SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.000499
SELECT cache_value
Params: 1
Run Time: 0.000186
FROM `xf_thread`
WHERE (`xf_thread`.`thread_id` = '409838')
LIMIT 1
Run Time: 0.000625
FROM `xf_post`
WHERE (`xf_post`.`thread_id` = 409838) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 620) AND (`xf_post`.`position` < 640)
Run Time: 0.017312
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 20 | Using index condition; Using where; Using filesort |
INSERT INTO xf_thread_view
(thread_id, total)
VALUES
(? , 1)
ON DUPLICATE KEY UPDATE
total = total + 1
Params: 409838
Run Time: 0.000220
-- XFDB=noForceAllWrite
VALUES
params = VALUES(params),
robot_key = VALUES(robot_key)
Params: 0, , , XF\Pub\Controller\Thread, Index, valid, thread_id=409838&page=32, 1715802931,
Run Time: 0.000252
Run Time: 0.000416
ORDER BY RAND() ASC
Run Time: 0.002029
SELECT `xf_post`.*
FROM `xf_post`
WHERE (`xf_post`.`post_id` = 3224956)
LIMIT 1
Run Time: 0.000274
SIMPLE | xf_post | const | PRIMARY | PRIMARY | 4 | const | 1 | |
- XF\Mvc\Entity\Entity->__get() in src/addons/VNXF/ImageView/Entity/Thread.php at line 43
- VNXF\ImageView\Entity\Thread->firsttPostAttach() in src/addons/VNXF/ImageView/Entity/Thread.php at line 12
- VNXF\ImageView\Entity\Thread->getImageView() in src/XF/Template/Templater.php at line 1191
- XF\Template\Templater->method() in internal_data/code_cache/templates/l2/s4/public/thread_view.php at line 681
SELECT `xf_attachment`.*, `xf_attachment_data_Data_1`.*
FROM `xf_attachment`
WHERE (`xf_attachment`.`content_type` = 'post') AND (`xf_attachment`.`content_id` = 3224956)
Run Time: 0.000243
SIMPLE | xf_attachment | ref | content_type_id_date | content_type_id_date | 31 | const,const | 1 | Using index condition; Using where |
SIMPLE | xf_attachment_data_Data_1 | eq_ref | PRIMARY | PRIMARY | 4 | f6kf_hdvietn116n.xf_attachment.data_id | 1 | |
- XF\Mvc\Entity\Finder->fetch() in src/XF/Mvc/Entity/Manager.php at line 380
FROM `xf_session_activity`
WHERE (`xf_session_activity`.`user_id` = 588513) AND (`xf_session_activity`.`unique_key` = '588513')
LIMIT 1
Run Time: 0.000317
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1713210931)
LIMIT 10
Run Time: 0.000934
SIMPLE | xf_thread | range | last_post_date | last_post_date | 4 | | 378 | Using where |
bytes_sent | 14800 |
bytes_received | 494096 |
packets_sent | 136 |
packets_received | 1646 |
protocol_overhead_in | 6584 |
protocol_overhead_out | 544 |
bytes_received_rset_header_packet | 396 |
bytes_received_rset_row_packet | 144 |
bytes_received_prepare_response_packet | 128020 |
bytes_received_change_user_packet | 364956 |
packets_sent_command | 67 |
packets_received_ok | 0 |
packets_received_eof | 0 |
packets_received_rset_header | 44 |
packets_received_rset_row | 24 |
packets_received_prepare_response | 1434 |
packets_received_change_user | 120 |
result_set_queries | 20 |
non_result_set_queries | 4 |
no_index_used | 1 |
bad_index_used | 0 |
slow_queries | 0 |
buffered_sets | 0 |
unbuffered_sets | 0 |
ps_buffered_sets | 20 |
ps_unbuffered_sets | 0 |
flushed_normal_sets | 0 |
flushed_ps_sets | 0 |
ps_prepared_once_executed | 21 |
rows_fetched_from_server_ps | 100 |
rows_buffered_from_client_ps | 100 |
rows_affected_normal | 0 |
rows_affected_ps | 0 |
rows_skipped_normal | 0 |
rows_skipped_ps | 100 |
copy_on_write_saved | 0 |
copy_on_write_performed | 0 |
connect_success | 1 |
connect_failure | 0 |
connection_reused | 0 |
reconnect | 0 |
pconnect_success | 1 |
active_connections | 1 |
explicit_close | 0 |
implicit_close | 0 |
disconnect_close | 0 |
explicit_free_result | 0 |
implicit_free_result | 0 |
explicit_stmt_close | 0 |
implicit_stmt_close | 0 |
mem_emalloc_count | 0 |
mem_emalloc_amount | 0 |
mem_ecalloc_count | 0 |
mem_ecalloc_amount | 0 |
mem_erealloc_count | 0 |
mem_erealloc_amount | 0 |
mem_efree_count | 0 |
mem_efree_amount | 0 |
mem_malloc_count | 0 |
mem_malloc_amount | 0 |
mem_calloc_count | 0 |
mem_calloc_amount | 0 |
mem_realloc_count | 0 |
mem_realloc_amount | 0 |
mem_free_count | 0 |
mem_free_amount | 0 |
mem_estrndup_count | 0 |
mem_strndup_count | 0 |
mem_estrdup_count | 0 |
mem_strdup_count | 0 |
mem_edupl_count | 0 |
mem_dupl_count | 0 |
proto_text_fetched_null | 0 |
proto_text_fetched_bit | 0 |
proto_text_fetched_int | 0 |
proto_text_fetched_date | 0 |
proto_text_fetched_year | 0 |
proto_text_fetched_time | 0 |
proto_text_fetched_blob | 0 |
proto_text_fetched_enum | 0 |
proto_text_fetched_set | 0 |
proto_binary_fetched_bit | 306 |
proto_binary_fetched_short | 597 |
proto_binary_fetched_int24 | 268 |
proto_binary_fetched_bigint | 1678 |
proto_binary_fetched_decimal | 29 |
proto_binary_fetched_float | 82 |
proto_binary_fetched_json | 1107 |
proto_binary_fetched_blob | 455 |
com_quit | 0 |
com_init_db | 0 |
com_query | 2 |
com_field_list | 0 |
com_create_db | 0 |
com_drop_db | 0 |
com_refresh | 0 |
com_shutdown | 0 |
com_statistics | 0 |
com_process_info | 0 |
com_connect | 0 |
com_process_kill | 0 |
com_debug | 0 |
com_ping | 0 |
com_time | 0 |
com_delayed_insert | 0 |
com_change_user | 0 |
com_binlog_dump | 0 |
com_table_dump | 0 |
com_connect_out | 0 |
com_register_slave | 0 |
com_stmt_prepare | 22 |
com_stmt_execute | 22 |
com_stmt_send_long_data | 0 |
com_stmt_close | 21 |
com_stmt_reset | 0 |
com_stmt_set_option | 0 |
com_stmt_fetch | 0 |
com_deamon | 0 |
bytes_received_real_data_ps | 361955 |
