Đang quan tâm em này, ko biết có bác nào dùng rồi cho tí review
So sánh với Denon thì tương đương model nào ?
Bring the sound of studio master to your home, with Pioneer-original surround sound technologies Phase Control and MCACC with DTS-HD Master Audio and Dolby TrueHD new generation audio formats. Features by HDMI connection also provide enhanced video and audio, as well as superior sound from your iPod/iPhone
Features
Click here to find out more
Pioneer-Exclusive Innovations
Phase Control (Bass management system ensures precision low frequency output)
Advanced MCACC setup with 9-band EQ
Standing Wave Control
Advanced Sound Retriever (for enhanced PC and portable audio)
Front Stage Surround Advance
Auto Level Control (Multi)
Advanced Direct Energy Power Amplifier
Features for Superior Sound Quality
Maximum power (6 ohms): 170 W x 7ch
PQLS 2ch Audio
Digital Core Engine with Freescale 400MIPS Processing DSP
192 kHz/24-bit DAC
Surround Sound Technologies
DTS-ES/DTS 96/24/Dolby Digital EX/Dolby Digital Plus decoders
Neural-THX Surround
Sound Delay for adjusting Lip Sync (0.0-10.0 frames)
Dialogue Enhancement
Enhanced Convenience
iPod player digital direct via USB
USB memory audio ready (USB Host function)
HDMI Upscaler
Digital video converter (up to HDMI)
Multi-Zone Audio/Video (Zone 2)
VSX-1019AH-K
Power Spec 6,1k,1%THD
140W
ch
7
THX
HD-Audio
Yes
MCACC
Advanced
PHASE CONTROL
Yes
SRC
PQLS
2ch
LowJitter Master Clock (tentativej
ALC MULTI
Yes
Multi
Neural THX
Yes
WMA9Pro
Yes
HDMI Terminal (Total)
4/1
Front HDMI
Deep Color
Yes
x.v.Color
Yes
KURO Link
Yes
Multi Link
Yes
>>Volume, Power On/Off, Input select
Yes
Analog to Analog up/down Conversion
Yes
Analog to HDMI up Conversion
Yes
Scalar ( up to 1080p, Analog to HDMIj
Yes
PureCinemaTM (for 480i analog input)
Yes
>>Film mode/3D Motion Adaptive
Deinterlacer
Yes
>>3D YNR
Yes
>>2D Y/C Separation (Comb Filter)
Yes
iPod Digital
Yes
@@ Jacket Pictures from iPod
Yes
Works with iPhone
Yes
USB
Yes
>>Jpeg slide show via USB
Yes
GUI
Yes
AV (Composite) in / out
3/1
Audio in / out (Tuner included)
4/1
Component in / out
2/1
Digital in / out
4/-
S Terminal
Multi-Zone
Zone2
Multi Zone Composite out
Zone2
12V trigger
232C
Cosmetics
Plastic
*1 Action, Drama, Sci-Fi, Mono Film, Entertainment Show, Expanded Theater, TV Surround, Advanced Game, Sports, Classical, Rock/Pop, Unplugged, Extended Stereo + Phones Surround
*2 Action, Drama, Entertainment Show, Advanced Game, Sports, Classical, Rock/Pop, Unplugged, Extended Stereo
*3 The units are compatible with 5th generation and newer iPod, iPod nano, and iPod touch, but compatibility may vary depending on the software incorporated in your iPod. The Pioneer A/V receivers do not support software versions prior to iPod update 2004-10-20. Consult your nearest Pioneer dealer for supported versions.
While connected to the A/V receiver, iPod cannot be controlled directly and only the word "Pioneer" is displayed on the iPod display. Functions such as equalizer cannot be controlled using the receiver, so we recommend you to turn off the equalizer before connecting. iPod is for legal or rightholder-authorized copying only. Don't steal music. iPod is a trademark of Apple Computer, Inc., registered in the U.S. and other countries.
Features
PQLS 2ch Audio
192 kHz/24-bit DAC
Neural-THX Surround
HDMI Upscaler
VSX-1019AH-K
140W
ch
7
THX
HD-Audio
Yes
MCACC
Advanced
PHASE CONTROL
Yes
SRC
PQLS
2ch
ALC MULTI
Yes
Multi
Neural THX
Yes
WMA9Pro
Yes
4/1
Front HDMI
Deep Color
Yes
x.v.Color
Yes
KURO Link
Yes
Multi Link
Yes
Yes
Yes
Yes
Yes
Yes
Deinterlacer
Yes
>>3D YNR
Yes
Yes
iPod Digital
Yes
Yes
Works with iPhone
Yes
USB
Yes
Yes
GUI
Yes
3/1
4/1
Component in / out
2/1
Digital in / out
4/-
S Terminal
Multi-Zone
Zone2
Zone2
12V trigger
232C
Cosmetics
Plastic
