Firmware Mede8er V4 final cho M6, Egreat 200, HDS Pro
kinggai
Ðề: Firmware Mede8er V4 final cho M6, Egreat 200, HDS Pro
Bác Kinggai up lại bản bác đang dùng cho mình tham khảo được không!?
-- E vẫn sài bản của bác latruong ở trang 1.
-- Bác thử down 1 vài bài ape và flac khác để test
latruong
Mình đọc trên web bản FIRMWARE Mede8er v4.0.3 sẽ phát hành ngày 27/02/11 sẽ fix được nhiều lỗi lắm như
v4.0.3 25Feb2011 FINAL RC
1. Ken Burns ettect in Picture Slide Show not working - fixed
2. DVD Subtitles on/off Setup menu not working -- fixed?? * some DVD's still default to "on"
3. m3u Playlist not working with "Umlauts" charcters -- fixed
4. Focus / Unfocus Series View Video Wall hard to see the focus -- fixed
v4.0.2 24Feb2011
1. Screensaver movement not smooth MP3 play -- improved
2. Large size FAT32 USB drives not working -- fixed and varified
3. Screensaver appears in picture slideshow -- fixed
4. Older DD hardware cannot switch MED500x off with front on/off button -- fixed
v4.0.2 22Feb2011
1. Screensaver artwork changed
2. Screensaver not working when video paused -- fixed
3. Large size FAT32 USB drives not working -- fixed *require some clarification that it is indeed fixed
v4.0.1 18Feb2011
1. HFS Volume link to Video Wall not working -- fixed
2. Screensaver during slideshow -- fixed
3. Screensaver shows when playing multiple short video in a folder -- fixed
4. Open image and press Zoom+ and image zooms to 16x -- It should start with 2x - fixed
5. File Manager "Move" function not working -- fixed
6. Screensaver not smooth on Internet Radio and MP3 Play -- Improved
v4.0.1 15Feb2011
1. Bootloader updater not working - should update to #26 -- fixed
2. Protected folder in Media Library not protected in Video Wall -- Fixed
3. MP4 not working from video wall "www123" profile Sony PSP Codec ID: MSNV. Works from Media Library -- fixed
4. No audio .mov container has H264 codec + PCM audio -- fixed
Thế là chuẩn bị có firmware mới sử dụng nữa rồi
latruong
Cái đó chẳng phải là firmware của asus mà là hướng dẫn asus dùng firmware của Eagreat R1 mà Eagreat R1 dùng firmware của Mede8
tat
Bác download firmware cho HD300B ở trang 1 nha
Bác latruong giúp mình với.Mình đã cài vào Himedia HD300B rồi,nhưng nút enter không sử dụng được.Để mình tạo lại file irake.conf khác ,nhờ Bác make lại giúp mình nhé!thanks Bác
latruong
bác lấy cho mình cái Remote code nút Enter là được rồi. Mình sẽ make file cho bác
MTAM
Flac mình đầy cả đống, FW cũ của Datage chạy ầm ầm hết mà!
@bác Latruong: bác xem giúp em với!
latruong
Thì bác up thử 1 file FLAC không chạy được để mọi người cùng test. Chứ nói không không như vậy thì làm sao biết nguyên nhân mà giúp bác được
MTAM
Khi bật bất cứ 1 file FALC nào đều không chạy, các file định dạng khác thì vô tư.
Tất cả các file này em khẳng định là ok hết (FW cũ em chạy mãi mà)
Em tắt HDP đi bật lại thì có khi được, có khi không được.
Có bác nào bị giống em không!? nếu mình em bị thì em sẽ up lại FW xem sao nhỉ!
tat
Mình đã sửa lại nút Enter rồi.Nhờ Bác latruong làm lại giúp nhé.Thanks Bác nhiều!!!
hnhp
đung rồi đông flac , ape, deu ko chay dc, chay dc 1 bai flac roi im.
mp3 thi chay vo tu
DUNGMOTO
mp3 thi chay vo tu
em up FW cha HDMAX H1073 các định dạng audio chạy đc hết mà bác , FLAC thì chạy ok hết bài này qua bài khác
-- các đầu khác em ko có nên ko biết
kinggai
Em test tất cả các file nhạc Flac, ape trong ổ cứng của e. kết quả đều chạy tốt
hnhp
Sao lạ vậy nhỉ. Chẳng lẽ đống flac và ape có vấn đề, vẫn dùng suốt mà. Có khi tại thay file video.íntall vào FW nên nó bị thế
DUNGMOTO
bác thử lấy nguyên bản file của bác lantruong coi sao ...nhưng thực ra em coi hình ko đẹp = bản Rom gốc có cách nào khắc phục ko nhỉ
Bác latruong ơi, e mới up Mede8er v4 cho R7300, remote dùng ok nhưng có hai nút bị lộn với nhau :zoom in thành subtitle và ngược lại. E dùng tool của bác nhưng ko tìm thấy file irfake.conf để sửa lại, bác giúp e sửa lại nhé, thanks bác
hnhp
cach khac phuc chinh la kieu cua minh day
tun1978
Bác mở bằng notepad 2 file makebat và unmake.bat sửa ..\..\..\unyaffs.exe ..\yaffs2_1.img = ..\..\..\unyaffs.exe ..\yaffs2_2.img là ok ợ. Xong bác đổi vị trí 2 nút trong file ifake.conf thoai.
tat
Mình đã chỉnh lại được file remote cho Himedia HD300B rồi.Cám ơn Bác latruong nhiều nhé!!!!!
Bác nào có nhu cầu sử dụng firmware hack Mede8er cho Himedia HD300a,HB300B thì vào đây lấy nhé
Firmware Mede8er For Himedia HD300B.rar
