@linh0983
Có bo này, dual ethernet làm front ngon
Họ chỉ là thử luôn bác a . :p
Thanhvo31
Bác Lâm cài UPnP vào Arch64 giúp hộ a . :eek:
https://drive.google.com/file/d/1SriDoyHMep6bIEwG-35Bhv-DgTFb7T4x/view
@linh0983
pi-3 is cute.
I installed from Arch AUR.
https://aur.archlinux.org/packages/upmpdcli/
You need to install libnpupnp and libupnpp before upmpdcli.
git clone https://aur.archlinux.org/libnpupnp.git
git clone https://aur.archlinux.org/libupnpp.git
$ git clone https://aur.archlinux.org/libnpupnp.git
$ cd libnpupnp
$ makepkg
Japanese is mixed, but you can also check here.
https://www.symphonic-mpd.com/forum/topic/145/arch-linux-aoe/43
Họ chỉ mình làm nó ko chạy : systemctl status upmpdcli báo lỗi ui . . . :p
Bác cài vào Pi3 , Pi3+ hoặc Pi4 để check đều được a . :cool:
Sau khi makepkg xong nó ra file cài đặt dạng zst, bác phải cài
pacman -U uxxxyyy.pkg.tar.zst
sau đó systemctl start/enable/status nó nữa.
TuanQuynhAudio
Trên Pi 4 bác thử tham số: force_eeprom_read=0 trong /boot/config.txt chưa?
https://www.hifiberry.com/docs/software/configuring-linux-3-18-x/
Vẫn không được anh à. Sau khi test "aplay -c 12.wav" thì báo lỗi "bcm2835-i2s fe203000.i2s: I2S SYNC error!"
[    7.564347] snd-rpi-wm8804 soc:sound: ASoC: failed to init link HiFiBerry Digi+ Pro: -517
[    7.608530] wm8804 1-003b: revision E
[    7.619348] snd-rpi-wm8804 soc:sound: wm8804-spdif <-> fe203000.i2s mapping ok
[    7.619376] snd-rpi-wm8804 soc:sound: ASoC: no DMI vendor name!
[    8.935520] random: crng init done
[    8.935537] random: 7 urandom warning(s) missed due to ratelimiting
[    9.114379] 8021q: 802.1Q VLAN Support v1.8
[    9.212857] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[    9.224246] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.270402] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    9.307497] bcmgenet: Skipping UMAC reset
[    9.309492] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[    9.309683] bcmgenet fd580000.ethernet eth0: Link is Down
[   12.388999] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   12.389048] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  656.829881] bcm2835-i2s fe203000.i2s: I2S SYNC error!
triton
Anh @TuanQuynhAudio thử làm theo hướng dẫn của anh shanghai2004 này xem có được không (anh xem post #7). Em đã xử đủ các kiểu theo hướng dẫn của Hifiberry mà không được. Cho đến khi làm theo hướng dẫn của anh shanghai2004 thì ok.
Anh tìm chân số 6 của IC WM8804 hàn thêm tụ 2.2m/16v với (+) vào chân 6 của IC và chân (-) của tụ hàn xuống GND.
Note: Em dùng card nhái pifi digi+ nhưng cũng cùng driver của hifiberry và chỉ bị không có tiếng khi dùng Pi4.
TuanQuynhAudio
Em dùng card 502DAC PRO. Hix vị tró khó hàn thêm tụ.
TuanQuynhAudio
@triton Board của anh trống trải dễ hàn hơn của em và dễ chấm hàn. Của em ở vị trí khe hẹp, dò sang mặt bên mà chưa xác định có con tụ, trở nào nối sang chân 6 (WM8804). Lây source code driver cũ của Hifiberry Digi Pro build trên kernel 4.19.x 64 bit lỗi tùm lum, lỗi nhiều khó sửa code. Em mò so sánh source code cũ và mới nó khác nhau nhiều.
triton
@TuanQuynhAudio vâng, digi+ chạy trên 4.19.xx chỉ fix nhẹ nhàng nhưng sang 5.4.xx thì không chạy được anh ạ. Cuối cùng hết cách em thử mod phần cứng thì ok!
là sao anh, anh nói rõ xíu ah
(FE) cài Arch Linux AoE : https://www.symphonic-mpd.com/forum/topic/145/arch-linux-aoe
Bác up như vầy . :p
wget https://www.symphonic-mpd.com/forum/assets/uploads/files/1616919740604-webui-plus_2021_03_28.tar.gz
tar zxvf 1616919740604-webui-plus_2021_03_28.tar.gz
cd pkgbuild/
systemctl stop ympd.socket
systemctl stop ympd.service
sh install.sh
cd /root
rm -rf pkgbuild/
reboot
(FE) cài Smpd 1.0.xx AoE : https://www.symphonic-mpd.com/forum/topic/141/audio-over-ether
Bác up như vầy . :D
app remove webui-base
app install webui-plus
cd /opt/plugins/detach
rm 82-aoe
reboot
TuanQuynhAudio
Hàn trực tiếp chân to khó hàn trung gian qua sợi dây đồng nhỏ (rất dễ tu 2.2 một đầu vào tụ kia xuống mass đầu còn lại qua cộng dây đồng vào chân số 6) xem hót ko a ? :cool:
Tạm thời em dùng "dtoverlay=rpi-dac" trong /boot/config.txt. Sau đó dùng tools raspi-gpio để enable gpio 5/6 (44,1khz hoặc 48khz) mở clock cho card 502DAC PRO. Hót ngon lành anh à.
Em đang mò theo Archphile để setup up UPnP vào Arch Linux AoE. Build sẵn file cài để anh cài cho nhanh.
pm: Em không truy cập được nas của anh ạ.
quatmo
@linh0983
pi-3 is cute.
$ cd libnpupnp
$ makepkg
Em build chưa được, báo lỗi.
https://github.com/lovehifi/libnpupnp-archlinux
toi511
Bác up như vầy . :p
cd pkgbuild/
sh install.sh
cd /root
rm -rf pkgbuild/
reboot
Bác up như vầy . :D
rm 82-aoe
reboot
Cảm ơn anh, anh đang xài Fe nào vậy, thấy khác nhau k
TuanQuynhAudio
- Anh download file Upmpdcli-Archlinux64.zip, giải nén và làm theo file hướng dẫn bên trong để cài upmpdcli cho archlinux64. :):)
- Cài đặt thêm Minidlna:
pacman -Sy minidlna
Edit file "/etc/minidlna.conf" để trỏ đến thư mục chứa nhạc. Của em là /root/Music"
media_dir=/root/Music
- Đêm khuya nghe Radio của upmpdcli:
ABSRlIp3eoTq3ecsWUSZu0y1BBej44IalVWLGAZ_kcK0UCQxJ0eT0mUbcBYluxUSxC3YwD5kah4sjgFIReFQaYgZ5djLFWyuW3HEaWTDlYsxNQU0xrG4EaioML4K-DbDTj51r_Hx4rBmPjOf1GnKDh-aT9fEcVaVPKbALELD6r1Uen81PTHihxop1q6PcTx4X9WgewRH_zFSBj94PU_j9k7IZfoAiMzAo80E3Pn3a8it9gKg-phQzGYPTrrua3AEnEKBnqa1g-fFwMLFTgqtNNWxSC5_0OU_vz2kHoJI6F0bLZGEU7iORlSFpSZGefnv60TNBTVxzxsVbO6Bm6YK15Izs4mgJ6OZMUwq7yLkU3rydatKn_DFkH0Vmtnchd1aTwKJmoEdiSTMDprQLzXUisyXYvqtlEGGI6udTs71tzTIA-P8gj5D6e5S9hI_8mK1Rtdp7FIuT5BCEXs9nHEub2pkwxjH1l8lVNZTTXXfO_11m-NvCLQrcjKYiYZjfUHjoB2dOzsRXYP3jlmf-VC7qbBGz6gQopFx2CHluRoPQr4w-SqItXbrVU_wPygWICUjZEsMphBbAcLjeG4NItSk6zByGOqw94FmkTVNmekEgKHcPfhUK9DQ6WV_1C4N0HcnTmwxfiwkSnlJS_YPdr6LRnvmed-f2zedge6c0bay9EhXSVYXdu2Khk4AcJPLMKKacuEYFS3JdN9I6Cjy8YpJVicSolztGjokWfqDCw=w2549-h4663-ft
pacman -Sy minidlna
Bác Quỳnh tuyệt vời mình thử add vào a . :oops:
