Make MKV (and/or AVI) out of Blu-ray/HDDVD ISO image or ANY BD/HDDVD ripped to HDD
iscol
Apps to use
1. Isobuster v2.3
You could either buy this at
or download it at our Applications section (thanks to zeeko)
Note: Please be aware that this “cracked” version doesn’t work always and may require to be registered again even though already registered during initial installation.
2. tsMuxeR v1.8.4(b)
It’s freeware.
Download link:
More info:
3. MKVToolnix v2.2.0
It’s freeware.
Download link:
More info:
Install this app and then go to the installation directory (most likely: C:\Program Files\MKVtoolnix) to find “mmg.exe”. This stands for “mkvmerge GUI”. Create a desktop shortcut.
Required process
As an example, we’re going to use a BD ISO image of "National Treasure: Book of Secrets (2007) READNFO.1080p.Bluray.x264-Chakra"
1. Right click your ISO image (“ck-nt21080.iso”) and select to open it with ISOBUSTER (“The Ultimate CD/DVD Recovery tool”). The following screen appears.
index.php
2. Double click on “BDMV” at the right window or select to expand the National Treasure 2 UDF in the left window and then expand BDMV.
3. Double click on “STREAM”. This screen should appear.
index.php
4. Right click on “00001.m2ts” and select “Extract 00001.m2ts”. Select a place to save and a name for your m2ts file.
Note: If your ISO image has more than one m2ts (Blu-ray) or evo (HD DVD) files then select to extract all of them, one by one. This case stands most likely for lots of INTACT (not re-authored) BD or HDDVD ISO images
Hint: A. It’s better to save it in a different HDD than the one your ISO was originally stored, in order to achieve significantly increased extraction speed. B. Give short file names without spaces between characters, like the one in the screen below. This helps both “tsMuxeR” and “mkvmerge GUI”
index.php
Hit on “Save” button and wait for the extraction to finish.
index.php
5. Close ISOBUSTER
6. Create a folder named “tsMuxeR v1.8.4”, cut-paste in there the “tsMuxeR_1.8.4(b).zip” and select to extract it. If it’s convenient, create a desktop shortcut for “tsMuxerGUI.exe”.
7. Run “tsMuxerGUI.exe”. Drag & drop your extracted m2ts file(s) (in this example: "NT-BoS.m2ts") into the “Input files:” window of tsMuxeR. In the “Tracks:” window appear all the streams included in your m2ts file, meaning Video, Audio and Subtitles streams, along with a detailed description of them. This is what you should get:
index.php
Note: If you have multiple extracted m2ts files (or evo in case of HD DVD) building the BD or HD DVD main movie, then load the No 1 in tsMuxerGUI and use the "Append" button as many times as needed to add all the rest, one by one, following the arithmetical order.
8. Go to the “Tracks:” window and unpick all the subtitles streams. Leave selected only the H264 video and the AC3 audio streams (or any other AV streams of your preference). In the “Output” lower part of tsMuxeR window select “Demux” and then “Browse” for a different HDD to save the demuxed streams (increased process speed is obtained this way). If you’ve done everything as described here, the following screen should appear on your monitor.
index.php
In this step you could also configure “General track options” for each selected stream as long as you highlight it. Please don’t mess with Video stream options unless you know exactly what you’re doing. In Audio stream options you may select the language of the track, in case it’s not listed correctly.
9. Hit on “Start demuxing” button and wait for the process to finish. You will be viewing progress in the following window. Once finished, hit OK and then close tsMuxeR.
index.php
10. Open “mkvmerge GUI”. Drag & drop your demuxed AV streams. Highlight the video stream, go to the “Format specific options” tab, hit on the down arrow next to FPS field and select the correct framerate (24000/1001 if movie’s original fps is 23.976). See screen below. It’s important to perform this action whenever the imported video stream is raw (elementary) h.264, otherwise audio will be definitely out of sync because mkvmerge is always setting as default framerate 25 fps automatically.
index.php
Please don’t touch the other available options unless you know what you’re doing.
11. Select output mkv filename, hit on the “Start muxing” button and wait for the process to finish. It usually takes few minutes. You’re all done!
Notes: 1) “Haali Media Splitter” (freeware) latest version MUST be installed on your system.
Download link:
2) In case the included video stream is encoded in VC-1 advanced profile (wvc-1), you could also create an .avi file. Perform steps 1-9 and then use AVI-Mux_GUI v1.17.7 to make your AVI file.
Download it from here:
and visit the following page for a detailed user manual
3) You can download all screenshoots included in this tutorial in their original size using the links below
4. To make an mkv out of ANY BD or HD DVD disc even if it has multiple m2ts or evo files building up the main movie, just load the first file (ie "yourmovie0001.m2ts" or "yourmovieFeature1.evo") and then use the "Append" button of tsMuxeR to add the rest main movie's m2ts or evo files, one by one. tsMuxeR will merge all of them and if you select the "Demux" button it will do so for all the available Audio, Video and Subtitles streams you had selected (ticked boxes) to demux. Then use "mkvmerge GUI" to mux these streams into a new mkv container. If audio is anything different than AC3 or DTS, then you should use "eac3to" (freeware) in order to convert DD+ or DTS HD to "casual" AC3 or DTS before muxing to mkv container using mkvmerge GUI.
For more info on "eac3to" as well as for download links, please visit the following link.
iscol
Ðề: Make MKV (and/or AVI) out of Blu-ray/HDDVD ISO image or ANY BD/HDDVD ripped to HDD
Bài hướng dẫn tóm gọn nếu có chỗ nào ko đúng các bác nhớ góp ý nha.
Bước 1 chuẩn bị :
  1. Software (Isobuster hoặc bất cứ soft nào có thể extract iso bluray, tsMuxeR, MKVToolnix
  2. Chuẩn bị file iso bluray hoặc file m2ts
* tsMuxeR : tham khảo tại http://www.smlabs.net/tsmuxer_en.html để lấy phiên bản mới nhất
* MKVToolnix : tham khảo tại http://www.bunkus.org/videotools/mkvtoolnix/downloads.html để tải phiên bản mới nhất
Bước 2 Extract và Demux file bludisc
Nếu các bạn đã có sẵn file bludisc (filename.m2ts) thì bỏ qua phần extract
  1. Extract Bludisc ISO : Mở file iso bằng phần mềm isobuster hoặc các phần mềm đọc iso khác khi đó trên phần mềm sẽ xuất hiện các thư mục nằm trong file iso tìm thư mục "BDMV" và chọn mở thư mục trong thư mục "BDMV" tìm thư mục "STREAM" chọn mở thư mục và các bạn sẽ thấy các file có phần mở rông .m2ts các bạn chọn extract all file để lấy các file .m2ts
  2. Demux file m2ts (tách các file video, audio, sub ra khỏi file .m2ts) chạy chương trình tsMuxeR trong tab input nhấn add button khi đó các bạn chọn file .m2ts mà các bạn vừa extract ở trên hoặc file .m2ts mà các bạn có sẵn nếu có nhiều file .m2ts thì các bạn chon file nào có dung lượng lớn nhất và click open. Ở phần output bên dưới các bạn click chọn Demux và chọn thư mục lưu file và click Start muxing button sau khi ctrình demux xong click ok và thoát chương trình
  3. Make MKV file (merge file video, audio,sub to mkv file) chạy chương trình MKVToolnix trong tabinput click add button sau đó chọn file video audio mà các bạn vừa demux ở bước trên sau đó chọn tên và thư mục lưu file và click start muxing và đợi chương trình merge xong là bạn đã có file video của iso bluray với định dạng MKV
Nếu có gì khó khăn các bác cứ PM nha
trgvson
Có PM nào dùng thay cho isobuster không, vì nếu cài đặt không chuẩn sẽ không extrack file được.
fan2tech
Thanks,cũng đang muốn tập tành thử nghiệm xem sao
ahahui
Mình có sẵn file .TS. Làm sao CONVERT sang .MKV được, nếu dùng mkvmerge GUI khi input file báo lỗi kô đọc được định dạng file.
Cám ơn bác!
Chanh Niem
Cám ơn bạn rất nhiều.Tôi đã tạo được file .mkv chạy mượt mà bằng WMP,trước đây khi còn file .m2ts thì chỉ nghe âm thanh chứ không có hình,tuy nhiên file .mkv này VLC vẫn chưa đọc được,mong bạn chỉ thêm.Dù sao cung tốt lắm rồi.
Tốt nhất là dẹp ngay cái topic có cái MKV này đi. Để xem HD online lên có 1 tài khoản vip xem HD trực tuyến với chuơng trình xem định dạng chuẩn ví như chuẩn hddvd là .ts hoặc DVD là .vob. Qua phần mềm chuyển đổi thì xem hình có khi còn thua FLV trên Youtube. Mấy cái HD kiểu này dành cho đa số cư dân mạng không lắm rõ được chuẩn HD, HDDVD, DVD, DVD5, DVD9
Heaven86
Ðề: Re: Make MKV (and/or AVI) out of Blu-ray/HDDVD ISO image or ANY BD/HDDVD ripped to HDD
Anh chị có soft nào đơn giản hơn ko ạ? Em là người mới nên ko hiểu cho lắm. Anh chị có soft nào đơn giản rip từ dvd ra mkv, hướng dẫn dùm em luôn cách set video và audio, em cám ơn !
thien8x
Xài cái này để chuyển DVD ra MKV nhé
laptrinhtinhyeu305
đây là soft đơn giản nhất rồi đấy cậu .
tsMuxeR
MKVToolnix
tammoto
Xin lỗi mod iscol để trả lời ở đây.
Cám ơn bác!
Hiện nay MakeMKV chủ yếu để rip bluray, nếu chỉ convert ts sang mkv hoặc rip DVD sang mkv thì dùng makeMKV hơi phí (vì soft này không free).
Bạn ahahui muốn chuyển ts sang mkv hoặc bạn Heaven86 cần rip DVD sang mkv thì thử dùng freeware Video to Video Converter.
Xin nói qua về cách rip DVD, cách convert file cũng tương tự.
* Cách rip DVD:
- Chạy "Video to Video"
- Bấm File -> Add DVD -> Select DVD Device -> Chọn ổ đang có đĩa DVD (nếu đĩa DVD lưu file ISO thì có thể chọn Select ISO File).
- Cửa sổ kế tiếp, bấm chọn title có thời gian dài, đó chính là phim cần rip. Nhớ đánh dấu Deinterlace để chọn chế độ quét hình khử interlace khi xuất phim (cái này tuy tương đối nhưng tôi thấy có tác dụng khử sọc ngang khi rip các DVD đời cũ).
- Cửa sổ tiếp chọn 1, 2, 3, 4 như hình, các mục khác để mặc định. Có thể tuỳ chọn lại Video bitrate, Audio codec, Audio Channel, nhưng tôi thấy theo mặc định là hay nhất, vì đó là thông số phổ biến hiện nay. Video bitrate để ở 2000 Kbps cũng vừa, vì chất lượng DVD nếu có chọn cao hơn thì cũng không đẹp hơn. Nhưng chú ý ở mục Deinterlace trong Advanced chọn No (nếu không sẽ bị lỗi).
- Trở về cửa sổ chương trình, browse thư mục xuất phim rip (5) -> bấm Convert để bắt đầu chuyển đổi phim (6)
Chờ "Video to Video" làm việc cho đến khi xong. Thời gian tuỳ theo cấu hình máy tính.
Cảm ơn bạn đã đọc!
hoangqv68
Cám ơn bạn tammoto đã giới thiệu & hướng dẩn chi tiết soft convert mkv (&other) .
