sieuthiandroid
ĐẠI LÝ MINIX TẠI VIỆT NAM - HỖ TRỢ CÀI ĐẶT NÂNG CẤP FIRMWARE MIỄN PHÍ CHO CỘNG ĐỒNG VIỆT TRÊN TOÀN QUỐC.
HỖ TRỢ QUA HOTLINE : 0938.005.055 ( Mr Minh )
HỖ TRỢ QUA YAHOO NIK : vip_kts
HỖ TRỢ TẠI TRUNG TÂM MINIX VIỆT NAM : 164 NGUYỄN PHÚC NGUYÊN , P 9 , Q3 , TH.HCM
CÁC BẠN CÓ THỂ GHÉ ĐẾN ĐẠI LÝ MINIX TRÊN TOÀN QUỐC, NƠI BẠN GẦN NHẤT ĐỂ ĐƯỢC HỖ TRỢ TỐT NHẤT
XEM THÊM ĐẠI LÝ MINIX TRÊN TOÀN QUỐC TẠI ĐÂY: http://minix.vn/shop
MINIX ĐÚNG LÀ ĐẲNG CẤP
+ Firmware Minix Neo X7 Mới nhất ngày 12-09-2013 đã có download miễn phí tại đây : Download, Hướng dẫn Update firmware Minix Neo x7, Minix Neo x7mini, Minix Neo x5, Minix Neo x5mini, Minix Neo G4
File Name: NEO X7 4th FW Release (0911, version 005)
Change log:
1.) Fixed Play Store app. search compatibility issue; (Location access fix)
2.) Enhanced Wi-Fi stabiity and throughput.
3.) Added Location access settings.
4.) Added Accessibility settings (Large text, Mouse Wheel Zoom Settings...etc.)
5.) Fixed video stuttering problem.
FIRMWARE THỨ 3 Mới nhất của NEO X7 đã Phát hành Hôm nay 22-08-2013 HỖ TRỢ ĐƯỢC HDMI and SPDIF Passthrough
LINK DOWNLOAD Download
File Name: NEO X7 3 FW phát hành (0822, phiên bản 004)
FIX 1 SỐ VẤN ĐỀ NHƯ SAU :
1.) Fixed Factory data reset bug
2.) Fixed mouse unable to wake up event
3.) Fixed shut down bug, added blinking sleep status LED
4.) Added HDMI and SPDIF passthrough options
5.) Improved DDR stability
6.) Added support for Logitech C525, C920 web cameras
7.) Fixed screenshot bug
firmware Minix neo x7 ngày 10/10
http://minix.com.hk/firmware/pre-006c.rar
http://minix.com.hk/firmware/pre-006c-1080fb.rar
Added tun (VPN) support. (preloaded, you don't need to use tun.ko installer)
Fixed NEO A2 airmouse hot-plug audio bug.
flash method:
1.) unzip the image file to flash with the RKBatchTool.exe V1.7 (Windows) using the Restore;
2.) unzip the image, rename it to update.img, copy the update.img file to a SD card, and put it into X7 (OFF), then power the X7 up, system will detect and prompt asking for update confirmation.
Đẳng Cấp Digital hướng dẫn bạn từng bước update firmware Minix Neo X7...
Bước 1: Bạn tải và giải nén firmware Minix Neo X7 và công cụ Rockchip Batch Tool v1.7 ( đúng phần mềm nhé các bạn )
LINK DOWNLOAD : Download chọn phiên bản NEO X7 2nd FW Release (0813)
Bước 2: Chạy công cụ Rockchip Batch Tool v1.7 và chọn firmware Minix Neo X7 như hình bên dưới
Bước 3: ( bước làm cho máy tính nhận diện driver của X7)
đầu tiên bạn cấm nguồn vào Neo X7, sau đó dùng 1 cái kim nhỏ cắm và giữ chặt vào nút RECOVER trên thiết bị đồng thời bấm và giữ nút nguồn 5-7 giây, bạn sẽ thấy trên phần mềm Rockchip Batch Tool v1.7 hiện thị màu xanh như hình minh họa bên trên.
Sau khi đã nhận được Driver bạn bấm vào nút UPDATE đợi báo "Success" là ok rồi nhé
Các bạn chưa làm được vui lòng gọi cho Đẳng Cấp Digital theo số hotline : 0862.788.788
Video hướng dẫn bạn update firmware Minix neo x7 ( cách làm tương tự như Minix Neo X5 bạn nhé ) :
[video=youtube_share;1MY7-CB3hdc]http://youtu.be/1MY7-CB3hdc[/video]
[video=youtube;zbGp8WL4vu4]http://www.youtube.com/watch?v=zbGp8WL4vu4[/video]
Change log:
flash method:
