quatmo
Cài TC cho SMPD AOE không được, buồn tình qua RopieeeXL (Aarch64) cài TC vào một phát ăn ngay, start Service lên xanh, pa-devs-get ra device liền.Khi nào rảnh mình làm cái cook book.
Làm luôn cho nóng.
Tidal Connect RopieeeXL setup instructions
Github cook book
#1./ Download Tidal
wget https://raw.githubusercontent.com/lovehifi/Tidal-Connect-RopieeeXL/main/opttidal.tar.gz
wget https://raw.githubusercontent.com/lovehifi/Tidal-Connect-RopieeeXL/main/tidalservice.tar.gz
#2./ Download Aarch64 Lib
wget https://raw.githubusercontent.com/lovehifi/Tidal-Connect-RopieeeXL/main/tidallibs.tgz
#3./ Extract Tidal Connect
tar -xf /root/opttidal.tar.gz --overwrite -C /
tar -xf /root/tidalservice.tar.gz --overwrite -C /
#4./ Extract Aarch64 Lib
tar -xf /root/tidallibs.tgz -C /usr/lib/
#5./ Check device
/opt/tidal/pa_devs/bin/ifi-pa-devs-get
Copy device name, sample: snd_rpi_rpi_dac: RPi-DAC HiFi pcm1794a-codec-0 (hw:1,0)
WinCSP edit this file or vi /etc/systemd/system/tidal.service
To replace --playback-device.
sample: --playback-device "snd_rpi_rpi_dac: RPi-DAC HiFi pcm1794a-codec-0 (hw:1,0)" \
#6./ Start
systemctl daemon-reload
systemctl enable tidal.service
systemctl restart tidal.service
systemctl status tidal.service
Mình download Ropiee mới nhất gắn Pi 4, config DAC, update lên XL rồi cài TC. Tidal play qua OK, âm thanh tốt, đã test.
