Avalon Sentinel
Nhà có tivi 4K, xem phim bằng oppo 103D nhưng vẫn chưa chiến được file 4K nên vẫn phải ngồi hóng. Buồn...
General
Unique ID : 208978246982426242539759530087481128693 (0x9D37BF11607D3F1F9FB9EB426154B6F5)
Format : Matroska
Format version : Version 4 / Version 2
File size : 17.7 GiB
Duration : 58mn 4s
Overall bit rate : 43.7 Mbps
Encoded date : UTC 2015-08-26 18:57:12
Writing application : mkvmerge v8.3.0 ('Over the Horizon') 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
DURATION : 00:57:38.584000000
NUMBER_OF_FRAMES : 824
NUMBER_OF_BYTES : 23351
_STATISTICS_WRITING_APP : mkvmerge v8.3.0 ('Over the Horizon') 64bit
_STATISTICS_WRITING_DATE_UTC : 2015-08-26 18:57:12
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 58mn 4s
Bit rate : 41.3 Mbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.208
Stream size : 16.8 GiB (95%)
Writing library : x264 core 148 r2597 e86f3a1
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=2:0.90
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Color range : Limited
Audio
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 58mn 4s
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 627 MiB (3%)
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Title : CC
Language : English
Default : No
Forced : No
Nvidia Shield pro có nuốt trôi file này ko các bác ! Ai có link fshare hay 4share cho em xin để test thử con này . Thanks ...
Nvidia Shield là vô địch rồi bác, HEVC 4K@60Hz 10-bit hardware decoding thì còn ngán ai nữa
Bạn nào có bản này thì tải lên FShare để nhiều người có dịp thưởng thức 4K thứ thiệt đi nhẩy. Cám ơn trước luôn.
Em đang kéo khi xong tối về báo kết quả test Nvidia Shield cho các bác !
H.264 thì ko có vấn đề gì đâu, H.265 mới ra vấn đềXác nhận với các bác TV Samsung 4K , Himedia Q10IV , Nvidia shield đều chơi tốt file này !
Đó là quảng cáo , thực tế bác đã thử chưa ! Bác có link file HEVC 4K@60Hz 10-bit cho em thử với nóng lòng vì khoản này .
Bác thử file này xem sao (chưa biết là 30 hay 60Hz):
http://www.mediafire.com/download/2dq72ibzqmwvf8e/Clannad+After+Story+OP_.mkv
