hoangtuan_neu
TIN HOT:
Firmware chính thức kế tiếp (dự kiến trong tháng này 07/2009) của TViX sẽ hỗ trợ thêm phụ đề Việt .srt và giao diện tiếng Việt cho Model 6500A/7000A và 3300A cả nhà ạ.
Đây là bản Full nha cả nhà
[DOWNLOAD]http://demod.dvico.com/down/tvix_M-6x00_1.3.137.zip[/DOWNLOAD]
Changes from 1.3.129
1. Fixed NTP server option is disabled when IP is get properly through DHCP server.
2. Now TV connection type is set to HDMI even if the EDID is not get from HDMI.
3. Imporved Enhanced AC3 stream on recorded streams through a tuner.
4. Network stream performance is optimized.
5. For DTV, fixed the recorded file name is not correctly set for the som Czech stations.
Known issues and limitations for Video related
- Some TP/TS information may not correct.
- When HD Audio pass-through is on, S/PDIF does not output.
- When HD Audio pass-through is off with HD audio stream, the playback is not smooth.
○ When DTS audio setting is digital, HDMI audio is ON and HD audio pass-through is set to ON, then audio is not heard on the SPDIF output.
○ For the same setting, if HDMI audio is set to OFF, then it sounds through the SPDIF output.
- Some TP/TS files may cause the system rebooting.
- Some WMV may not play correctly.
- The digital output for AAC/WMA is disabled.
- Does not support PCM audio track on MP4 now.
- TVIX may not get IP from DHCP server after change between DTV and Player modes and this can be solved by retrying DHCP on the setup.
Known issues for Audio and pictures playing
- For MP3 files with low sampling frequency, the TVIX might crash while playing or trick play like FF or RW.
- M4A files are not supported now and AAC may not play correctly.
Known issues for PVR
- After channel changed, you may not here audio in short time. . To work around it, you can press DTV key or Audio key on the remote.
Known issues for general issues
- If you play files without refreshing the file list after delete files through FTP or SAMBA server, the system will reboot.
*** If you play files with HD audio tracks like Dolby TrueHD, , Dolby Digital Plus, DTS-HD MA or LPCM, you better turn on HD Audio pass through on the setup even though you don’t have a receiver that supports decoding of these formats. Otherwise, you will hear strange noise with some repetitive popping noise. Currently, we don’t support core decoding, if you don’t have a HD audio decoder receiver, you need to select other then these HD audio tracks audio track for now.
