Chào Các Bác! Thương hiệu Bel Canto đang sale giảm 50% ở Mỹ nè các Bác (hàng bandnew)
REF500
M Mono Amplifier 1200USD
REF500
S Dual Mono Amplifier 1000USD.
Bác nào cần PM mình nhé, có thể đem giúp về 1 cái thôi.
Specifications
Maximum Power Output:
500W 4 ohms, 250W 8 ohms per channel
Power Output 1% THD:
400W 4 ohms, 200W 8 ohms per channel
Minimum Load:
3 ohms per channel
Peak Output Current:
35 amperes per channel
Frequency Response:
+/-3 dB 1.5Hz-70KHz, all loads
THD+N:
0.003% 1W, 1KHz, 4 ohms
IMD (CCIF):
0.0003%, 1W, 14:15KHz, 4 ohms
Output noise:
35uVRMS A-weighted 10Hz-20KHz
Voltage gain:
27dB (single ended or balanced input)
Damping factor:
>1000
Output Impedance at 100Hz:
<8 milliohms
Dynamic Range:
121dB
Input Voltage for Max Output:
2Vrms
Input connections:
Single-ended RCA or balanced XLR
RCA input impedance:
100Kohms
Balanced input impedance:
200Kohms
Output connections:
2-sets WBT 5-way binding posts
Power On usage:
19W
Power Off usage:
0.0W
Internally Set Operating Voltages:
100-120VAC or 230-240VAC 50/60 Hz
Size:
8.5 x 3.5 x 12[inches], 216 x 88 x 305[mm] (WxHxD)
Weight:
15 lbs, 7 Kg
Features and specifications are subject to improvements and changes without prior notice.
