Thanhvo31
Bây giờ có Roon và Nas lại ko chơi được quá phí bác a mình cũng chịu ko add được bác ơi !
ADD KIỂU GÌ CŨNG LỖI A .
Roon nó chơi NAS mạng LAN OK ngay bác ạ.
NAS của bác nó hơi quái tý.
Bác cố mount / map vào folder/ thư mục nào rồi brow nó ra.
https://kb.roonlabs.com/Adding_Folders_Using_Path
Windows
- On the Windows PC running your Core, use Explorer to open your music folder
- Click on the right side of the Explorer field like a web browser, and Explorer will highlight it and turn it into a path
- Copy and paste this path into the watched folder field in Roon
- To add network storage, we recommend using your NAS drive's hostname, such as \\DISKSTATION or smb://MyNASDrive. You can usually find this information by logging into your NAS., and examples are below.
- You can also use your NAS drive's IP address, but note that this can change, depending on your network's settings.
- If your Roon Core is running on Windows, the path to your networked folder might look like this:
or
\\192.168.1.120\Multimedia\Music
- If your Roon Core is running on Mac or Linux, the path to your networked folder might look like this:
or
smb://192.168.1.120/Multimedia/Music
- After you've entered the network path in Roon, enter the credentials required to access your NAS. If a username, password, or workgroup isn't required to access your NAS, just leave the relevant fields blank and click Add Folder
