Power ISO v6.4 Final and Portable 32bit & 64bit - Clean Install, No Adware [26.10.2015]
About The Soft:
PowerISO - program allows you to create, convert, extract, compress, edit and encrypt images of CD / DVD, as well as open them with the built-in emulator.
PowerISO used in compression-decompression technology is a real-time image files with the extension DAA, which significantly reduces the size of image files. The image file can be cut into pieces of various sizes and in a compressed form to send via email or write to other carriers. Most importantly - the files can be used directly without decompressing.
It works with all major image formats: ISO, BIN, NRG, CDI, DAA, MDF, BWI, B5I, LCD, CIF, P01, PDI, NCD, PXI, GI, FCD, VCD, C2D. A built-in emulator CD / DVD-drive. There is the possibility of creating avtozagruzochnyh fayloobrazov. The program integrates into Windows shell, a high speed, easy interface ...
Key Features:
Create ISO image file from hard disk or CD / DVD
Support for most formats, disk images, including ISO, BIN, NRG, CDI, DAA and many other
Open and extract ISO File
Removing and editing images without decompressing
Convert image files between ISO / BIN and other formats
Create a bootable ISO files
Getting the boot information from boot image files
Create a floppy disk
Optimize files to save disk space
Mount a disk image as a virtual drive
Integration with Windows Shell
User-friendly interface
Ability to write CD / DVD discs from.
Support OS:
PS: Vui lòng đọc Read Me trước khi cài đặt.
PowerISO v6.4 Final (32bit & 64bit):
Link FShare:
[HIDE]http://www.fshare.vn/file/2XA96TFAWG8G[/HIDE]
PowerISO v6.4 Portable (32bit & 64bit):
Link FShare:
[HIDE]http://www.fshare.vn/file/NCI9F6AM36D2[/HIDE]​
