Egreat R500 : một hình thức phá cách mới lạ
ceo-sitcom
E vửa thấy con này , nên tạm dùng bản review từ Google để a e tham khảo trước , e sẽ có bài đập hộp chi tiết hơn cho em này sau nhé :
Product Description
[URL="http://www.singingegg.com/pics/egreat-r500-1.gif"] [/URL]
[URL="http://www.singingegg.com/pics/egreat-r500-2.gif"] [/URL]
[URL="http://www.singingegg.com/pics/egreat-r500-3.gif"] [/URL]
[URL="http://www.singingegg.com/pics/egreat-r500-4.gif"] [/URL]
[URL="http://www.singingegg.com/pics/egreat-r500-5.gif"] [/URL]
[URL="http://www.singingegg.com/pics/egreat-r500-6.gif"] [/URL]
Overview:
Appearance using solid Aluminum alloy case with cylinder frame by black wire drawing technology, add the shielded enclosure, Ultra-thin framework, good heat sink
3.5"hdd mobile rack design give user easily/friendly/quickly installation
HDMI1.3 port support full HD 1080p
3 adding 1 card reader design, support SDHC, SD,MMC,MS,MS_Pro, MS_Duo
Build-in wireless card(Optional)
Strong network function, RSS, weather forecast,BT download and so on
Support web browser, wireless Keyboard and mouse are supported also.
Turn on/off by remote control.
Double color digital screen, display the boot, play time,audio output mode, resolution, playing, pause ,repeat and so on
11 key touch-key designed(play, pause, stop, return and the arrows keys)without the remote control can complete all operations
DVB-T/DMB-TH supported
APE,OGG,FLAC,CUE can be supported
Support True HD ,DTS-HD, DTS-MA
Support HD audio downmix
Playback TS and M2TS files without interval
BD simple navigation; multi subtitle and audio track switch; chapter selection function
Adjust external subtitle color, size, position, contour color and so on
Exclusive dual language external subtitles and automatic identification error correction of the subtitle coding function
Time seek during playing, time jump and time scroll bar two method
Support slide show; music background, screen savor, movie preview, parental control
Realtek 1183DD+ 400MHz MIPS CPU, 256MB NAND FLASH and 256MB DDR2
Specifications:
Video output:
HDMI1.3
Component
AV output
Audio output:
Stereo
SPDIF digital output
Coaxial output
Other connectors:
USB HOST ports x 2
USB Slave port x 1
External SATA port x 1,connect with SATA HDD or DVD ROM directly without extra power adaptor
SD/MS/MMC ports
10/100M RJ45 port, support playback by LAN
Network function:
SMB,NFS,UPNP supported
Support YOU TUBE and PPS
RSS, weather Forecast service, BT download and so on
Webpage browser
File format:
Video container: RM/RMVB, MPEG1/2/4 Elementary (M1V, M2V, M4V), MPEG1/2 PS (M2P, MPG), MPEG2 Transport Stream (TS, TP, TRP, M2T, M2TS, MTS), VOB, AVI, ASF, WMV, Matroska (MKV), MOV (H.264), MP4, RMP4, IFO, DVD-ISO,BD-ISO, MINI BD,BD-9,BD25,BD50,RBD,D5,D9,DVD,CD
Video decoder: MPEG-1, VCD1.0/2.0,SVCD, MPEG-2 MP@HL, ISO,IFO,VOB,TS, HD MPEG4 SP/ASP,Xvid, H.264, WMV9, VC-1 AP@L, VC-1 MP@HL and AP@L3, DivX3/4/5, XVID SD/HD, RM/RMVB 8/9/10
Audio container: AAC, M4A,MPEG audio (MP1, MP2, MP3, MPA),WAV,FLAC+CUE,APE+CUE,OGG
Audio decoder: MPEG I Layer 1/2/3(2-CH),MPEG II 1/2(Multi-Channel), LPCM,ADPCM,FLAC,AAC,WAV,OGG, Dolby Digital, RA1/RA-cook/RA-Lossless
Picture format: JPG,BMP,GIF,PNG
Subtitle format: SRT, SUB, SSA, SMI, idx+sub, TXT, PGS
Menu language: Simple Chinese, traditional Chinese, English, Russian, Spanish, Czech,
Dutch, Italian, French, German, Turkish, Hebrew
HDD partition: FAT32,NTFS
Package:
SATA cable 1pcs
Remote control 1pcs
12V/3A power adapter 1pcs
AC cable 1pcs
Simple user guide 1pcs
Screw bag 1pcs
http://www.hdvietnam.com/diendan/12...thuc-la-dai-dien-cua-egreat-tai-viet-nam.html
danvt
Ðề: Egreat R500 : một hình thức phá cách mới lạ
Cái này nhìn cũng đẹp, chip Realtek mới. có điều bác để nguyên tiếng Anh thì dễ đọc hơn, google dịch đọc nhức đầu quá :D
ceo-sitcom
:D Mình cũng biết vậy , nhưng đang cho đội ngũ review đập hộp cho chuẩn rùi sẽ bổ sung sau , vậy mình để tiếng Anh cho a e dễ nhận đinh nha ? Cho e ý kiến để e sửa hoàn chinh hơn các Bác
diyomate
Cái này có gì đâu mà phá cách bác, giống TViX 7000 thôi mà.
Cấu hình R500 chạy chip Realtek 1183, không có Line-in nhé các bác. Em xem thông số trên web của Egreat thấy có line-in nhập một ít về mới tá hỏa là ko có Line-in.
Cấu hình chuẩn chưa có USB WIFI và Module DTV. Hiện tại hãng chưa có Module DTV để bán nên tính năng chẳng khác gì R200 - Hơn được dàn nút bấn trên nóc.
Giao diện giống y chang R3A, Firm mới nhất đã có tiếng Việt.
Bác nào muốn test qua em xem nhé.
TamNhinSo.Net
Em này chẳng có gì mới, cả cái kiểu dáng cũng của em 7000A. Quang trọng cái giá có làm người hâm mộ mềm lòng hay không
hangbinhdan
R500 có bộ vỏ giống y như em trên :D
ceo-sitcom
Như bạn TNS nói đấy giá cả hợp lý là Sure
Eagethd
Dòng chip này có tinh năng gì mới ( ưu điểm hay khuyết điểm ) gì không Bác
meigyoku1
Thấy 1 trang web họ ghi:
NEW Egreat R500 Realtek 1183DD+ 400MHz MIPS CPU,Build-in wireless card,full HD 1080p
Share |
Quality
Service
Price
Value 1 Review(s)
Availability: In stock.
$156.95
ceo-sitcom
Share |
Quality
Service
Price
Value 1 Review(s)
$156.95
Vâng . Nhưng theo mình biết giá tại Việt Nam chắc rẻ hơn xíu
ceo-sitcom
Theo thông tin từ nhà phân phối thì Fw cũng được hãng cập nhật thường xuyên
Eagethd
Tầm tiền như báo giá thì oki . Chấp nhận được
Eagethd
hihi . Quan trọng là người dùng có nhìn giống Bác không nữa
Đã chạy thử con này thấy kiểu dang hay , Fw làm cũng được so với giá thành người bán đưa ra . A e nào có nhu cầu thì nghiên cứu
hangbinhdan
Em gái này cắm chuột usb thì ngon nhưng ko hiểu sao cái bàn phím usb của em cắm vào do to quá hay sao nên không phím nào ấn được
Eagethd
Cắm bàn phím vào để làm gì Bác ? E không có con này nhưng nghe thấy muôn vọc
ceo-sitcom
http://www.mediafire.com/?qqt5lnyke20cqqw . ( Fw new cho HDplayer S7A ) a e nào có chơi cập nhật nhé
Mod thông cảm vì cái mạng inter net bị gì đó nên gửi 2 bài nội dung như nhau xem lại hết hồn , không phải e spam đừng khóa e tội nghiệp
Eagethd
Hehe . Đợi hoài mà không chủ topic làm review tiếng Việt , lại còn kêu a e nào làm thì gửi vào
