Tin hot nhất cuối ngày
Bác latruong ơi có bản 4.0.4 rồi đấy bác làm luôn thể có hay hơn không
http://www.mede8er.org/beta/Firmware_Final/Mede8er_MED500X_V4.0.4_3March2011_INC_HDaudio.zip
http://www.mede8er.org/beta/Firmware_Final/Mede8er_MED500X_V4.0.4_3March2011_NO_HDaudio.zip
Chắc anh em mình dùng bản INC_HDaudio bác nhỉ
Changelog from V4
1. Bootloader updater not working - should update to #26 - fixed
2. Large size FAT32 USB Hard Drive not working - fixed
3. HFS Volume link to Video Wall not working - fixed
4. No audio .mov container has H264 codec + PCM audio - fixed
5. Video Wall image quality folder.jpg & about.jpg - fixed
6. Video Wall Navigation bug - one movie on last page - fixed
7. Video Wall increased max folder.jpg size to 100k
8. Video Wall speed "next page" - fixed
9. Watched Indicator on root of HDD - fixed
10. HDD Format no name - fixed
11. IR Interference from other remotes - fixed
12. File Manager copy to protected folder - fixed
13. Web Remote enabled by default - fixed
14. Slidshow Playlist Option - fixed
15. HFS Volume mask System files ie .fseventsd .Trashes .Spotlight-V100 - fixed
16. Video Wall MAC - .AppleDouble folder problem - fixed
17. Ken Burns ettect in Picture Slide Show not working - fixed
18. m3u Playlist not working with "Umlauts" characters - fixed
19. Focus / Unfocus Series View Video Wall hard to see the focus - fixed
20. Screensaver artwork changed
21. Screensaver movement not smooth MP3 play - improved
22. Screensaver during slideshow - fixed
23. Screensaver shows when playing multiple short video in a folder - fixed
24. Screensaver appears in picture slideshow - fixed
25. Older DD hardware cannot switch MED500x off with front on/off button - fixed
26. Open image and press Zoom+ and image zooms to 16x - It should start with 2x - fixed
27. File Manager "Move" function not working - fixed
28. Protected folder in Media Library not protected in Video Wall - Fixed
29. MP4 not working from video wall "www123" profile Sony PSP Codec ID: MSNV. Works from Media Library - fixed
30 No audio .mov container has H264 codec + PCM audio - fixed
Original V4 Features
• Support Dolby True HD and DTS MA passthrough - DD+ hardware
• New “Video Wall” with mapped share functionality
• New GUI
• Improved network streaming performance (both Samba & NFS / DD+ and DD hardware)
• Improved and fixed SAMBA NTFS write (NAS Mode)
• Shoutcast Radio API implementation
• New SDK and general improvement and bug fix
• Picture Thumbnail Viewer
• Improved upsampled picture quality SD content
• Added Thai Language support
• Added Icelandic Language support
Known SDK Issues
* Sceensaver on pls Radio Station does not change song name
* MED500X cannot connect via wireless that does not broadcast SSID
* WiFi WEP
* HD Audio will only passthrough on HDMI if TV Res Output is set to 720 or Higher
* Downmix SPDIF / Co- Ax Digital must set HDMI AND SPDIF to Downmix 2 CH
* Flac .cue files support (SDK- Realtek)
* APE .cue files support (SDK - Realtek)
* ID3 tags FLAC Audio (SDK - Realtek)
* BDMV over NFS ( SDK - Realtek)
* DD+ Hardware will not Passthrough to Core5.1 from HD Audio source on SPDIF (Awaiting Realtek)
Workaround - Use the "No HD Audio Firmware Version"
* Long Playlist over 3000 songs
* Random Audio Play
* PPPoE bug (SDK- Realtek)
* Some DVD files still show Subtitles although set to "off" in the Setup Menu
* "autoplay" Folder DVD ISO from FAT32 USB stick -- Starts with no picture and press zoom button then it corrects - fixed but only plays for +- 2 min and then restarts. Suggest to use raw VOB files for "autoplay" folder
