jackpham
Sau bao ngày chờ đợi thì e nó cũng đã ra mắt firmware 1.0.30
OTA zip file v1.0.30 unroot version
Fshare mirror:
http://www.fshare.vn/file/QQ5APDH1ENUZ
Amazon mirror:
http://ota-cloudfront.zidoo.tv/zidoo_x6/20160114_ZIDOO_X6+Pro_v1.0.30_ota_unroot.zip
MD5: 8EB6078C71E7C952567F6B5B8DD0A41A
v1.0.30 rooted version
Fshare mirror:
http://www.fshare.vn/file/YA7UGFFNQFML
Amazon mirror:
http://ota-cloudfront.zidoo.tv/zidoo_x6/20160114_ZIDOO_X6+Pro_v1.0.30_ota_root.zip
MD5: DE881DA717ED1DF96400279FC68FD416
1. Optimized the hidden of mouse pointer
2. Add the zidoo Home Threater(Experimental function)
3. Video player
a. Add the shade of subtitle
b. Change the operation interface with three-dimension
c. Add function than can download substitle online(It depends on the language your settings.Experimental function)
d. Add adjustable funtion with size/color/location for subtitle
e. Add display of video information(like size/format/resolution, etc.) when video pausing.
4. Flie managementt
a. Add display function when connected USB device
b. Add compatible and shared directory for device, also any shared path
c. It will pop up a login box when entering shared directory and got a validation error, allowing users to login with a new account and saved automatically as a new device
d. It doesn't allow multiple choice with the shared directoryr list, it will judge automatically whether mount or not when copy; if not, have to verify firstly.
e. It will remove a mounted network device when exiting.
f. It only mounts that needed directory when enter shared directory
g. Add scan method of samba
h.Show the volume name in the file manager when insert USB device
5. Optimization of airplay: Solved the broken screen of airmirror, support ISO 9.2
6. Upgrade kodi to 16.0
7. Support external USB audio device
8. Solve the spelling mistake of "contorl" for local disk (thanks for grummel2005's feedback)
9. Solve kodi with black screen sometimes when playing some video(thanks for dorol's feedback).
Fshare mirror:
Amazon mirror:
Fshare mirror:
Amazon mirror:
