winscp sees empty
fstab
PARTUUID=7ad3c0f7-01 /boot vfat defaults,noatime 0 0
PARTUUID=7ad3c0f7-02 / ext4 defaults,noatime 0 0
lms my music disk and folder mnt mpd usb is empty
wget -O - https://raw.githubusercontent.com/lovehifi/raudiolms-64bit/main/install-archlinux.sh | sh
i am wirete this command
reboot raudio
it is ok lms add library thanks quatmo
but Why does it not see the HDD after installing v6?
wget -O - https://raw.githubusercontent.com/lovehifi/raudiolms-64bit/main/update | sh
wget -O - https://raw.githubusercontent.com/lovehifi/addraudio/main/eqfa12lms | sh
wget -O - https://raw.githubusercontent.com/lovehifi/tidal-raudio-pi4/main/install | sh
wget -O - https://raw.githubusercontent.com/lovehifi/tidal-raudio-pi4/main/update | sh
wget -O - https://raw.githubusercontent.com/lovehifi/lmsbub9/main/install.sh | sh
wget -O - https://raw.githubusercontent.com/lovehifi/addraudio/main/configgui | sh
wget -O- https://raw.githubusercontent.com/lovehifi/picoreaddon/main/mskin | sudo sh
Dựa trên anh Phước chỉ cách dùng plugin truy cập Nas Local.
Có cách để dùng Nas online như sau:
1. LMS, Active plugin: Remote Music Libraries.
2. Trong Setting của plugin Remote Music Libraries, ở UPnP/DLNA Client, chọn: Enabled, look for other UPnP/DLNA media servers.
3. Cài BubbleUPnP Tether Client với 1 dòng lệnh:
4. Edit config, WinSCP edit file: /opt/upnp/bupnp.service
Dòng này: ExecStart=/opt/upnp/launch.sh
Edit, (thay thế) link server, username, pass :
-connect http://server link :58050
-login user-name
-password pass-of-server
Edit xong, chạy nó:
Mình lưu trữ hướng dẫn ở đây: https://github.com/lovehifi/lmsbub
có chữ tether là Nas online
Đã test: Duyệt album, nghe Ok
pass là foobar2000 trơn hay foobar2000! vậy bác
Có ! ạ .pass là foobar2000 trơn hay foobar2000! vậy bác
I am rechecking the issue of certain WAV albums not playing, while many other WAV albums play well.@quatmo v6 doesn't play wav files Why ?
my sq.sh file ;
#!/bin/bash
card=$(grep -oP '(?<=defaults.pcm.card ).*' /etc/asound.conf)
echo "Card number: $card"
/opt/sq/squeezelite64 -o eqfa12p -n SQ64-rAudio -s 127.0.0.1 -m 00:00:00:00:00:00 -W
Bác dùng Pi2 hay Pi4 vậy ạ ?
Update : Thấy rồi bác SQ32 .
Bác kiểm tra file /opt/sq/sq.service cấu hình đúng chưa?Pi 3 bác ạ nhưng khi play nhạc nội mạng hay ngoại mạng nó chạy được khoảng 15s thì dừng và phát lại từ đầu rồi nghe luôn không bị dừng nữa next sang album khác nó cũng bị vậy mình thử nãy giờ file flac không bị mà bị file wav
Thêm -W để LMS hiểu - gửi play định dạng wav
ExecStart=/opt/sq/squeezelite32 -o default -n SQ32-rAudio -s 127.0.0.1 -m 00:00:00:00:00:00 -W
Hoặc đơn giản update #1
wget -O - https://raw.githubusercontent.com/lovehifi/raudiolms-32bit/main/install-archlinux.sh | sh
wget -O - https://raw.githubusercontent.com/lovehifi/raudiolms-32bit/main/update | sh
wget -O - https://raw.githubusercontent.com/lovehifi/tidal-raudio/main/install.sh | sh
wget -O - https://raw.githubusercontent.com/lovehifi/addraudio/main/eqfa12lms32 | sh
Cái này cài làm gì anh 12-band Parametric EQ
Build LMS-rAudio cho Pi 2 và Pi 3
Mình mới flash thẻ mới cho Pi 2 ( Pi 3 dùng chung) + cài xong hết các thứ này tầm 10 - 15 phút.
LMS and Squeezelite (32bit)
Mã:wget -O - https://raw.githubusercontent.com/lovehifi/raudiolms-32bit/main/install-archlinux.sh | sh
Mã:wget -O - https://raw.githubusercontent.com/lovehifi/raudiolms-32bit/main/update | sh
Tidal Connect for rAudio
Mã:wget -O - https://raw.githubusercontent.com/lovehifi/tidal-raudio/main/install.sh | sh
Active plugin Material Skin
BubLMSV9 (Connect to BubbleUPnP Server)
Mã:wget -O - https://raw.githubusercontent.com/lovehifi/lmsbub9/main/install.sh | sh
Material Skin mod
Mã:wget -O- https://raw.githubusercontent.com/lovehifi/picoreaddon/main/mskin | sudo sh
12-band Parametric EQ Eqfa12 LMS (32bit, 64bit)
Mã:wget -O - https://raw.githubusercontent.com/lovehifi/addraudio/main/eqfa12lms32 | sh
Config GUI LMS (Giao diện để dùng đăng nhập BubLMSV9 và chọn SQ output)
Mã:wget -O - https://raw.githubusercontent.com/lovehifi/addraudio/main/configgui | sh
Chạy test file wav native Ok.
http://honddpy.ddns.net:58050/stream/audio/5c4d4c913ba56018f821fb01e1e01c95.wav
24 bit, 192kHz, Bitrate 9216 kbps, Codec PCM
Build LMS-rAudio cho Pi 4 (64 bit) xem trang 1364
