Mede8er MED500X – Đầu phát số 1 trên MPCclub!
Mede8erViet
Ðề: Mede8er MED500X – Đầu phát số 1 trên MPCclub!
Gửi các Mede8ter - người dùng Mede8er
Mede8er sau 1 thời gian làm việc test firmware đã cho ra bản V4 4.0.4 với nhiều cải tiến, fix lỗi cho thấy Mede8er là nhà cung cấp thiêt bị HD đẳng cấp và chuyên nghiệp.
Chúng tôi luôn làm việc hết mình vì những khách hàng của Mede8er.Mọi người up thử firmware mới và cho biết ý kiến nhé.Thanks
Hi All Mede8ers
After some lengthy testing by the Mede8er Beta testers we are now releasing V4.0.4 to all Mede8er users. We really believe this release is stable and will enhance your mede8er in so many ways. Please download and follow these installation instructions.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
MED400X
http://www.mede8er.org/beta/Firmware_Final/Mede8er_MED400X_V4.0.4_3March2011_INC_HDaudio.zip
http://www.mede8er.org/beta/Firmware_Final/Mede8er_MED400X_V4.0.4_3March2011_NO_HDaudio.zip
MED500X
http://www.mede8er.org/beta/Firmware_Final/Mede8er_MED500X_V4.0.4_3March2011_INC_HDaudio.zip
http://www.mede8er.org/beta/Firmware_Final/Mede8er_MED500X_V4.0.4_3March2011_NO_HDaudio.zip
Update the Mede8er in the normal way via Emergency procedure.
DO NOT USE THE RESTORE CONFIGERATION - KHÔNG DÙNG RESTORE
Emergency Installation Procedure
- Download the latest Firmware from the Mede8er website
- Unrar / Unzip the file i.e. install.img
- Copy this file to the root directory of a Flash Drive
- Plug the flash drive into the Mede8er
- Disconnect the power jack at the rear of the Mede8er then plug it back in
- Now press the on/off button (on Mede8er unit - not remote) - keep it pressed in for 15 seconds and then release
- The LED on the front fascia of the Mede8er with flash red-blue
- You will get a progress bar on your TV display (some TV's will not display this)
- Wait until the Mede8er re boots itself +/- 90 sec
- Your Mede8er is now updated;
- Re-boot once by pulling power and use as normal
- Do not use Restore Confiig
xxxx WARNING - DO NOT REMOVE POWER DURING THE UPDATE PROCESS xxxxx
Bạn có thể download ảnh Cover-Art của phim ở đây để thử nếu bạn chưa có
http://www.mede8er.org/beta_2010/Mede8er_Video_Wall_demo_images.rar
Hướng dẫn sử dụng online bằng nhiều thứ tiếng:
http://www.mede8er.com/mede8er_video_wall_user_guide.html
The Mede8er Web Remote full functionality is not 100% complete but many aspects can be used for demo purposes.
Switch on the Web Remote in the Setup menu
Type the following in your browsers adress bar and change the your-mede8er-ip to the Mede8er actuall IP
http://your-mede8er-ip:1024/
pls shoutcast radio staton shortcut samples http://www.mede8er.org/artwork/temp/pls_samples.rar
Note: The Video Wall now uses the USB DrIve "name" so pls make sure that your USB drives is named and if you use more than one USB Drive make sure they have different names. This can be changed in Windows -- My Computer -- Drive - Properties
Những cải tiến và sửa lỗi:
1. Bootloader updater not working - should update to #26 - fixed
2. Large size FAT32 USB Hard Drive not working - fixed
3. HFS Volume link to Video Wall not working - fixed
4. No audio .mov container has H264 codec + PCM audio - fixed
5. Video Wall image quality folder.jpg & about.jpg - fixed
6. Video Wall Navigation bug - one movie on last page - fixed
7. Video Wall increased max folder.jpg size to 100k
8. Video Wall speed "next page" - fixed
9. Watched Indicator on root of HDD - fixed
10. HDD Format no name - fixed
11. IR Interference from other remotes - fixed
12. File Manager copy to protected folder - fixed
13. Web Remote enabled by default - fixed
14. Slidshow Playlist Option - fixed
15. HFS Volume mask System files ie .fseventsd .Trashes .Spotlight-V100 - fixed
16. Video Wall MAC - .AppleDouble folder problem - fixed
17. Ken Burns ettect in Picture Slide Show not working - fixed
18. m3u Playlist not working with "Umlauts" characters - fixed
19. Focus / Unfocus Series View Video Wall hard to see the focus - fixed
20. Screensaver artwork changed
21. Screensaver movement not smooth MP3 play - improved
22. Screensaver during slideshow - fixed
23. Screensaver shows when playing multiple short video in a folder - fixed
24. Screensaver appears in picture slideshow - fixed
25. Older DD hardware cannot switch MED500x off with front on/off button - fixed
26. Open image and press Zoom+ and image zooms to 16x - It should start with 2x - fixed
27. File Manager "Move" function not working - fixed
28. Protected folder in Media Library not protected in Video Wall - Fixed
29. MP4 not working from video wall "www123" profile Sony PSP Codec ID: MSNV. Works from Media Library - fixed
30 No audio .mov container has H264 codec + PCM audio - fixed
Original V4 Features
* Support Dolby True HD and DTS MA passthrough - DD+ hardware
• New “Video Wall” with mapped share functionality
• New GUI
• Improved network streaming performance (both Samba & NFS / DD+ and DD hardware)
• Improved and fixed SAMBA NTFS write (NAS Mode)
• Shoutcast Radio API implementation
• New SDK and general improvement and bug fix
• Picture Thumbnail Viewer
• Improved upsampled picture quality SD content
• Added Thai Language support
• Added Icelandic Language support
Known SDK Issues
* Sceensaver on pls Radio Station does not change song name
* MED500X cannot connect via wireless that does not broadcast SSID
* WiFi WEP
* HD Audio will only passthrough on HDMI if TV Res Output is set to 720 or Higher
* Downmix SPDIF / Co- Ax Digital must set HDMI AND SPDIF to Downmix 2 CH
* Flac .cue files support (SDK- Realtek)
* APE .cue files support (SDK - Realtek)
* ID3 tags FLAC Audio (SDK - Realtek)
* BDMV over NFS ( SDK - Realtek)
* DD+ Hardware will not Passthrough to Core5.1 from HD Audio source on SPDIF (Awaiting Realtek)
Workaround - Use the "No HD Audio Firmware Version"
* Long Playlist over 3000 songs
* Random Audio Play
* PPPoE bug (SDK- Realtek)
* Some DVD files still show Subtitles although set to "off" in the Setup Menu
* "autoplay" Folder DVD ISO from FAT32 USB stick -- Starts with no picture and press zoom button then it corrects - fixed but only plays for +- 2 min and then restarts. Suggest to use raw VOB files for "autoplay" folder
I would like to thank the Mede8er Alpha and Beta testers for all their testing and feedback.
Mede8er1 (trích tư diễn đàn hỗ trợ của Mede8er)
Bác Mede8er cho hỏi thêm là 15 tới này ngoài sản phẩm MED 500X về thì có sản phẩm Mede8er MED10WF không?
meigyoku1
Thấy có mỗi chủ topic quảng cáo cho sản phẩm này. Có 1 sản phẩm được nhiều anh em quảng cáo trên forum.
Mede8erViet
Cảm ơn anh cezeroosaka đã quan tâm. Wifi của Mede8er là Mede8er MED10WF sẽ có mặt khoảng cuối tháng 4 anh ạ. Hi vọng được anh ủng hộ ;)
Mede8erViet
Còn có MPCClub - diễn đàn số 1 thế giới về thiết bị phát HD, các trang web, forum Hitech nổi tiếng thế giới như AVForum,T3 Magazine,Techdaily....
Chi tiết anh có thể tham khảo thêm ở đây :
Mede8er REVIEW
Mede8erViet
Hôm nay Mede8erViet giới thiệu đến cộng đồng sử dụng Mede8er MED400X, Mede8er MED500X một bản firmware được mod thêm các tính năng dựa trên bản chuẩn của Mede8er.Thành viên SHIZZL là 1 Beta Tester của Mede8er, anh đã nghiên cứu và cho ra mắt bản firmware MOD V4.04 với các tính năng nổi bật trong hàng loạt các tính năng giúp Mede8er vượt trội hơn hẳn các thiết bị khác.Chúng ta hãy cùng khám phá firmware này nhé ;)
TÍNH NĂNG MỚI :​
DUYỆT PHIM DẠNG ẢNH:
- Bạn dễ dàng thay đổi kiểu duyệt phim 2x6, 2x7, 3x8 (số dòng x số phim hiện ra trên 1 dòng) hay dạng danh mục
- Ấn INFO để Tìm Kiếm
- Ở dạng Danh mục bạn ấn nút Mũi tên sang phải để vào thư mục, Mũi tên bên trái để Quay Lại
- Ấn nút Mũi tên đi xuống khi ở phim cuối cùng để sang trang phim mới, Mũi tên đi lên khi ở phim đầu tiên để sang trang phim mới
- In List View 2 you can jump to previous/next page by pressing „LEFT“ or „RIGHT“
- Giờ đây bạn đã có thể nghe nhạc ngay ở trong Duyệt Phim Dạng Ảnh, sau khi bắt đầu chơi nhạc, bạn có thể ấn INFO để biết thông tin chi tiết về bài hát.
- Bạn có thể sử dụng nút GO TO để tua nhanh khi nghe nhạc
Bạn có thể ấn nút FFW để cho bài nhạc chạy nhanh hơn ;)
- Bạn có thể hẹn giờ tắt Mede8er sau thời gian: 15, 30, 45, 60, 90, 120, 180 hay 240 phút.
- Bạn có thể lựa chọn kiểu Duyệt Phim theo Thể Loại
ỨNG DỤNG MẠNG:
- Dự báo thời tiết, Picasa, Flickr và Tin Tức đã sẵn sàng
Tự Động Chạy:
- Bạn có thể chọn chế độ tự động chạy cho Mede8er khi khởi động từ HDD, USB, NAS hay Video Wall
HƯỚNG DẪN CÀI ĐẶT:
- Copy file install.img vào usb
- Tháo nguồn
- Cắm nguồn - Cắm USB - Bấm giữ nút POWER trong 10s
- Vào NETWORK SETTING bật "REMOTE CONTROL" lên
- Chú ý: KHÔNG DÙNG SYSTEM RESTORE
Hướng dẫn sử dụng :
- Add thư mục bạn muốn vào VIDEO WALL- DUYỆT PHIM DẠNG ẢNH bằng nút MENU
- Vào VIDEO WALL- DUYỆT PHIM DẠNG ẢNH và ấn MENU
- Trong SETTING bạn có thể thay đổi Moviewall, chạy các ứng dụng mạng , thay đổi giao diện
DOWNLOAD:
MED400X:
http://www.multiupload.com/H3T4F6OO8R
http://rapidshare.com/files/454360510/Mede8er_MED400X_V4.0.4_FW_MOD_2_BY_SHIZZL.zip
MED500X:
http://www.multiupload.com/A31SJZS8IH
http://rapidshare.com/files/454453020/Mede8er_MED500X_V4.0.4_FW_MOD_2_BY_SHIZZL.zip
Mình đã dùng thử và thấy chạy khá OK. Mọi người có thể up lên cho Mede8er 400X, Mede8er MED500X của mình nhé ;) Thank you SHIZZL for moding this great Mede8er firmware.Have fun
Vài hình ảnh cho khí thế nào :
Thay đổi giao diện tuỳ thích
Các ứng dụng mạng
Mede8erViet
Giao diện của 1 thiết bị phát HD phần nào nói lên đẳng cấp của thương hiệu HD đó. Mede8er với giao diện mới đẹp mắt, thân thiện đã phần nào làm hài lòng đa số người dùng Mede8er. Nếu 1 ngày nào đó bạn muốn thay đổi giao diện của Mede8er làm mới chiếc Mede8er thì ngày nào đó có thể là ngày hôm nay ;)
Với bộ sưu tập giao diện cực kì đẹp mắt và ấn tượng này, người dùng Mede8er có thể dễ dàng thay đổi 5 giao diện mình muốn tuỳ theo sở thích, gu thẩm mĩ của mỗi người.
Mede8er xin giới thiệu đến người dùng Mede8er bộ sưu tập giao diện dưới đây và xin cảm ơn SHIZZL và GlynRS2 - Beta Tester của Mede8er đã giúp chúng ta có thể làm mới chiếc Mede8er của mình.
Hướng dẫn để cài giao diện
1.Cài firmware của SHIZZL theo hướng dẫn dưới đây:
[Mede8er] Firmware V4.0.4 SPECIAL của Beta Tester SHIZZL cho người dùng Mede8er MED400X,MED500X
2.Tải thư mục Resource dưới đây về và cop vào ổ đĩa phim của bạn - Trong đó có chứa sẵn các Themes - Giao diện của Mede8er
http://www.4shared.com/file/N6is-GBh/Resource.html
3.Muốn dùng giao diện nào thì bạn chỉ cần copy tất cả file trong thư mục giao diện nào đó vào thư mục CUSTOM - Bạn có thể sử dụng tính năng COPY - DELETE file ngay trên Mede8er
4.Add thư mục phim của bạn vào VIDEOWALL - Vào VIDEOWALL - Ấn Menu - Chọn Setting - Tiếp tục chọn biểu tượng Setting ở cuối - Vào SKIN và chọn CUSTOM để có giao diện bạn muốn cho Mede8er
5.Thưởng thức giao diện mới của Mede8er nào ;)
Các giao diện mới của Mede8er MED400X, MED500X
Simple Skin NO LOGO
BEACH
http://www.multiupload.com/2NSY0DH54X
Med to XBMC
index.php
http://www.datafilehost.com/download-12aee325.html
Red Cinema
http://www.datafilehost.com/download-b2bbf15a.html
TV1
TV2:
HOME CINEMA
FLOWING LIGHT
ALUMINIUM 2D
CARBON
HOME SKIN
NIGHT
HONEY
PLANET EARTH
PLANET EARTH V2
http://dl.dropbox.com/u/18987218/Earth.rar
ABOVE THE CLOUDS
MORNING DEW
FLIMSTRIPS BLUE
FILM REEL :
http://dl.dropbox.com/u/18987218/Film%20Reel.rar
Canvas Clapperboard MED400x
http://dl.dropbox.com/u/18987218/Canvas%20Clapperboard%20Med400x.rar
Canvas Clapperboard MED500x
http://dl.dropbox.com/u/18987218/Canvas%20Clapperboard%20Med500x.rar
Clapperboard v2 MED400X
http://dl.dropbox.com/u/18987218/Clapperboard%20v2%20MED400x.rar
Clapperboard v2 MED500X
http://dl.dropbox.com/u/18987218/Clapperboard%20v2%20MED500x.rar
* UPDATE 14.4.2011:
UTOPIA :
http://dl.dropbox.com/u/18987218/Utopia.rar
Cho anh em nào thích đi Ferrari ;)
http://www.multiupload.com/2KE9234CFY
Không thì đi Porsche vậy ;)
4RXMO7ZF41
meomatto
Kinh, đẹp quá nhờ! Mede8 chuẩn đới! :D
Mede8erViet
Mình sẽ post bài hướng dẫn làm ảnh phim tự động cho Mede8er bằng phần mềm riêng của Mede8er là YAMJ2Mede8er - Mọi người có thể đợi xem nhé
kinggai
Bao giờ Mede cho ra firm mới với những tính năng như trên
Mede8erViet
Ý bác đó là ra FW gốc của hãng, còn FW này là MOD lại rồi
Firmware đó được làm ra bởi SHIZZL, là người của Mede8er, anh có thể dùng thoải mái. Cảm ơn anh jackpham đã giúp mình hiểu ý anh kinggai.
nmtbk
Có cái Mi đi nào kéo được torrent ko nhỉ?
Mede8erViet
Chào anh nmtbk, Mede8er tập trung vào giải trí nên tính năng torrent bên hãng không cho vào. Hi vọng sẽ được anh nmtbk ủng hộ trong thời gian tới ;)
Mede8erViet
Các giải thưởng và các bài viết đánh giá về Mede8er MED500X:
Thedigitalfix.com đã bình chọn Mede8er nhiều nhất trong cuộc thi đấu giữa Xtreamer, Pop-corn C200, HTPC ASRock Ion 330HT và Shuttle H7 4500H XPC . Một bài viết hay và chi tiết để anh em tham khảo :
Network Media Streamer Face Off!
It is obvious there is NO perfect solution, but there are options for almost every need. The Mede8er wins as our pick for the best standalone option due to it's speed and functionality; while the countless options available for full HTPCs make choosing any particular unit a difficult task. We really like the Shuttle - it's a solid and powerful piece of hardware, but it IS expensive and the Core2Duo processor is power hungry. It's also the noisiest unit on test given the need for a larger fan. It can do far more than anything else here though and the expansion options mean it is totally future-proof.
Mede8er - The Greatest Show On Earth
bogay
Em đang lăn tăn 500X và HD life v3, thấy giá cả chênh nhau nhiều mà xem qua review cũng gần như nhau, bác cho em lời khuyên nhé.
minh_lay
V3 đi bác, rẻ hơn hẳn bác ạ, cũng như 500X thôi nhưng rẻ hơn nhiều.
ChipLe
Khó so sánh lắm bác. Nhìn 1 cái wave tàu với 1 cái wave thái, thông số kỹ thuật nó cũng như nhau
