[TViX 6600/Slim S1]: Firmware mới chính thức 2.0.6B4 ngày 17.11.2010 với rất nhiều tính năng mới
hoangtuan_neu
Phiên bản firmware mới 2.0.6B4 chính thức với rất nhiều tính năng hay ho được cập nhật
[DOWNLOAD]http://demod.dvico.com/PreRelease/tvix_6600_2.0.6_B4.zip[/DOWNLOAD]
Link tải phim
[Changes]
[Multimedia Player/ System]
1. Supports DVD backup
- You can back up your DVDs (including encrypted one) into TVIX HDD
automatically.
- You need to connect external DVD drive thru USB to enable this
feature.
- You will be prompted before “BACKUP” menu as soon as you insert
the DVD, and the result will be stored in the movie/DVD folder with title
name.
- The backup file format is .IFO.
- This feature will work only when internal HDD is available.
2. Supports BT (Bit-Torrent) download (Món này ngon)
- If you configure the .torrent file, TVIX will automatically
download it. TVIX will consume much less power than PC, so it’s a good
downloading machine. You can directly playback contents as soon as it’s
done.
- Download itself happens in background, and does not interfere the
foreground playback. (Except recording DTV files - it will stop the
downloading in the meantime.)
- You can monitor or configure torrent at http://<tvix IP
address>/bt/. For example - Type http://192.168.1.5/bt/ on your PC web
browser and monitoring page will pop-up.
- The downloaded file will store at /BT on internal HDD.
- Supports resuming download just after last downloading.
- You can check the download completed files by clicking ”Visit
Neighbor” button on the monitor page (It will connect TVIX via Samba
server)
- Hướng dẫn sử dụng tại đây
http://demod.dvico.com/User/torrent_download.pdf
3. Improves Web-Remote
- Changes major user interface to more intuitive one.
- Supports progress bar to show the current status of playback. You
can also click the progress bar to change the playback position.
- So it becomes more and more usable without TV, when you want to use TVIX as music server.
4. Improves Media Library
- Add searching feature. You can type the searching words by virtual
keyboard (using remote).
- You can search music by artist/ album/ title/ file name. You can
search movie, photo by file name.
- Supports APE/ FLAC/ OGG tags and it will be enabled in Media
Library.
- If there is no audio tag, searching may not be enabled. Please
update the audio information using below FAQ.
http://www.tvix.co.kr/ENG/faq/default.aspx?bserial=0&act=RD&pg=1&gText=TViX%
20PVR&pSerial=52&id=744
5. Adds multi-language virtual keyboard
- Supports simplified Chinese/ traditional Chinese/ Korean/ Latin
Extended.
- The virtual keyboard will be automatically changed according to the
menu-language at set-up, if available.
- You can use this virtual keyboard at You-Tube searching, file name
editing and play-list editing.
- You can change the virtual keyboard by selecting “ABC” button on
the virtual keyboard.
6. Supports external subtitle browser (Món này tạm ngon)
- By selecting “Subtitle” button on remote then select “Extra
SUB” to browse the external subtitle file in the same folder.
- This “Extra SUB” button will be disabled if external subtitle
file does not exist in the same folder.
- Will not support upper folder or other folder’s subtitle file.
7. Improves AUTO-RUN function
- If you configure “DTV” or “Inlive” (for Korea only) as a start-
up at AUTO-RUN, it will start up as “DTV” or “InLive”.
8. Improves universal jukebox
- Fixes some bugs on several .ISO files.
9. Supports CUE file on WAV file format
10. Adds Serbian and Thai menu languages.
11. Fixes video not-showing bug on some MKV files. (Món này ngon tuyệt. Giải quyết vấn đề xem 1 số phim hiện nay chỉ có tiếng mà không có hình)
[Network]
1. Adds manual IP address configuration on Wi-Fi.
2. Supports FTP password changing at SET-UP.
tdhvn
Ðề: [TViX 6600/Slim S1]: Firmware mới chính thức 2.0.6B4 ngày 17.11.2010 với rất nhiều tính năng mới
Có cái món số 4 cũng ngon đấy: Tìm kiếm phim, nhạc v.v.... trên HDD
Library.
khonggianhd
Em thick nhất món số 2 :-bd -> phải thử ngay xem thế nào :D
ở đây cũng có nè : tvix.vn
wasabi18
OMG, hok bik N1 bao giờ mới có ~X(~X(
Coconut
Có 1 lỗi phụ đề của S1 mà không biết mấy con TViX khác có không, là nếu câu rỗng (tức là chỉ có số thứ tự và thời gian, có thể do các bác dịch từ phụ đề khiếm thính chỉ xóa chữ) thì
cả số thứ tự, thời gian, chữ của câu sau đó đều hiện lên khi đến thời gian của câu rỗng, cái này xem rất khó chịu, không biết có cách khắc phục không hay chờ FW mới, vấn đề này xem trên PC không bao giờ có.
tdhvn
Bác nói đúng, cái đó sẽ sửa trong firmware chính thức.
Trước mắt có thể khắc phục bằng cách dùng Subtitle Workshop mở phụ đề đó, rồi save lại, thì các dòng rỗng sẽ bị khử hết, và không còn hiện tượng đó.
sonthanhbinh
up phát em s1 chết nhăn răng bây giờ sử lý sao đây các pro. up dc 50% nó tự tắt bây giờ bật lên hiên hello mọt tí ròi lại tắt
tdhvn
Sao bác hỏi nhiều nơi thế???
hoptuyen
không biết bao giờ thì N1 có thể chơi nhạc lossless đuôi .dts nhở?
Hungtm87
K biết bản firmware beta này đã fix đc lỗi play những phim gần đây chỉ lên tiếng mà k lên hình k nhỉ :d
tdhvn
Đã fix món đó rồi bác ạ. Trong mục 11:
Cho đến nay mới có Xtreamer, TViX fix vấn đề này. Còn các HDP khác thì chắc sẽ dần dần khắc phục.
chaienHD
Mình đã up firm và đã lên hình lẫn tiếng.:)):)):))
Nó giải quyết lun mấy cái phụ đề rắc rối\:D/\:D/\:D/
cdduy
sao e không vào được dc IP: http://172.28.1.38/bt/
E lấy cái IP trên tvix slim s1 ở nhà e cũng không vào đc thì làm sao download bittorent?
Các bro giúp với
tdhvn
Các bro giúp với
Trước hết, từ máy tính khi ping, đã nhìn thấy IP của TViX Slim S1 chưa đã. Nếu nhìn thấy thì sẽ truy cập được.
toemayman
Bác chỉ dẫn kĩ hộ em cái vụ này với.Em dùng TVix 6600A.Cám ơn bác
cdduy
Bác chỉ cách lấy cái IP tvix s1 qua laptop giúp e, mù tịt?
tvip
FW này vẫn còn lỗi khi xem DTV thanh info không tự mất đi khi chuyển kênh.
va6888
Hôm qua em đã chạy thử 1 film Inception, quả nhiên có hiện tượng như bác nói. Nếu các phụ đề chạy liên tục thì ko sao, nhưng cách quãng 15-30s thì câu phụ đề đầu tiên hiện cả thời gian và thứ tự
