW/ACM codecs.
Update on ver 7.7.0 :
Updated Media Player Classic Home Cinema to version 1.5.3.3705
Updated ffdshow to version 1.1.3978
Updated LAV Filters to version 0.33 build 2011-08-25
Updated Codec Tweak Tool to version 5.0.8
Updated Win7DSFilterTweaker to version 4.6
Updated MediaInfo Lite to version 0.7.48
Added LAV Video decoder
Removed Gabest RealMedia Splitter
Improved playback of RealMedia files (using LAV Filters)
Link : http://download.betanews.com/download/1080441198-1/K-Lite_Codec_Pack_770_Mega.exe
Ðề: K-Lite Codec Pack Mega 7.7.0 - Bản mới nhất ngày 29/8/2011
lâu rồi chả để ý nâng cấp cho cái Klite này , còn xài 5.9
thấy cũng ngon lành cành đào nên k update
Còn mình khác, mấy bản cũ có khi bị lỗi nên mình mún update liên tục. Cũng có cái hay mà bạn :)
hi , mình cũng hám cái mới
mà cái cũ mình play HD ko lỗi lầm nào nên cũng k để ý update
mới update cái coreAVC 3.0 :))
ak47
Này thì update...
pác nào có bị vậy chưa... fig ra sao.. ngồi mấy h mà chưa fig đc...@-)
daemon
Này thì update...
Bị giống bác này mà còn ghê hơn nữa là hình nó lộn ngược, chân lên trời nữa cơ. vẫn đang sài Klite 64bit 4.6 thôi chỉ mới update Core AVC lên 3.0.1.0 thôi là nó bị thế ngay lập tức. đang thử gỡ ra cài lại. nếu kg hết buộc lại quay đầu về cới coreAVC 2.5 và Klite 64bit 4.6 thôi vậy.
nhutbang
chỉnh lại ffdshow video:
-Output-> bỏ Flip video.
RBG conversion:tự mài mò nha, tui hết bít!!
ak47
Cái bị phủ màu đỏ vẫn chưa ổn... chỉnh hoài .. nó mất hình luôn.. và thành mỗi Audio.. tức là như nghe nhạc ấy...8-X Có pác nào vọc đc xin chỉ giáo nữa nào....
Thanks all..:)
edc
Cài bản Core AVC 3.0 thì ngon ngay. 3.1 bị vậy
daemon
Cảm ơn bạn. thử ngay lập tức. tình hình là mò tới lui thì khắc phục được vụ đỏ trên của avc3.0.1 nhưng lộn đầu đuôi thì kg được. Khi cài coreAVC 3.0.1 thì buộc chỉnh lên DXVA sẽ hết vụ màu đỏ. (dù vga mình kg onboard chứ kg phải NVdia rời gì cả nhưng cứ phải tick vào DXVA trên CoreAVC config nó mới hết đỏ. nhưng lộn đầu đuôi thì mò kg ra cách fix. mò trên mấy trang nước ngoài nó còn bảo là bị Broken Codec mới sợ. mình gỡ sạch cả MPC-HC lẫn Klite và coreAVC cài từ đầu mà nó vẫn bị chứ có phải lung tung đâu mà bảo hư codec. Để thử CoreAVC 3.0 xem sao.
daemon
Đã giải quyết xong. cài được coreAVC 3.0.1 mà kg bị đỏ và lộn ngược.
Vấn đề chính thức nó nằm ở chỗ không được dùng keygen để kấy key đăng ký. lộn ngược và đỏ chính là do key bị phát hiện.
Chỉ cần kiếm cái key bỏ vào là được. Đừng cố dùng keygen mà lấy key.
ak47
Vậy bạn cho cái Key đi..:D.. chứ ae toàn dùng Keygen:-j
[email protected]
TBCYS8-Q18CKZ-8FHGG8-F49LTA-UK8AQQ
Ps: Hình như đã tìm đc....=))
daemon
Bác để cái key lộ thiên thế có ảnh hưởng gì không bác. Em cũng sài cái đó thôi. Ông Gú Gồ ổng cho ngay cái đó mà. Đăng sợ ảnh hưởng gì đến diễn đàn kg thôi. chứ chịu khó hỏi Gú gồ ra ngay thôi mà. :D
ak47
Chắc không ảnh hưởng j` đâu,, có j` Mod đã xóa bài...\m/
Để nude cho đẹp...=))
