Cái này áp dụng cho 203 ko bácConfiguring your OPPO Blu-ray player for Dolby Atmos
In the cinema, at home, and on the go, Dolby Atmos can transport you from an ordinary moment into an extraordinary experience with breathtaking, moving audio that flows all around you.
Your OPPO Blu-ray player is fully compliant with an Atmos receiver if you follow these easy steps:
CONNECTIONS
PLAYBACK
- 1. Connect your OPPO BDPx10x via HDMI to a compatible Atmos receiver.
- 2. Select the BITSTREAM OUTPUT on your OPPO Player.
- 2. The AV receiver does all ATMOS decoding and rendering.
- 3. The Dolby Atmos bitstream is transported from the OPPO player to the Atmos receiver via HDMI 1.4 with full compatibility. (Dolby Atmos does not require HDMI 2.0)
- 4. Be sure to turn off all internal decoding in the OPPO player. (Choose Bitstream out AND be sure to turn off SECONDARY AUDIO feature)
1. When an Atmos Blu-ray title is played back through a connected Atmos compatible receiver connected to Atmos speakers you will get a full Dolby Atmos playback experience.
The LCD Display on the AVR will most likely display “Dolby Atmos” or "Dolby Atmos - TrueHD”
2. When an Atmos Blu-ray title is played back through a connected Atmos compatible receiver connected to a channel based speaker layout (eg: 5.1 or 7.1) you will enjoy a channel based playback experience.
The LCD Display on the AVR will most likely display “ Dolby True-HD”
em dung 103d duôi .MKV thì atmos 100% là multich 7.1 còn file m2ts thì là truehd atmos !!!!Có bác nào dùng oppo 103/105/D hiện atmos cho phim atmos đuôi .mkv được không. Do em không chắc mình đang dùng dây hdmi 1.4 hay 2.0 (mà sao nó nói không hỗ trợ dây hdmi 2.0 nhỉ).
Vậy file mkv không có hiệu ứng trên cao à ?em dung 103d duôi .MKV thì atmos 100% là multich 7.1 còn file m2ts thì là truehd atmos !!!!
Nó nhận vậy là 8ch pcm rồi thì làm gì có hiệu ứng trên cao!Vậy file mkv không có hiệu ứng trên cao à ?
Atmos 5.1.2củng là 8ch ?Nó nhận vậy là 8ch pcm rồi thì làm gì có hiệu ứng trên cao!
thích atmos của 7.1 pcm thì treo đại 2 cái loa nào đó trên cao bên dưới 5loa thì có âm thanh trên cao thôiAtmos 5.1.2củng là 8ch ?
Âm thanh PCM là âm thanh gốc . dts hay dolby là nén lại thôi .thích atmos của 7.1 pcm thì treo đại 2 cái loa nào đó trên cao bên dưới 5loa thì có âm thanh trên cao thôi
vậy muốn gốc thì treo lên làm gốcÂm thanh PCM là âm thanh gốc . dts hay dolby là nén lại thôi .
Không chừng mấy file demo đó chỉ là dolby digital plus atmos đó bác,còn cái vụ truehd atmos mới khó nhằnVụ Atmos với .mkv có vẻ hơi khó nhằn.
Em mở trên con Oled C7 thì nó báo không hỗ trợ âm thanh này. Nhưng mấy cái clip test dạng (DolbyVision/Dolby Atmos) .mp4 thì lại mở ngon lành.
Nó hiện ngay logo Dolby Atmos và Dolby Vision.
Em đang điên đầu vụ đó đây bác!em dùng pc nhưng k làm cách nào để bistream lên dàn được ,kiểu như pc nó chỉ bistream ac3 ,dts với eac3 (dolbydigital plus atmos)a có kiểm tra lại thì các clip đó đều là audio 6 channel nó là Dolby Digital Plus 5.1 còn mấy cái True-HD Atmos 7.1 là tivi báo không hỗ trợ âm thanh này. Nhưng mà có cái DD+ 5.1 là thằng receiver nó kích lên atmos được.
Bác config làm sao cho nó passthrough cái True-HD Atmos cho thằng Receiver nó xử lý được là ngon.
Bác thảm khảo ở đây https://kodi.wiki/view/Windows_audio
Có đoạn quan trọng này mà em làm hoài k dc
QUAN TRỌNG - Để âm thanh HD hoạt động thì Số lượng Kênh tối đa phải được báo cáo là 8 nếu bất kỳ điều gì khác hơn 8 được báo cáo thì âm thanh HD sẽ không hoạt động ngay cả khi DTS-HD và TrueHD được liệt kê trong hộp Định dạng được mã hóa.
chắc samsung nó thiết kế để chơi với đầu bluray hay đầu HD , còn pc có nhiều cái không tương thích!em định làm em q10 pro nhưng vừa có bác báo lổi tương tựE cũng bị vụ này trên con Xbox One S nó luôn cho ra âm thanh Atmos nhưng không phải là true-HD Atmos e thì không có HTPC để check. Nói chung bác nên kiếm con Blu-ray 4K chơi chắc là ngon nhất.
File MKV là file đã rip, ripper chắc đã decode soundtrack gốc AtMos thành LPCM (multichannel) và nén lại thành AAC nhiều kênh. Hiện nay Atmos và DTS:X chỉ có chip giải mã tích hợp trong receiver như 3300W mới decode được, thậm chí computer cũng không playback được Atmos đâu bác nên bên Anh Duy trả lời đúng đó. Để nguyên Atmos thì không xem trên computer được, có phải ai cũng bitstream ra AVR rồi ra dàn loa đủ chuẩn Atmos đâu bác, phần lớn người xem vẫn còn dùng loa TV hay soundbar.Tui đang xài AVR Denon 3300W.
Các bác cho hỏi sao khi xem các clip demo Atmos trên 3300W thì nó nhận âm thanh là chuẩn Atmos,
nhưng khi xem các film mkv Atmos thì nó nhận âm thanh là Multi channel???
Tui có hỏi kỹ thuật bên Anh Duy audio thì được trả lời là do file mkv đó âm thanh bị coder can thiệp, không còn là Atmos nữa. Vậy sao các bác coder vẫn để film là Atmos nhỉ???
Mong các bác chỉ giáo.
Cảm ơn các bác.
